entries.ini commands supported by DX WinNT6.x True Integrator
[sysPrepOC]
Component_Name=advpack.dll,LaunchINFSection,INF_FileName,SectionName
;or
Component_Name=setupapi.dll,InstallHinfSection,INF_FileName,SectionName
;;;example
[SysPrepOC]Unlocker=advpack.dll,LaunchINFSection,Unlocker.inf,UnlockerSilverlight=setupapi.dll,InstallHinfSection,MSSlight.inf,Silverlight
[General]
;;;example
[General]BuildDate=2010-10-27T11:05:11ZDescription="Freeware tool which overcomes a Windows bug"Language=EnglishTitle=UnlockerVersion=1.9.0WebSite=http://ccollomb.free.fr/unlocker/processorArchitecture=x86 ; --> Warning: this key is used to force addon integration only in a certain system architecture; if present OS architecture is not the one defined in this key, DX WinNT6.x True Integrator skips the AddOnForceLang=Italiano ; --> Warning: this key is used to force addon integration only in a certain system language; if present OS language is not the one defined in this key, DX WinNT6.x True Integrator skips the AddOnReleaseType=True AddOnCustomizedby=OnePieceCopyright=CEDRICK 'NITCH' COLLOMBCompany=CEDRICK 'NITCH' COLLOMBInstallPackageName=Unlocker.infLastUpdateTime=2010-10-27T11:05:11Z
about Dirids:
http://msdn.microsof...8(v=VS.85).aspx
about Security Descriptor Definition Language to be used in [securityRegistry*Integration] and in [securityFiles*Integration]:
http://msdn.microsof...7(v=VS.85).aspx
http://msdn.microsof...e/cc982153.aspx
http://blogs.technet...ove-part-1.aspx
http://technet.micro...y/cc512610.aspx
[securityRegistryBeforeIntegration]
;;;example
[SecurityRegistryBeforeIntegration]"CLASSES_ROOT\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""CURRENT_USER\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""CURRENT_USER\Software\Classes",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""MACHINE\SOFTWARE\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""MACHINE\SYSTEM\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""MACHINE\SECURITY\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""MACHINE\SAM\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""MACHINE\COMPONENTS\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\.DEFAULT\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\DefaultUsers\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)"
[securityRegistryAfterIntegration]
;;;example
[SecurityRegistryAfterIntegration]"USERS\S-1-5-18_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\SystemProfile_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-18\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\SystemProfile\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-19_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\LocalService_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-19\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\LocalService\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-20_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\NetworkService_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-20\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\NetworkService\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-21*_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\UserProfile_Classes\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\S-1-5-21*\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\UserProfile\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)""USERS\SMIStoreMachine\Name",0,"D:P(A;CIOI;GR;;;BU)(A;CIOI;GA;;;BA)(A;CIOI;GA;;;SY)(A;CIOI;GA;;;CO)"
DX WinNT6.x True Integrator loads this HIVES as default, so like previous example if want to add reglines in HKLM\Software, you need to use MACHINE\%KEY_SOFTWARE%, if you want to add or delete reglines in HKLM\System instead, you need MACHINE\%KEY_SYSTEM%
"%MountDir%\Windows\System32\config\SOFTWARE" = %KEY_SOFTWARE%"%MountDir%\Windows\System32\config\SYSTEM" = %KEY_SYSTEM%"%MountDir%\Windows\System32\config\SECURITY" = %KEY_SECURITY%"%MountDir%\Windows\System32\config\SAM" = %KEY_SAM%"%MountDir%\Windows\System32\config\COMPONENTS" = %KEY_COMPONENTS%"%MountDir%\Windows\System32\config\DEFAULT" = %KEY_DEFAULT%"%MountDir%\Users\default\ntuser.dat" = %KEY_NTUSER%"%MountDir%\Windows\system32\smi\store\Machine\schema.dat" = %KEY_SCHEMA%"%MountDir%\WINDOWS\system32\config\systemprofile\NTUSER.DAT" = %KEY_NTUSER_SP%"%MountDir%\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\Windows\UsrClass.dat" = %KEY_USRCLASS_SP%"%MountDir%\Windows\ServiceProfiles\LocalService\NTUSER.DAT" = %KEY_NTUSER_LS%"%MountDir%\Windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\UsrClass.dat" = %KEY_USRCLASS_LS%"%MountDir%\Windows\ServiceProfiles\NetworkService\NTUSER.DAT" = %KEY_NTUSER_NS%"%MountDir%\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\UsrClass.dat" = %KEY_USRCLASS_NS%"%MountDir%\Users\Administrator\NTUSER.DAT" = %KEY_NTUSER_ADMIN%"%MountDir%\Users\Administrator\AppData\Local\Microsoft\Windows\UsrClass.dat" = %KEY_USRCLASS_ADMIN%
[securityFilesBeforeIntegration]
;;;example
[SecurityFilesBeforeIntegration]%11%\FileName.exe,0,"D:P(A;;GA;;;BA)(A;;GR;;;SY)(A;;GR;;;BU)"%PROGRAMDATA%,0,"D:PAI(A;;0x1200a9;;;SY)(A;OICIIO;GXGR;;;SY)(A;;FA;;;BA)(A;OICIIO;GA;;;BA)(A;;0x1200a9;;;BU)(A;OICIIO;GXGR;;;BU)"%10%\regedit.exe,0,"D:P(A;CI;GR;;;LS)(A;CI;GR;;;BU)(A;CI;GR;;;PU)(A;CI;GA;;;BA)(A;CI;GA;;;SY)(A;CI;GA;;;CO)"
[securityFilesAfterIntegration]
;;;example
[SecurityFilesAfterIntegration]%11%\FileName.exe,0,"D:P(A;;GR;;;BA)(A;;GR;;;SY)(A;;GR;;;BU)"%ALLUSERSPROFILE%,0,"D:P(A;CI;GR;;;BU)(A;CI;GA;;;BA)(A;CI;GA;;;SY)(A;CI;GA;;;CO)"%16422%,0,"D:P(A;CI;GR;;;BU)(A;CI;GA;;;BA)(A;CI;GA;;;SY)(A;CI;GA;;;CO)"
[TweaksAddReg]
;;;example
[TweaksAddReg]HKLM, "%KEY_SOFTWARE%\ProgramName", "Test", %REG_SZ%, "Test....."HKLM, "Test\Test2", "Test2", %REG_SZ%, "Test2.....";;;see example in [ProcessesToRun*Integration] where RegHive has been loaded in HKLM\Test
[TweaksDelReg]
;;;example
[TweaksDelReg]HKLM, "%KEY_SOFTWARE%\ProgramName"
SourceFiles = Directory where the addon has been extracted
MountDir = Directory where the image has been mounted
Warning: %MountDir% is an optional variable, there's no need for it as MountDir is always DIRID 24 (Root directory of the system disk), so %24%\ is always mount directory destination
[ProcessesToRunBeforeIntegration]
;;;example
[ProcessesToRunBeforeIntegration]reg load HKLM\Test "%Mountdir%\Windows\System32\config\RegHive""%SourceFiles%\ResHacker.exe" -delete "%16422%\Internet Explorer\iexplore.exe", "%16422%\Internet Explorer\iexplore.exe", Icon,,"%SourceFiles%\ResHacker.exe" -addoverwrite "%16422%\Internet Explorer\iexplore.exe", "%16422%\Internet Explorer\iexplore.exe", "%SourceFiles%\Icon.res",,,"%SourceFiles%\ResHacker.exe" -delete "%MountDir%\Program Files\Internet Explorer\iexplore.exe", "%MountDir%\Program Files\Internet Explorer\iexplore.exe", Bitmap,,"%SourceFiles%\ResHacker.exe" -addoverwrite "%MountDir%\Program Files\Internet Explorer\iexplore.exe", "%MountDir%\Program Files\Internet Explorer\iexplore.exe", "%SourceFiles%\Bitmap.res",,,
[ProcessesToRunAfterIntegration]
;;;example
[ProcessesToRunAfterIntegration]reg unload HKLM\Test"%SourceFiles%\ResHacker.exe" -delete "%MountDir%\windows\system32\FileName.exe", "%MountDir%\windows\system32\FileName.exe", Bitmap,,"%SourceFiles%\ResHacker.exe" -addoverwrite "%MountDir%\windows\system32\FileName.exe", "%MountDir%\windows\system32\FileName.exe", "%SourceFiles%\Bitmap.res",,,"%SourceFiles%\ResHacker.exe" -delete "%11%\FileName.exe", "%11%\FileName.exe", Icon,,"%SourceFiles%\ResHacker.exe" -addoverwrite "%11%\FileName.exe", "%11%\FileName.exe", "%SourceFiles%\Icon.res",,,
Warning, these sections do same job of [securityFiles*Integration] sections but in different ways; they've been added for they who find hard to understand microsoft guides about "Security Descriptor Definition Language", so you can use these too; anyway it is suggested to use [securityFiles*Integration] section, safer e also faster
1 = gives Admin permissions for a file or a directory
2 = when destination is a directory, gives Admin permission for all files and subdirectories of specified directory
3 = when destination is a directory, if it doesn't exist will be automatically created
[FilePermissionsBeforeIntegration]
;;;example
[b][FilePermissionsBeforeIntegration][/b]%10%\regedit.exe,1%COMMONPROGRAMFILES%,1%16426%\Filename.exe,1
[FilePermissionsAfterIntegration]
;;;example
[FilePermissionsAfterIntegration]%10%\test.exe,1%PROGRAMFILES(X86)%,1%16428%\Test,3
[AddProgram]
;;;example
[AddProgram]Filerefox.exe;orinstall_flash_player.exe -install -force"SetUp XXX.exe" /S
[string]
;;;example
[Strings]LANGNAME = "English"LANGUAGE = "ENU"MuiCultureDirectory = "en-US"LangIdHex = "409"Lang = "EN"LCID = "0409"UnlockerTip = "Freeware tool to overcome a Windows bug"
;or use multi local
about International INF Files http://msdn.microsof...8(v=VS.85).aspx
[Strings.0409]LANGNAME = "English"LANGUAGE = "ENU"MuiCultureDirectory = "en-US"LangIdHex = "409"Lang = "EN"LCID = "0409"UnlockerTip = "Freeware tool to overcome a Windows bug"[Strings.0410]LANGNAME = "Italiano"LANGUAGE = "ITA"MuiCultureDirectory = "it-IT"LangIdHex = "410"Lang = "IT"LCID = "0410"UnlockerTip = "Strumento freeware per superare un bug di Windows"
DX WinNT6.x True Integrator adds as default these keys in Strings section
REG_SZ = 0x00000000REG_EXPAND_SZ = 0x00020000REG_DWORD = 0x00010001REG_QWORD = 0x000B0001REG_BINARY = 0x00000001REG_MULTI_SZ = 0x00010000REG_NONE = 0x00020001REG_KEYONLY = 0x00000010REG_KEYONLY_COMMON = 0x00002000REG_UNKNOWN = 0x00030001REG_NOCLOBBER = 0x00000002REG_DELVAL = 0x00000004REG_OVERWRITEONLY = 0x00000020REG_APPEND = 0x00000008 ;Append a given value to that of an existing named value entry. This flag is valid only if FLG_ADDREG_TYPE_MULTI_SZ is also set. The specified string value is not appended if it already exists.REG_64BITKEY = 0x00001000REG_32BITKEY = 0x00004000REG_SZ_64BITKEY = 0x00001000REG_SZ_32BITKEY = 0x00004000REG_SZ_NOCLOBBER = 0x00000002REG_SZ_NOCLOBBER_64BITKEY = 0x00001002REG_SZ_NOCLOBBER_32BITKEY = 0x00004002REG_SZ_DELVAL = 0x00000004REG_SZ_DELVAL_64BITKEY = 0x00001004REG_SZ_DELVAL_32BITKEY = 0x00004004REG_SZ_OVERWRITEONLY = 0x00000020REG_SZ_OVERWRITEONLY_64BITKEY = 0x00001020REG_SZ_OVERWRITEONLY_32BITKEY = 0x00004020REG_EXPAND_SZ_64BITKEY = 0x00021000REG_EXPAND_SZ_32BITKEY = 0x00024000REG_EXPAND_SZ_NOCLOBBER = 0x00020002REG_EXPAND_SZ_NOCLOBBER_64BITKEY = 0x00021002REG_EXPAND_SZ_NOCLOBBER_32BITKEY = 0x00024002REG_EXPAND_SZ_DELVAL = 0x00020004REG_EXPAND_SZ_DELVAL_64BITKEY = 0x00021004REG_EXPAND_SZ_DELVAL_32BITKEY = 0x00024004REG_EXPAND_SZ_OVERWRITEONLY = 0x00020020REG_EXPAND_SZ_OVERWRITEONLY_64BITKEY = 0x00021020REG_EXPAND_SZ_OVERWRITEONLY_32BITKEY = 0x00024020REG_DWORD_64BITKEY = 0x00011001REG_DWORD_32BITKEY = 0x00014001REG_DWORD_NOCLOBBER = 0x00010003REG_DWORD_NOCLOBBER_64BITKEY = 0x00011003REG_DWORD_NOCLOBBER_32BITKEY = 0x00014003REG_DWORD_DELVAL = 0x00010005REG_DWORD_DELVAL_64BITKEY = 0x00011005REG_DWORD_DELVAL_32BITKEY = 0x00014005REG_DWORD_OVERWRITEONLY = 0x00010021REG_DWORD_OVERWRITEONLY_64BITKEY = 0x00011021REG_DWORD_OVERWRITEONLY_32BITKEY = 0x00014021REG_QWORD_64BITKEY = 0x000B1001REG_QWORD_32BITKEY = 0x000B4001REG_QWORD_NOCLOBBER = 0x000B0003REG_QWORD_NOCLOBBER_64BITKEY = 0x000B1003REG_QWORD_NOCLOBBER_32BITKEY = 0x000B4003REG_QWORD_DELVAL = 0x000B0005REG_QWORD_DELVAL_64BITKEY = 0x000B1005REG_QWORD_DELVAL_32BITKEY = 0x000B4005REG_QWORD_OVERWRITEONLY = 0x000B0021REG_QWORD_OVERWRITEONLY_64BITKEY = 0x000B1021REG_QWORD_OVERWRITEONLY_32BITKEY = 0x000B4021REG_BINARY_64BITKEY = 0x00001001REG_BINARY_32BITKEY = 0x00004001REG_BINARY_NOCLOBBER = 0x00000003REG_BINARY_NOCLOBBER_64BITKEY = 0x00001003REG_BINARY_NOCLOBBER_32BITKEY = 0x00004003REG_BINARY_DELVAL = 0x00000005REG_BINARY_DELVAL_64BITKEY = 0x00001005REG_BINARY_DELVAL_32BITKEY = 0x00004005REG_BINARY_OVERWRITEONLY = 0x00000021REG_BINARY_OVERWRITEONLY_64BITKEY = 0x00001021REG_BINARY_OVERWRITEONLY_32BITKEY = 0x00004021REG_MULTI_SZ_64BITKEY = 0x00011000REG_MULTI_SZ_32BITKEY = 0x00014000REG_MULTI_SZ_APPEND = 0x00010008REG_MULTI_SZ_APPEND_64BITKEY = 0x00011008REG_MULTI_SZ_APPEND_32BITKEY = 0x00014008REG_MULTI_SZ_NOCLOBBER = 0x00010002REG_MULTI_SZ_NOCLOBBER_64BITKEY = 0x00011002REG_MULTI_SZ_NOCLOBBER_32BITKEY = 0x00014002REG_MULTI_SZ_DELVAL = 0x00010004REG_MULTI_SZ_DELVAL_64BITKEY = 0x00011004REG_MULTI_SZ_DELVAL_32BITKEY = 0x00014004REG_MULTI_SZ_OVERWRITEONLY = 0x00010020REG_MULTI_SZ_OVERWRITEONLY_64BITKEY = 0x00011020REG_MULTI_SZ_OVERWRITEONLY_32BITKEY = 0x00014020REG_NONE_64BITKEY = 0x00021001REG_NONE_32BITKEY = 0x00022001REG_NONE_NOCLOBBER = 0x00020003REG_NONE_NOCLOBBER_64BITKEY = 0x00021003REG_NONE_NOCLOBBER_32BITKEY = 0x00024003REG_NONE_DELVAL = 0x00020005REG_NONE_DELVAL_64BITKEY = 0x00021005REG_NONE_DELVAL_32BITKEY = 0x00024005REG_NONE_OVERWRITEONLY = 0x00020021REG_NONE_OVERWRITEONLY_64BITKEY = 0x00021021REG_NONE_OVERWRITEONLY_32BITKEY = 0x00024021REG_KEYONLY_64BITKEY = 0x00001010REG_KEYONLY_32BITKEY = 0x00004010REG_KEYONLY_NOCLOBBER = 0x00000012REG_KEYONLY_NOCLOBBER_64BITKEY = 0x00001012REG_KEYONLY_NOCLOBBER_32BITKEY = 0x00004012REG_KEYONLY_DELVAL = 0x00000015REG_KEYONLY_DELVAL_64BITKEY = 0x00001015REG_KEYONLY_DELVAL_32BITKEY = 0x00004015REG_KEYONLY_OVERWRITEONLY = 0x00000030REG_KEYONLY_OVERWRITEONLY_64BITKEY = 0x00001030REG_KEYONLY_OVERWRITEONLY_32BITKEY = 0x00004030REG_KEYONLY_COMMON_64BITKEY = 0x00003000REG_KEYONLY_COMMON_32BITKEY = 0x00006000REG_KEYONLY_COMMON_NOCLOBBER = 0x00002002REG_KEYONLY_COMMON_NOCLOBBER_64BITKEY = 0x00003002REG_KEYONLY_COMMON_NOCLOBBER_32BITKEY = 0x00006002REG_KEYONLY_COMMON_DELVAL = 0x00002005REG_KEYONLY_COMMON_DELVAL_64BITKEY = 0x00003005REG_KEYONLY_COMMON_DELVAL_32BITKEY = 0x00006005REG_KEYONLY_COMMON_OVERWRITEONLY = 0x00002020REG_KEYONLY_COMMON_OVERWRITEONLY_64BITKEY = 0x00003020REG_KEYONLY_COMMON_OVERWRITEONLY_32BITKEY = 0x00006020REG_UNKNOWN_64BITKEY = 0x00031001REG_UNKNOWN_32BITKEY = 0x00032001REG_UNKNOWN_NOCLOBBER = 0x00030003REG_UNKNOWN_NOCLOBBER_64BITKEY = 0x00031003REG_UNKNOWN_NOCLOBBER_32BITKEY = 0x00034003REG_UNKNOWN_DELVAL = 0x00030005REG_UNKNOWN_DELVAL_64BITKEY = 0x00031005REG_UNKNOWN_DELVAL_32BITKEY = 0x00034005REG_UNKNOWN_OVERWRITEONLY = 0x00030021REG_UNKNOWN_OVERWRITEONLY_64BITKEY = 0x00031021REG_UNKNOWN_OVERWRITEONLY_32BITKEY = 0x00034021; ServiceType valuesSERVICE_KERNEL_DRIVER = 0x00000001SERVICE_FILE_SYSTEM_DRIVER = 0x00000002SERVICE_ADAPTER = 0x00000004SERVICE_RECOGNIZER_DRIVER = 0x00000008SERVICE_WIN32_OWN_PROCESS = 0x00000010SERVICE_WIN32_SHARE_PROCESS = 0x00000020SERVICE_INTERACTIVE_PROCESS = 0x00000100SERVICE_INTERACTIVE_SHARE_PROCESS = 0x00000120; StartType valuesSERVICE_BOOT_START = 0x00000000SERVICE_SYSTEM_START = 0x00000001SERVICE_AUTO_START = 0x00000002SERVICE_DEMAND_START = 0x00000003SERVICE_DISABLED = 0x00000004; ErrorControl valuesSERVICE_ERROR_IGNORE = 0x00000000SERVICE_ERROR_NORMAL = 0x00000001SERVICE_ERROR_SEVERE = 0x00000002SERVICE_ERROR_CRITICAL = 0x00000003SPSVCINST_TAGTOFRONT = 0x00000001SPSVCINST_ASSOCSERVICE = 0x00000002SPSVCINST_DELETEEVENTLOGENTRY = 0x00000004SPSVCINST_NOCLOBBER_DISPLAYNAME = 0x00000008SPSVCINST_NOCLOBBER_STARTTYPE = 0x00000010SPSVCINST_NOCLOBBER_ERRORCONTROL = 0x00000020SPSVCINST_NOCLOBBER_LOADORDERGROUP = 0x00000040SPSVCINST_NOCLOBBER_DEPENDENCIES = 0x00000080SPSVCINST_NOCLOBBER_DESCRIPTION = 0x00000100COPYFLG_WARN_IF_SKIP = 0x00000001COPYFLG_NOSKIP = 0x00000002COPYFLG_NOVERSIONCHECK = 0x00000004COPYFLG_FORCE_FILE_IN_USE = 0x00000008COPYFLG_NO_OVERWRITE = 0x00000010COPYFLG_NO_VERSION_DIALOG = 0x00000020COPYFLG_OVERWRITE_OLDER_ONLY = 0x00000040COPYFLG_REPLACEONLY = 0x00000400COPYFLG_REPLACE_BOOT_FILE = 0x00001000COPYFLG_NOPRUNE = 0x00002000
this is the integration sequence as executed by DX WinNT6.x True Integrator
1 [FilePermissionsBeforeIntegration]
2 [securityFilesBeforeIntegration]
3 [ProcessesToRunBeforeIntegration]
4 [securityRegistryBeforeIntegration]
5 Offline Install Execution (installs addon AddOn)
6 [TweaksAddReg]
7 [TweaksDelReg]
8 [securityRegistryAfterIntegration]
9 [ProcessesToRunAfterIntegration]
10 [securityFilesBeforeIntegration]
11 [FilePermissionsAfterIntegration]
DX WinNT6.x True Integrator INF file syntax
To create a Multiple Platforms and Operating Systems setup.inf file you can use in your addon inf file these sections:
http://www.wincert.net/forum/index.php?/forum/128-inf-discussion/
http://msdn.microsoft.com/en-us/library/ff548687%28v=VS.85%29.aspx
http://technet.microsoft.com/en-us/library/dd309538.aspx
http://www.ryston.com/x/INF_web/
http://www.osronline.com/ddkx/install/create-inf_4l47.htm
So the inf file of a True AddOn for Windows 2000/XP/2003/Vista/Seven must be as follows:
[color=green][b];section installing Optional Components in 2000/XP/2003[/b][/color]
[Optional Components]
SectionName
[color=green][b];Optional Components section for Windows 2000/XP/2003 in nLite & RVMi[/b][/color]
[SectionName]
[color=green][b];Optional Components section for Windows Vista/Seven in DX WinNT6.x True Integrator[/b][/color]
[SectionName.nt]
In this case Sysoc doesn't read section with ".nt" etc., so you can use directly section name inside inf file to install the component both in Windows 2000/XP/2003 and in Windows Vista/Seven
so if AddOn will be integrated in Windows 2000/XP/2003 with nLite & RVMi, sysoc will install [sectionName] section during windows setup
If AddOn will integrated in Windows Vista/Seven withDXIntegrator instead, then DX WinNT6.x True Integrator will read inf file according to microsoft rules about .inf file, meanging it will start to read sections in this way, first [sectionName.ntx86] or [sectionName.ntamd64]; if not found, then it will search for [sectionName.nt], then [sectionName], so in this case (Windows Vista/Seven) it wil find and install [sectionName.nt]; In this way [sectionName.nt] can be customized for a Windows Vista/Seven installation and [sectionName] for a Windows 2000/XP/2003 installation instead.
Multiple Platforms
For an inf file designed for a Multiple Platforms addon, you need these sections:
[color=green][b];Install component only in x32 systems (x86)[/b][/color]
[SectionName.ntx86]
[color=green][b];Install component only in x64 systems (amd64)[/b][/color]
[SectionName.ntamd64]
In this case DX WinNT6.x True Integrator wil choose which section will install according to choosen OS
Multiple Operating Systems
For an inf file designed for a Multiple Operating Systems AddOn instead, you need these sections (Warning: microsoft doesn't support these options during Defaultinstall; They can be used only if you integrate them with DX WinNT6.x True Integrator. Microsoft supports them in inf file in HW install only http://msdn.microsof...3(v=VS.85).aspx
http://msdn.microsoft.com/en-us/library/ff539924%28v=VS.85%29.aspx
http://msdn.microsoft.com/en-us/library/ff550743%28v=VS.85%29.aspx
6.0 = Vista
6.1 = Windows 7
[color=green][b];Install component only in Windows Vista[/b][/color]
[SectionName.6.0]
[color=green][b];Install component only in Windows 7[/b][/color]
[SectionName.6.1]
Oppure
[SectionName.nt.6.0]
[SectionName.nt.6.1]
;in case of Multiple Platforms
http://msdn.microsof...4(v=VS.85).aspx
[color=green][b];Install component only in Windows Vista x32 (x86)[/b][/color]
[SectionName.ntx86.6.0]
[color=green][b];Install component only in Windows Vista x64 (amd64)[/b][/color]
[SectionName.ntamd64.6.0]
[color=green][b];Install component only in Windows 7 x32 (x86)[/b][/color]
[SectionName.ntx86.6.1]
[color=green][b];Install component only in Windows 7 x64 (amd64)[/b][/color]
[SectionName.ntamd64.6.1]
How to add/delete code in Windows 7 installation
First you must convert .reg file registry lines in INF file lines: for this you need n7Epsilon Reg2Inf tool
Here's is an example of windows 7 tweak reg file:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\PcaSvc]
"Start"=dword:00000004
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\PcaSvc]
Export it with Notepad and send it to Reg2inf and you should get this:
[Version]
Signature="$Windows NT$"
MyRegTweaks
[DefaultInstall]
AddReg =REGEntries.AddReg
DelReg =REGEntries.DelReg
[MyRegTweaks]
OptionDesc ="Registry Entries"
Tip ="Registry Entries"
Modes =0,1,2,3
[REGEntries.AddReg]
; Reg2Inf v0.46 - http://tinyurl.com/fgqyf
HKLM,"SYSTEM\CurrentControlSet\services\PcaSvc","Start",0x10001,04,00,00,00
HKLM,"SYSTEM\ControlSet001\services\PcaSvc","Start",0x10001,04,00,00,00
[REGEntries.DelReg]
You can already directly use this inf file: if you name it Test.inf the entries.ini directive will be:
[color=limegreen];This section contains entries that need to go into the [Components] section of the OCSysPrep.inf file. [/color]
[SysPrepOC]
Test=advpack.dll,LaunchINFSection,Test.inf,MyRegTweaks
[color=blue];for nLite RVMi in case you want to integrate the addon in Windows 2000/XP/2003 too[/color]
[color=limegreen];This section contains entries that need to go into the [Components] section of the Sysoc.inf file.[/color]
[sysoc]
Test = ocgen.dll,OcEntry,Test.inf,HIDE,7
If you want a more professional and/or customized inf file, the only lines needed are the ones under following sections:
REGEntries.AddReg and REGEntries.DelReg; got them and create an inf file compatible with both nLite/RVMi in Windows 2000/XP/2003 and DX WinNT6.x Integrator in Windows Vista/Seven: see more here (italian): http://www.eng2ita.net/forum/index.php/topic,7071.0.html
Here is a real example on how will must be your inf file in this case:
[Version] - http://msdn.microsoft.com/en-us/library/ff547502%28v=VS.85%29.aspx
in a normal inf file you need only signature directive under this section:
[Version]
signature="$Windows NT$"
[color=green]; or signature="$Chicago$"[/color]
Also these directives are default in the inf file structure, so they read and used by DX WinNT6.x Integrator too to take out info, etc.:
DriverVer=11/14/2010, %DSCP_ProductVersion%
Provider=Microsoft
These directives:
Customizedby=Berserk - DMD
PackageDisplayName=%ProductName%
PackageReleaseType=True AddOn
PackageLanguage=%LANGNAME%
PackageDescription=%DSCPTip%
are optionals instead. They are read by DX WinNT6.x Integrator only, in general they're not mandatory because when DX WinNT6.x Integrator integrates an addon it reads entries.ini file and it writes them by itself if they're are missing.
[Optional Components], is the section read by SYSOC in Windows 2000/XP/2003 during Windows setup to install optional components. You can write here from one to more section name to install, in this example DSCP onlyDSCP
DSCP
[DSCP] is the section indicated by Optional Components section, so this is the one that SYSOC will install in Windows 2000/XP/2003 Setup
Following directive are SYSOC defaults: this means, for example, that if Modes is missing so SYSOC don't installs this section in Windows Setup
OptionDesc ="%ProductName%"
Tip ="%DSCPTip%"
Modes = 0,1,2,3
About AddReg: http://msdn.microsoft.com/en-us/library/ff546320%28v=VS.85%29.aspx
AddReg = DSCP.Reg.Add.Values, DSCP.Add.Reg.ARP
This directive can be used in every kind of inf file both from SetupAPI and Advpack etc., in this case it is used to install or add our regentries in system (in the example TWEAK doesn't consider regentries deletion so DelReg is not used)
[DSCP.nt] is the section read and prepared for Windows Vista/Seven Setup by DX WinNT6.x Integrator in this case
BackupReg = DSCP.Reg.Restore.Values
BackupReg is a directive used in advanced INF options (when LaunchINFSectionEx is used: http://www.mdgx.com/INF_web/backup.htm). Now with DX WinNT6.x Integrator you can run it also from SetupApi or LaunchINFSection. In DX WinNT6.x Integrator this directive has same purpose: it saves the reg before installation and then restores it during Remove or Uninstall. The only difference in this case is that DX WinNT6.x Integrator backs up the reg in the same inf file, very useful in our case because reg rollback can be restored both in offline mode when DX WinNT6.x Integrator runs and in Online mode, for example when you want to unistall an addon from the Control Panel. The rollback section name is the same but with ".RollBack" at its end, for example the reg to be saved in DSCP.Reg.Backup section will be written by DX WinNT6.x Integrator lin DSCP.Reg.Backup.RollBack section (In this case it's not present because DSCP.Reg.Backup.RollBack will be created by DX WinNT6.x Integrator when the addon is installed in Offline Mode)
[DSCP.PerUser] is an optional section: Sometimes regentries are not added in a correct way or Windows setup overwrites them so better add it always after setup using peruserinstall. Peruserinstall run always before first desktop in Windows setup, after Runonce and RunonceEx, this means it is the latest configuration of system.
In this example is not needed but it is here to give you an example, to enable it you only need to add ".PerUser" in entries.ini section name like this:
[SysPrepOC]
DSCP=advpack.dll,LaunchINFSection,DSCP.inf,DSCP.PerUser
[DestinationDirs] - http://msdn.microsoft.com/en-us/library/ff547383%28v=VS.85%29.aspx
[DestinationDirs]
DefaultDestDir = 17
in this section you need to indicate directory destinations where to copy/delete/rename/etc. files. In the example is added to use "DefaultDestDir" directive, and it shows where to copy inf file inf
[DSCP.Reg.Add.Values] is the section shown in AddReg directive under "DSCP" and "DSCP.nt" sections (as always this regline works with both Windows XP and Windows 7)
[color=limegreen]; Disables Program Compatibility Service[/color]
[DSCP.Add.Reg.ARP] is the section shown in AddReg directive under "DSCP" and "DSCP.nt" sections: these regentries adds removal option in Control Panel
[DSCP.Add.Reg.ARP]
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","DisplayIcon", ,"%10%\regedit.exe"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","DisplayName", ,"%ProductName% %DSCP_ProductVersion%"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","DisplayVersion", ,"%DSCP_ProductVersion%"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","OnlineVersion", ,"%DSCP_ProductVersion%"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","Publisher", ,"DMD"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","UninstallString", ,"rundll32.exe advpack.dll,LaunchINFSection %17%\DSCP.inf,DefaultUninstall"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","URLInfoAbout", ,"http://www.eng2ita.net/forum/index.php/topic,6164.0.html"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","ParentKeyName", ,"OperatingSystem"
HKLM,"%KEY_WIN_CURVER%\Uninstall\DSCP","ParentDisplayName", ,"%PARENT_DISPLAY_NAME%"
[PerUserInst] is the section shown in PerUserInstall directive under "DSCP.PerUser" section
[PerUserInst]
Version=1.0.0000.0
IsInstalled=1
ComponentID=DSCP
GUID={x0020200-ecbd-11cf-8b85-00aa0050dscp}
Locale=en
StubPath=rundll32.exe advpack.dll,LaunchINFSection %17%\DSCP.inf,PerUser.Install,1,N
StubPath directive shows the directive to run: in the example it runs the directive which installs "PerUser.Install" section
[PerUser.Install] is the section to be installed in PerUser Mode in StubPath directive under "PerUserInst" section
[PerUser.Install]
DelReg = PerUser.CleanUp
[PerUser.CleanUp] is the section indicated in DelReg directive under "PerUser.Install" section
[PerUser.CleanUp]
HKCU,"Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
HKLM,"Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
HKU,".DEFAULT\Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
HKU,"S-1-5-18\Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
HKU,"S-1-5-19\Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
HKU,"S-1-5-20\Software\Microsoft\Active Setup\Installed Components\>{x0020200-ecbd-11cf-8b85-00aa0050dscp}"
this will remove all regentries used in peruser mode: better do this as peruser mode has been used only to execute a single directive and nothing else but generally you can also not remove these lines, so everytime you add a new user account, with new configurations "rundll32.exe advpack.dll,LaunchINFSection %17%\DSCP.inf,PerUser.Install" will start again.
Warning: this is valid with DX WinNT6.x Integrator in Windows Vista/Seven only: in Windows 2000/XP/2003 nLite/RVMi won't work because SYSOC doesn't recognize PerUserInstall directive. In Windows 2000/XP/2003 you must use a different way (see inside Onepiece's IE7/8 addon)
[DefaultUninstall] is the section indicated in "DSCP.Add.Reg.ARP" section, in other word the section executed when Control Panel uninstall is chosen
[DefaultUninstall]
BeginPrompt = BeginUnInsPrompt
AddReg = DSCP.Reg.Backup.RollBack
DelReg = DSCP.Add.Reg.ARP
UpdateInis = DSCP.OCSysPrep.CleanUp
EndPrompt = EndUnInsPrompt
CleanUp = 1
[DSCP.OCSysPrep.CleanUp] is the section indicated in UpdateInis directive under "DefaultUninstall" section
%17%\OCSysPrep.inf,Components,DSCP=*
This section removes the component from [Components] section in %WinDir%\inf\OCSysPrep.inf (as SYSOC does in Windows 2000/XP/2003)
[beginUnInsPrompt] is the section indicated in BeginPrompt directive under "DefaultUninstall" section
[BeginUnInsPrompt]
Title = %ProductName% Uninstaller
Prompt = %UnInsPrompt%
ButtonType = YESNO ;<- YESNO or OKCANC
This opens a windows before removal starts, prompting if you want to proceed or not: if you click on YES removal starts, if you click on NO removal is aborted.
[EndUnInsPrompt] is the section indicated in EndPrompt directive under "DefaultUninstall" section
[EndUnInsPrompt]
Prompt = %EndUnInsPrompt%
This opens a windows at the end of removal process, informing if removal has been successful or not, etc.
[DefaultInstall] is the section which starts when installation is manually run clicking on inf file.
[DefaultInstall]
BeginPrompt = BeginInstPrompt
CopyFiles = @DSCP.inf
UpdateInis = Update.Sysoc
EndPrompt = EndInstPrompt
About directive CopyFiles http://msdn.microsoft.com/en-us/library/ff546346%28v=VS.85%29.aspx
Warning! According to inf file rules, if no section name has been indicated in installation directive, DX WinNT6.x Integrator always search for DefaultInstall section, and if found customizes and installs it, for example if in entries.ini you use these lines
[SysPrepOC]
then DX WinNT6.x Integrator search inside DSCP.inf file DefaultInstall section and customizes and installs it
[update.Sysoc] is the section indicated in UpdateInis directive under "DefaultInstall" section
[Update.Sysoc]
%17%\OCSysPrep.inf,"Components",,"DSCP=advpack.dll,LaunchINFSection,DSCP.inf,DSCP"
This section adds the component in [Components] section in %WinDir%\inf\OCSysPrep.inf (as SYSOC does in Windows 2000/XP/2003)
[beginInstPrompt] is the section indicated in BeginPrompt directive under "DefaultInstall" section
[BeginInstPrompt]
Prompt = %InstPrompt%
This opens a windows before installation starts, prompting if you want to proceed or not: if you click on YES installation starts, if you click on NO installation is aborted.
[EndInstPrompt] is the section indicated in EndPrompt directive under "DefaultInstall" section
[EndInstPrompt]
Prompt = %EndInstPrompt%
This opens a windows at the end of installation process, informing if installation has been successful or not, etc.
[strings] - http://msdn.microsoft.com/en-us/library/ff547485%28v=VS.85%29.aspx
is the section where you can place the variables used in your inf file
These are the main options but inf file have endless possibilities. For further information follow Microsoft Guides
INF Sections - http://msdn.microsoft.com/en-us/library/ff547465%28v=VS.85%29.aspx
INF directives - http://msdn.microsoft.com/en-us/library/ff547388%28v=VS.85%29.aspx
Adding an entries.ini file created as usual, now you can create with your inf file a .cab Addon using CabTool http://www.eng2ita.net/forum/index.php/topic,6628.0.htm
Here is a windows 7 registry tweaks collection http://www.eng2ita.net/forum/index.php/topic,6164.0.html (italian)
and here are some sample addon (italian):
DMD Windows 7 RegTweaks collection True AddOn
tabdownload.png Update (March 23-2011)
Hash MD5 F103C39522A8D64A29E8F5603AFE5210
Filesize: 6.77 KB (6942 bytes)
DMD .mkv view in MediaCenter True AddOn
Hash MD5 ECF5893C528E3093857CCDF393F26554
Filesize: 4.00 KB (4102 bytes)
DMD Copy/Move directives True AddOn
Hash MD5 859956469C3C264698AD2E2FDC668EBD
Filesize: 3.07 KB (3144 bytes)
DMD fast menu opening True AddOn
Hash MD5 5F60D1A500C7D87709EC2CF14D2BB477
Filesize: 2.89 KB (2964 bytes)
DMD Recycle bin in Windows Explorer True AddOn
Hash MD5 FD20BEBC067AB9A15BB999BCA9A6EA3F
Filesize: 2.98 KB (3058 bytes)
DMD disable Program Compatibility service True AddOn
Hash MD5 38AC0AD68FE1A029FF8B4C79750F56C6
Filesize: 2.93 KB (3002 bytes)
DMD set UAC values True AddOn
Hash MD5 740D25D741A25A0B7AA1FEF2405BA169
Filesize: 3.25 KB (3330 bytes)
Dirids - Part 1
1 = %USERPROFILE%\Desktop\ect ect
10 = %SystemRoot%
11 = %SystemRoot%\system32
12 = %SystemRoot%\system32\DRIVERS
17 = %SystemRoot%\INF
18 = %SystemRoot%\help
20 = %SystemRoot%\fonts
21 = %SystemRoot%\system32\viewers
23 = %SystemRoot%\system32\spool\drivers\color
24 = %SystemDrive%
25 = %SystemRoot%
30 = %SystemDrive%
50 = %SystemRoot%\SYSTEM
51 = %SystemRoot%\system32\spool
52 = %SystemRoot%\system32\spool\DRIVERS\W32X86 %SystemRoot%\system32\spool\DRIVERS\x64
53 = %USERPROFILE%
54 = %SystemDrive%
55 = %SystemRoot%\system32\spool\PRTPROCS\W32X86 %SystemRoot%\system32\spool\PRTPROCS\x64
16384 = %USERPROFILE%\Desktop
16386 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
16389 = %USERPROFILE%\Documents
16390 = %USERPROFILE%\Favorites
16391 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
16392 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
16393 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
16395 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
16397 = %USERPROFILE%\Music
16398 = %USERPROFILE%\Videos
16400 = %USERPROFILE%\Desktop
16403 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
16404 = %SystemRoot%\Fonts
16405 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
16406 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
16407 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
16408 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
16409 = %AllUsersProfile%\Public\Desktop
16410 = %USERPROFILE%\AppData\Roaming
16411 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
16412 = %USERPROFILE%\AppData\Local
16413 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
16414 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
16415 = %USERPROFILE%\Favorites
16416 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
16417 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
16418 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
16419 = %PROGRAMDATA%
16420 = %SystemRoot%
16421 = %SystemRoot%\system32
16422 = %PROGRAMFILES%
16423 = %USERPROFILE%\Pictures
16424 = %USERPROFILE%
16425 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
16426 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
16427 = %COMMONPROGRAMFILES%
16428 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
16429 = %PROGRAMDATA%\Microsoft\Windows\Templates
16430 = %AllUsersProfile%\Public\Documents
16431 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16432 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16437 = %AllUsersProfile%\Public\Music
16438 = %AllUsersProfile%\Public\Pictures
16439 = %AllUsersProfile%\Public\Videos
16440 = %SystemRoot%\resources
16441 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
16442 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
16443 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
16640 = %USERPROFILE%\Desktop
16642 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
16645 = %USERPROFILE%\Documents
16646 = %USERPROFILE%\Favorites
16647 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
16648 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
16649 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
16651 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
16653 = %USERPROFILE%\Music
16654 = %USERPROFILE%\Videos
16656 = %USERPROFILE%\Desktop
16659 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
16660 = %SystemRoot%\Fonts
16661 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
16662 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
16663 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
16664 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
16665 = %AllUsersProfile%\Public\Desktop
16666 = %USERPROFILE%\AppData\Roaming
16667 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
16668 = %USERPROFILE%\AppData\Local
16669 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
16670 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
16671 = %USERPROFILE%\Favorites
16672 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
16673 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
16674 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
16675 = %PROGRAMDATA%
16676 = %SystemRoot%
16677 = %SystemRoot%\system32
16678 = %PROGRAMFILES%
16679 = %USERPROFILE%\Pictures
16680 = %USERPROFILE%
16681 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
16682 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
16683 = %COMMONPROGRAMFILES%
16684 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
16685 = %PROGRAMDATA%\Microsoft\Windows\Templates
16686 = %AllUsersProfile%\Public\Documents
16687 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16688 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16693 = %AllUsersProfile%\Public\Music
16694 = %AllUsersProfile%\Public\Pictures
16695 = %AllUsersProfile%\Public\Videos
16696 = %SystemRoot%\resources
16697 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
16698 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
16699 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
16896 = %USERPROFILE%\Desktop
16898 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
16901 = %USERPROFILE%\Documents
16902 = %USERPROFILE%\Favorites
16903 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
16904 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
16905 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
16907 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
16909 = %USERPROFILE%\Music
16910 = %USERPROFILE%\Videos
16912 = %USERPROFILE%\Desktop
16915 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
16916 = %SystemRoot%\Fonts
16917 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
16918 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
16919 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
16920 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
16921 = %AllUsersProfile%\Public\Desktop
16922 = %USERPROFILE%\AppData\Roaming
16923 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
16924 = %USERPROFILE%\AppData\Local
16925 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
16926 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
16927 = %USERPROFILE%\Favorites
16928 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
16929 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
16930 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
16931 = %PROGRAMDATA%
16932 = %SystemRoot%
16933 = %SystemRoot%\system32
16934 = %PROGRAMFILES%
16935 = %USERPROFILE%\Pictures
16936 = %USERPROFILE%
16937 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
16938 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
16939 = %COMMONPROGRAMFILES%
16940 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
16941 = %PROGRAMDATA%\Microsoft\Windows\Templates
16942 = %AllUsersProfile%\Public\Documents
16943 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16944 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
16949 = %AllUsersProfile%\Public\Music
16950 = %AllUsersProfile%\Public\Pictures
16951 = %AllUsersProfile%\Public\Videos
16952 = %SystemRoot%\resources
16953 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
16954 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
16955 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
17152 = %USERPROFILE%\Desktop
17154 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
17157 = %USERPROFILE%\Documents
17158 = %USERPROFILE%\Favorites
17159 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
17160 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
17161 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
17163 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
17165 = %USERPROFILE%\Music
17166 = %USERPROFILE%\Videos
17168 = %USERPROFILE%\Desktop
17171 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
17172 = %SystemRoot%\Fonts
17173 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
17174 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
17175 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
17176 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
17177 = %AllUsersProfile%\Public\Desktop
17178 = %USERPROFILE%\AppData\Roaming
17179 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
17180 = %USERPROFILE%\AppData\Local
17181 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17182 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17183 = %USERPROFILE%\Favorites
17184 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
17185 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
17186 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
17187 = %PROGRAMDATA%
17188 = %SystemRoot%
17189 = %SystemRoot%\system32
17190 = %PROGRAMFILES%
17191 = %USERPROFILE%\Pictures
17192 = %USERPROFILE%
17193 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
17194 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
17195 = %COMMONPROGRAMFILES%
17196 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
17197 = %PROGRAMDATA%\Microsoft\Windows\Templates
17198 = %AllUsersProfile%\Public\Documents
17199 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17200 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17205 = %AllUsersProfile%\Public\Music
17206 = %AllUsersProfile%\Public\Pictures
17207 = %AllUsersProfile%\Public\Videos
17208 = %SystemRoot%\resources
17209 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
17210 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
17211 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
17408 = %USERPROFILE%\Desktop
17410 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
17413 = %USERPROFILE%\Documents
17414 = %USERPROFILE%\Favorites
17415 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
17416 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
17417 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
17419 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
17421 = %USERPROFILE%\Music
17422 = %USERPROFILE%\Videos
17424 = %USERPROFILE%\Desktop
17427 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
17428 = %SystemRoot%\Fonts
17429 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
17430 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
17431 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
17432 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
17433 = %AllUsersProfile%\Public\Desktop
17434 = %USERPROFILE%\AppData\Roaming
17435 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
17436 = %USERPROFILE%\AppData\Local
17437 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17438 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17439 = %USERPROFILE%\Favorites
17440 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
17441 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
17442 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
17443 = %PROGRAMDATA%
17444 = %SystemRoot%
17445 = %SystemRoot%\system32
17446 = %PROGRAMFILES%
17447 = %USERPROFILE%\Pictures
17448 = %USERPROFILE%
17449 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
17450 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
17451 = %COMMONPROGRAMFILES%
17452 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
17453 = %PROGRAMDATA%\Microsoft\Windows\Templates
17454 = %AllUsersProfile%\Public\Documents
17455 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17456 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17461 = %AllUsersProfile%\Public\Music
17462 = %AllUsersProfile%\Public\Pictures
17463 = %AllUsersProfile%\Public\Videos
17464 = %SystemRoot%\resources
17465 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
17466 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
17467 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
17664 = %USERPROFILE%\Desktop
17666 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
17669 = %USERPROFILE%\Documents
17670 = %USERPROFILE%\Favorites
17671 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
17672 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
17673 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
17675 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
17677 = %USERPROFILE%\Music
17678 = %USERPROFILE%\Videos
17680 = %USERPROFILE%\Desktop
17683 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
17684 = %SystemRoot%\Fonts
17685 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
17686 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
17687 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
17688 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
17689 = %AllUsersProfile%\Public\Desktop
17690 = %USERPROFILE%\AppData\Roaming
17691 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
17692 = %USERPROFILE%\AppData\Local
17693 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17694 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17695 = %USERPROFILE%\Favorites
17696 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
17697 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
17698 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
17699 = %PROGRAMDATA%
17700 = %SystemRoot%
17701 = %SystemRoot%\system32
17702 = %PROGRAMFILES%
17703 = %USERPROFILE%\Pictures
17704 = %USERPROFILE%
17705 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
17706 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
17707 = %COMMONPROGRAMFILES%
17708 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
17709 = %PROGRAMDATA%\Microsoft\Windows\Templates
17710 = %AllUsersProfile%\Public\Documents
17711 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17712 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17717 = %AllUsersProfile%\Public\Music
17718 = %AllUsersProfile%\Public\Pictures
17719 = %AllUsersProfile%\Public\Videos
17720 = %SystemRoot%\resources
17721 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
17722 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
17723 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
17920 = %USERPROFILE%\Desktop
17922 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
17925 = %USERPROFILE%\Documents
17926 = %USERPROFILE%\Favorites
17927 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
17928 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
17929 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
17931 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
17933 = %USERPROFILE%\Music
17934 = %USERPROFILE%\Videos
17936 = %USERPROFILE%\Desktop
17939 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
17940 = %SystemRoot%\Fonts
17941 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
17942 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
17943 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
17944 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
17945 = %AllUsersProfile%\Public\Desktop
17946 = %USERPROFILE%\AppData\Roaming
17947 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
17948 = %USERPROFILE%\AppData\Local
17949 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17950 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
17951 = %USERPROFILE%\Favorites
17952 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
17953 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
17954 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
17955 = %PROGRAMDATA%
17956 = %SystemRoot%
17957 = %SystemRoot%\system32
17958 = %PROGRAMFILES%
17959 = %USERPROFILE%\Pictures
17960 = %USERPROFILE%
17961 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
17962 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
17963 = %COMMONPROGRAMFILES%
17964 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
17965 = %PROGRAMDATA%\Microsoft\Windows\Templates
17966 = %AllUsersProfile%\Public\Documents
17967 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17968 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
17973 = %AllUsersProfile%\Public\Music
17974 = %AllUsersProfile%\Public\Pictures
17975 = %AllUsersProfile%\Public\Videos
17976 = %SystemRoot%\resources
17977 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
17978 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
17979 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
18176 = %USERPROFILE%\Desktop
18178 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
18181 = %USERPROFILE%\Documents
18182 = %USERPROFILE%\Favorites
18183 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
18184 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
18185 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
18187 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
18189 = %USERPROFILE%\Music
18190 = %USERPROFILE%\Videos
18192 = %USERPROFILE%\Desktop
18195 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
18196 = %SystemRoot%\Fonts
18197 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
18198 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
18199 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
18200 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
18201 = %AllUsersProfile%\Public\Desktop
18202 = %USERPROFILE%\AppData\Roaming
18203 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
18204 = %USERPROFILE%\AppData\Local
18205 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
18206 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
18207 = %USERPROFILE%\Favorites
18208 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
18209 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
18210 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
18211 = %PROGRAMDATA%
18212 = %SystemRoot%
18213 = %SystemRoot%\system32
18214 = %PROGRAMFILES%
18215 = %USERPROFILE%\Pictures
18216 = %USERPROFILE%
18217 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
18218 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
18219 = %COMMONPROGRAMFILES%
18220 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
18221 = %PROGRAMDATA%\Microsoft\Windows\Templates
18222 = %AllUsersProfile%\Public\Documents
18223 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
18224 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
18229 = %AllUsersProfile%\Public\Music
18230 = %AllUsersProfile%\Public\Pictures
18231 = %AllUsersProfile%\Public\Videos
18232 = %SystemRoot%\resources
18233 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
18234 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
18235 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
18432 = %USERPROFILE%\Desktop
18434 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
18437 = %USERPROFILE%\Documents
18438 = %USERPROFILE%\Favorites
18439 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
18440 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
18441 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
18443 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
18445 = %USERPROFILE%\Music
18446 = %USERPROFILE%\Videos
18448 = %USERPROFILE%\Desktop
18451 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
18452 = %SystemRoot%\Fonts
18453 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
18454 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
18455 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
18456 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
18457 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
18458 = %USERPROFILE%\AppData\Roaming
18459 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
18460 = %USERPROFILE%\AppData\Local
18461 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
18462 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
18463 = %USERPROFILE%\Favorites
18464 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
18465 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
18466 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
18467 = %PROGRAMDATA%
18468 = %SystemRoot%
18469 = %SystemRoot%\system32
18470 = %PROGRAMFILES% ---> does not work = Win7_x64
18471 = %USERPROFILE%\Pictures
18472 = %USERPROFILE%
18473 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
18475 = %COMMONPROGRAMFILES%
18476 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
18477 = %PROGRAMDATA%\Microsoft\Windows\Templates
18478 = %AllUsersProfile%\Public\Documents
18479 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
18480 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
18485 = %AllUsersProfile%\Public\Music
18486 = %AllUsersProfile%\Public\Pictures
18487 = %AllUsersProfile%\Public\Videos
18488 = %SystemRoot%\resources
18489 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
18490 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
18491 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
18688 = %USERPROFILE%\Desktop
18690 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
18693 = %USERPROFILE%\Documents
18694 = %USERPROFILE%\Favorites
18695 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
18696 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
18697 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
18699 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
18701 = %USERPROFILE%\Music
18702 = %USERPROFILE%\Videos
18704 = %USERPROFILE%\Desktop
18707 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
18708 = %SystemRoot%\Fonts
18709 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
18710 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
18711 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
18712 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
18713 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
18714 = %USERPROFILE%\AppData\Roaming
18715 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
18716 = %USERPROFILE%\AppData\Local
18717 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
18718 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64 ---> does not work = WinXP_x64;WinXP_x32
18719 = %USERPROFILE%\Favorites
18720 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
18721 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
18722 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
18723 = %PROGRAMDATA%
18724 = %SystemRoot%
18725 = %SystemRoot%\system32
18726 = %PROGRAMFILES% ---> does not work = Win7_x64
18727 = %USERPROFILE%\Pictures
18728 = %USERPROFILE%
18729 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
18731 = %COMMONPROGRAMFILES%
18732 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
18733 = %PROGRAMDATA%\Microsoft\Windows\Templates
18734 = %AllUsersProfile%\Public\Documents
18735 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
18736 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
18741 = %AllUsersProfile%\Public\Music
18742 = %AllUsersProfile%\Public\Pictures
18743 = %AllUsersProfile%\Public\Videos
18744 = %SystemRoot%\resources
18745 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
18746 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
18747 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
18944 = %USERPROFILE%\Desktop
18946 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
18949 = %USERPROFILE%\Documents
18950 = %USERPROFILE%\Favorites
18951 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
18952 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
18953 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
18955 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
18957 = %USERPROFILE%\Music
18958 = %USERPROFILE%\Videos
18960 = %USERPROFILE%\Desktop
18963 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
18964 = %SystemRoot%\Fonts
18965 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
18966 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
18967 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
18968 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
18969 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
18970 = %USERPROFILE%\AppData\Roaming
18971 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
18972 = %USERPROFILE%\AppData\Local
18973 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
18974 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
18975 = %USERPROFILE%\Favorites
18976 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
18977 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
18978 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
18979 = %PROGRAMDATA%
18980 = %SystemRoot%
18981 = %SystemRoot%\system32
18982 = %PROGRAMFILES% ---> does not work = Win7_x64
18983 = %USERPROFILE%\Pictures
18984 = %USERPROFILE%
18985 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
18986 = %PROGRAMFILES(X86)% ;NOT work in WIn7 anche WInxp x32
18987 = %COMMONPROGRAMFILES%
18988 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
18989 = %PROGRAMDATA%\Microsoft\Windows\Templates
18990 = %AllUsersProfile%\Public\Documents
18991 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
18992 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
18997 = %AllUsersProfile%\Public\Music
18998 = %AllUsersProfile%\Public\Pictures
18999 = %AllUsersProfile%\Public\Videos
19000 = %SystemRoot%\resources
19001 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
19002 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
19003 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
19200 = %USERPROFILE%\Desktop
19202 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
19205 = %USERPROFILE%\Documents
19206 = %USERPROFILE%\Favorites
19207 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
19208 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
19209 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
19211 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
19213 = %USERPROFILE%\Music
19214 = %USERPROFILE%\Videos
19216 = %USERPROFILE%\Desktop
19219 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
19220 = %SystemRoot%\Fonts
19221 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
19222 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
19223 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
19224 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
19225 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
19226 = %USERPROFILE%\AppData\Roaming
19227 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
19228 = %USERPROFILE%\AppData\Local
19229 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
19230 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
19231 = %USERPROFILE%\Favorites
19232 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
19233 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
19234 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
19235 = %PROGRAMDATA%
19236 = %SystemRoot%
19237 = %SystemRoot%\system32
19238 = %PROGRAMFILES% ---> does not work = Win7_x64
19239 = %USERPROFILE%\Pictures
19240 = %USERPROFILE%
19241 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
19242 = %PROGRAMFILES(X86)% ;NOT Win7 and winxp x32
19243 = %COMMONPROGRAMFILES%
19244 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
19245 = %PROGRAMDATA%\Microsoft\Windows\Templates
19246 = %AllUsersProfile%\Public\Documents
19247 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
19248 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
19253 = %AllUsersProfile%\Public\Music
19254 = %AllUsersProfile%\Public\Pictures
19255 = %AllUsersProfile%\Public\Videos
19256 = %SystemRoot%\resources
19257 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
19258 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
19259 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
19456 = %USERPROFILE%\Desktop
19458 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
19461 = %USERPROFILE%\Documents
19462 = %USERPROFILE%\Favorites
19463 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
19464 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
19465 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
19467 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
19469 = %USERPROFILE%\Music
19470 = %USERPROFILE%\Videos
19472 = %USERPROFILE%\Desktop
19475 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
19476 = %SystemRoot%\Fonts
19477 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
19478 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
19479 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
19480 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
19481 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
19482 = %USERPROFILE%\AppData\Roaming
19483 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
19484 = %USERPROFILE%\AppData\Local
19485 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
19486 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
19487 = %USERPROFILE%\Favorites
19488 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
19489 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
19490 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
19491 = %PROGRAMDATA%
19492 = %SystemRoot%
19493 = %SystemRoot%\system32
19494 = %PROGRAMFILES% ---> does not work = Win7_x64
19495 = %USERPROFILE%\Pictures
19496 = %USERPROFILE%
19497 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
19498 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
19499 = %COMMONPROGRAMFILES%
19500 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
19501 = %PROGRAMDATA%\Microsoft\Windows\Templates
19502 = %AllUsersProfile%\Public\Documents
19503 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
19504 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
19509 = %AllUsersProfile%\Public\Music
19510 = %AllUsersProfile%\Public\Pictures
19511 = %AllUsersProfile%\Public\Videos
19512 = %SystemRoot%\resources
19513 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
19514 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
19515 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
19712 = %USERPROFILE%\Desktop
19714 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
19717 = %USERPROFILE%\Documents
19718 = %USERPROFILE%\Favorites
19719 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
19720 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
19721 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
19723 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
19725 = %USERPROFILE%\Music
19726 = %USERPROFILE%\Videos
19728 = %USERPROFILE%\Desktop
19731 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
19732 = %SystemRoot%\Fonts
19733 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
19734 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
19735 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
19736 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
19737 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
19738 = %USERPROFILE%\AppData\Roaming
19739 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
19740 = %USERPROFILE%\AppData\Local
19741 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
19742 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
19743 = %USERPROFILE%\Favorites
19744 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
19745 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
19746 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
19747 = %PROGRAMDATA%
19748 = %SystemRoot%
19749 = %SystemRoot%\system32
19750 = %PROGRAMFILES% ---> does not work = Win7_x64
19751 = %USERPROFILE%\Pictures
19752 = %USERPROFILE%
19753 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
19754 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
19755 = %COMMONPROGRAMFILES%
19756 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
19757 = %PROGRAMDATA%\Microsoft\Windows\Templates
19758 = %AllUsersProfile%\Public\Documents
19759 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
19760 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
19765 = %AllUsersProfile%\Public\Music
19766 = %AllUsersProfile%\Public\Pictures
19767 = %AllUsersProfile%\Public\Videos
19768 = %SystemRoot%\resources
19769 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
19770 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
19771 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
19968 = %USERPROFILE%\Desktop
19970 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
19973 = %USERPROFILE%\Documents
19974 = %USERPROFILE%\Favorites
19975 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
19976 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
19977 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
19979 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
19981 = %USERPROFILE%\Music
19982 = %USERPROFILE%\Videos
19984 = %USERPROFILE%\Desktop
19987 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
19988 = %SystemRoot%\Fonts
19989 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
19990 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
19991 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
19992 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
19993 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
19994 = %USERPROFILE%\AppData\Roaming
19995 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
19996 = %USERPROFILE%\AppData\Local
19997 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
19998 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
19999 = %USERPROFILE%\Favorites
20000 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
20001 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
20002 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
20003 = %PROGRAMDATA%
20004 = %SystemRoot%
20005 = %SystemRoot%\system32
20006 = %PROGRAMFILES% ---> does not work = Win7_x64
20007 = %USERPROFILE%\Pictures
20008 = %USERPROFILE%
20009 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
20010 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
20011 = %COMMONPROGRAMFILES%
20012 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
20013 = %PROGRAMDATA%\Microsoft\Windows\Templates
20014 = %AllUsersProfile%\Public\Documents
20015 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20016 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20021 = %AllUsersProfile%\Public\Music
20022 = %AllUsersProfile%\Public\Pictures
20023 = %AllUsersProfile%\Public\Videos
20024 = %SystemRoot%\resources
20025 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
20026 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
20027 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
20224 = %USERPROFILE%\Desktop
20226 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
20229 = %USERPROFILE%\Documents
20230 = %USERPROFILE%\Favorites
20231 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
20232 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
20233 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
20235 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
20237 = %USERPROFILE%\Music
20238 = %USERPROFILE%\Videos
20240 = %USERPROFILE%\Desktop
20243 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
20244 = %SystemRoot%\Fonts
20245 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
20246 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
20247 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
20248 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
20249 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
20250 = %USERPROFILE%\AppData\Roaming
20251 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
20252 = %USERPROFILE%\AppData\Local
20253 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
20254 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
20255 = %USERPROFILE%\Favorites
20256 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
20257 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
20258 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
20259 = %PROGRAMDATA%
20260 = %SystemRoot%
20261 = %SystemRoot%\system32
20262 = %PROGRAMFILES% ---> does not work = Win7_x64
20263 = %USERPROFILE%\Pictures
20264 = %USERPROFILE%
20265 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
20267 = %COMMONPROGRAMFILES%
20268 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
20269 = %PROGRAMDATA%\Microsoft\Windows\Templates
20270 = %AllUsersProfile%\Public\Documents
20271 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
20272 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20277 = %AllUsersProfile%\Public\Music
20278 = %AllUsersProfile%\Public\Pictures
20279 = %AllUsersProfile%\Public\Videos
20280 = %SystemRoot%\resources
20281 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
20282 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
20283 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
20480 = %USERPROFILE%\Desktop
20482 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
20485 = %USERPROFILE%\Documents
20486 = %USERPROFILE%\Favorites
20487 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
20488 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
20489 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
20491 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
20493 = %USERPROFILE%\Music
20494 = %USERPROFILE%\Videos
20496 = %USERPROFILE%\Desktop
20499 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
20500 = %SystemRoot%\Fonts
20501 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
20502 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
20503 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
20504 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
20505 = %AllUsersProfile%\Public\Desktop
20506 = %USERPROFILE%\AppData\Roaming
20507 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
20508 = %USERPROFILE%\AppData\Local
20509 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
20510 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
20511 = %USERPROFILE%\Favorites
20512 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
20513 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
20514 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
20515 = %PROGRAMDATA%
20516 = %SystemRoot%
20517 = %SystemRoot%\system32
20518 = %PROGRAMFILES%
20519 = %USERPROFILE%\Pictures
20520 = %USERPROFILE%
20521 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
20522 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
20523 = %COMMONPROGRAMFILES%
20524 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
20525 = %PROGRAMDATA%\Microsoft\Windows\Templates
20526 = %AllUsersProfile%\Public\Documents
20527 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20528 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20533 = %AllUsersProfile%\Public\Music
20534 = %AllUsersProfile%\Public\Pictures
20535 = %AllUsersProfile%\Public\Videos
20536 = %SystemRoot%\resources
20537 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
20538 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
20539 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
20736 = %USERPROFILE%\Desktop
20738 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
20741 = %USERPROFILE%\Documents
20742 = %USERPROFILE%\Favorites
20743 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
20744 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
20745 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
20747 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
20749 = %USERPROFILE%\Music
20750 = %USERPROFILE%\Videos
20752 = %USERPROFILE%\Desktop
20755 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
20756 = %SystemRoot%\Fonts
20757 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
20758 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
20759 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
20760 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
20761 = %AllUsersProfile%\Public\Desktop
20762 = %USERPROFILE%\AppData\Roaming
20763 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
20764 = %USERPROFILE%\AppData\Local
20765 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
20766 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
20767 = %USERPROFILE%\Favorites
20768 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
20769 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
20770 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
20771 = %PROGRAMDATA%
20772 = %SystemRoot%
20773 = %SystemRoot%\system32
20774 = %PROGRAMFILES%
20775 = %USERPROFILE%\Pictures
20776 = %USERPROFILE%
20777 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
20778 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
20779 = %COMMONPROGRAMFILES%
20780 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
20781 = %PROGRAMDATA%\Microsoft\Windows\Templates
20782 = %AllUsersProfile%\Public\Documents
20783 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20784 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
20789 = %AllUsersProfile%\Public\Music
20790 = %AllUsersProfile%\Public\Pictures
20791 = %AllUsersProfile%\Public\Videos
20792 = %SystemRoot%\resources
20793 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
20794 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
20795 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
20992 = %USERPROFILE%\Desktop
20994 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
20997 = %USERPROFILE%\Documents
20998 = %USERPROFILE%\Favorites
20999 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
21000 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
21001 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
21003 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
21005 = %USERPROFILE%\Music
21006 = %USERPROFILE%\Videos
21008 = %USERPROFILE%\Desktop
21011 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
21012 = %SystemRoot%\Fonts
21013 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
21014 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
21015 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
21016 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
21017 = %AllUsersProfile%\Public\Desktop
21018 = %USERPROFILE%\AppData\Roaming
21019 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
21020 = %USERPROFILE%\AppData\Local
21021 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21022 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21023 = %USERPROFILE%\Favorites
21024 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
21025 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
21026 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
21027 = %PROGRAMDATA%
21028 = %SystemRoot%
21029 = %SystemRoot%\system32
21030 = %PROGRAMFILES%
21031 = %USERPROFILE%\Pictures
21032 = %USERPROFILE%
21033 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
21034 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
21035 = %COMMONPROGRAMFILES%
21036 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
21037 = %PROGRAMDATA%\Microsoft\Windows\Templates
21038 = %AllUsersProfile%\Public\Documents
21039 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21040 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21045 = %AllUsersProfile%\Public\Music
21046 = %AllUsersProfile%\Public\Pictures
21047 = %AllUsersProfile%\Public\Videos
21048 = %SystemRoot%\resources
21049 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
21050 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
21051 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
21248 = %USERPROFILE%\Desktop
21250 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
21253 = %USERPROFILE%\Documents
21254 = %USERPROFILE%\Favorites
21255 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
21256 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
21257 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
21259 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
21261 = %USERPROFILE%\Music
21262 = %USERPROFILE%\Videos
21264 = %USERPROFILE%\Desktop
21267 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
21268 = %SystemRoot%\Fonts
21269 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
21270 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
21271 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
21272 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
21273 = %AllUsersProfile%\Public\Desktop
21274 = %USERPROFILE%\AppData\Roaming
21275 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
21276 = %USERPROFILE%\AppData\Local
21277 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21278 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21279 = %USERPROFILE%\Favorites
21280 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
21281 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
21282 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
21283 = %PROGRAMDATA%
21284 = %SystemRoot%
21285 = %SystemRoot%\system32
21286 = %PROGRAMFILES%
21287 = %USERPROFILE%\Pictures
21288 = %USERPROFILE%
21289 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
21290 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
21291 = %COMMONPROGRAMFILES%
21292 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
21293 = %PROGRAMDATA%\Microsoft\Windows\Templates
21294 = %AllUsersProfile%\Public\Documents
21295 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21296 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21301 = %AllUsersProfile%\Public\Music
21302 = %AllUsersProfile%\Public\Pictures
21303 = %AllUsersProfile%\Public\Videos
21304 = %SystemRoot%\resources
21305 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
21306 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
21307 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
21504 = %USERPROFILE%\Desktop
21506 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
21509 = %USERPROFILE%\Documents
21510 = %USERPROFILE%\Favorites
21511 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
21512 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
21513 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
21515 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
21517 = %USERPROFILE%\Music
21518 = %USERPROFILE%\Videos
21520 = %USERPROFILE%\Desktop
21523 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
21524 = %SystemRoot%\Fonts
21525 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
21526 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
21527 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
21528 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
21529 = %AllUsersProfile%\Public\Desktop
21530 = %USERPROFILE%\AppData\Roaming
21531 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
21532 = %USERPROFILE%\AppData\Local
21533 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21534 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21535 = %USERPROFILE%\Favorites
21536 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
21537 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
21538 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
21539 = %PROGRAMDATA%
21540 = %SystemRoot%
21541 = %SystemRoot%\system32
21542 = %PROGRAMFILES%
21543 = %USERPROFILE%\Pictures
21544 = %USERPROFILE%
21545 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
21546 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
21547 = %COMMONPROGRAMFILES%
21548 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
21549 = %PROGRAMDATA%\Microsoft\Windows\Templates
21550 = %AllUsersProfile%\Public\Documents
21551 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21552 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21557 = %AllUsersProfile%\Public\Music
21558 = %AllUsersProfile%\Public\Pictures
21559 = %AllUsersProfile%\Public\Videos
21560 = %SystemRoot%\resources
21561 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
21562 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
21563 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
21760 = %USERPROFILE%\Desktop
Dirids - Part 2
21762 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
21765 = %USERPROFILE%\Documents
21766 = %USERPROFILE%\Favorites
21767 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
21768 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
21769 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
21771 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
21773 = %USERPROFILE%\Music
21774 = %USERPROFILE%\Videos
21776 = %USERPROFILE%\Desktop
21779 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
21780 = %SystemRoot%\Fonts
21781 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
21782 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
21783 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
21784 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
21785 = %AllUsersProfile%\Public\Desktop
21786 = %USERPROFILE%\AppData\Roaming
21787 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
21788 = %USERPROFILE%\AppData\Local
21789 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21790 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
21791 = %USERPROFILE%\Favorites
21792 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
21793 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
21794 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
21795 = %PROGRAMDATA%
21796 = %SystemRoot%
21797 = %SystemRoot%\system32
21798 = %PROGRAMFILES%
21799 = %USERPROFILE%\Pictures
21800 = %USERPROFILE%
21801 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
21802 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
21803 = %COMMONPROGRAMFILES%
21804 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
21805 = %PROGRAMDATA%\Microsoft\Windows\Templates
21806 = %AllUsersProfile%\Public\Documents
21807 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21808 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
21813 = %AllUsersProfile%\Public\Music
21814 = %AllUsersProfile%\Public\Pictures
21815 = %AllUsersProfile%\Public\Videos
21816 = %SystemRoot%\resources
21817 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
21818 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
21819 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
22016 = %USERPROFILE%\Desktop
22018 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
22021 = %USERPROFILE%\Documents
22022 = %USERPROFILE%\Favorites
22023 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
22024 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
22025 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
22027 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
22029 = %USERPROFILE%\Music
22030 = %USERPROFILE%\Videos
22032 = %USERPROFILE%\Desktop
22035 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
22036 = %SystemRoot%\Fonts
22037 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
22038 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
22039 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
22040 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
22041 = %AllUsersProfile%\Public\Desktop
22042 = %USERPROFILE%\AppData\Roaming
22043 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
22044 = %USERPROFILE%\AppData\Local
22045 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22046 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22047 = %USERPROFILE%\Favorites
22048 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
22049 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
22050 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
22051 = %PROGRAMDATA%
22052 = %SystemRoot%
22053 = %SystemRoot%\system32
22054 = %PROGRAMFILES%
22055 = %USERPROFILE%\Pictures
22056 = %USERPROFILE%
22057 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
22058 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
22059 = %COMMONPROGRAMFILES%
22060 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
22061 = %PROGRAMDATA%\Microsoft\Windows\Templates
22062 = %AllUsersProfile%\Public\Documents
22063 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22064 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22069 = %AllUsersProfile%\Public\Music
22070 = %AllUsersProfile%\Public\Pictures
22071 = %AllUsersProfile%\Public\Videos
22072 = %SystemRoot%\resources
22073 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
22074 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
22075 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
22272 = %USERPROFILE%\Desktop
22274 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
22277 = %USERPROFILE%\Documents
22278 = %USERPROFILE%\Favorites
22279 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
22280 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
22281 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
22283 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
22285 = %USERPROFILE%\Music
22286 = %USERPROFILE%\Videos
22288 = %USERPROFILE%\Desktop
22291 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
22292 = %SystemRoot%\Fonts
22293 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
22294 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
22295 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
22296 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
22297 = %AllUsersProfile%\Public\Desktop
22298 = %USERPROFILE%\AppData\Roaming
22299 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
22300 = %USERPROFILE%\AppData\Local
22301 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22302 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22303 = %USERPROFILE%\Favorites
22304 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
22305 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
22306 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
22307 = %PROGRAMDATA%
22308 = %SystemRoot%
22309 = %SystemRoot%\system32
22310 = %PROGRAMFILES%
22311 = %USERPROFILE%\Pictures
22312 = %USERPROFILE%
22313 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
22314 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
22315 = %COMMONPROGRAMFILES%
22316 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
22317 = %PROGRAMDATA%\Microsoft\Windows\Templates
22318 = %AllUsersProfile%\Public\Documents
22319 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22320 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22325 = %AllUsersProfile%\Public\Music
22326 = %AllUsersProfile%\Public\Pictures
22327 = %AllUsersProfile%\Public\Videos
22328 = %SystemRoot%\resources
22329 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
22330 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
22331 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
22528 = %USERPROFILE%\Desktop
22530 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
22533 = %USERPROFILE%\Documents
22534 = %USERPROFILE%\Favorites
22535 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
22536 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
22537 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
22539 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
22541 = %USERPROFILE%\Music
22542 = %USERPROFILE%\Videos
22544 = %USERPROFILE%\Desktop
22547 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
22548 = %SystemRoot%\Fonts
22549 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
22550 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
22551 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
22552 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
22553 = %AllUsersProfile%\Public\Desktop
22554 = %USERPROFILE%\AppData\Roaming
22555 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
22556 = %USERPROFILE%\AppData\Local
22557 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22558 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22559 = %USERPROFILE%\Favorites
22560 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
22561 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
22562 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
22563 = %PROGRAMDATA%
22564 = %SystemRoot%
22565 = %SystemRoot%\system32
22566 = %PROGRAMFILES% ---> does not work = Win7_x64
22567 = %USERPROFILE%\Pictures
22568 = %USERPROFILE%
22569 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
22570 = %PROGRAMFILES% ---> does not work = Win7_x64
22571 = %COMMONPROGRAMFILES%
22572 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
22573 = %PROGRAMDATA%\Microsoft\Windows\Templates
22574 = %AllUsersProfile%\Public\Documents
22575 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22576 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22581 = %AllUsersProfile%\Public\Music
22582 = %AllUsersProfile%\Public\Pictures
22583 = %AllUsersProfile%\Public\Videos
22584 = %SystemRoot%\resources
22585 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
22586 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
22587 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
22784 = %USERPROFILE%\Desktop
22786 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
22789 = %USERPROFILE%\Documents
22790 = %USERPROFILE%\Favorites
22791 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
22792 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
22793 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
22795 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
22797 = %USERPROFILE%\Music
22798 = %USERPROFILE%\Videos
22800 = %USERPROFILE%\Desktop
22803 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
22804 = %SystemRoot%\Fonts
22805 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
22806 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
22807 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
22808 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
22809 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
22810 = %USERPROFILE%\AppData\Roaming
22811 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
22812 = %USERPROFILE%\AppData\Local
22813 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
22814 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
22815 = %USERPROFILE%\Favorites
22816 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
22817 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
22818 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
22819 = %PROGRAMDATA%
22820 = %SystemRoot%
22821 = %SystemRoot%\system32
22822 = %PROGRAMFILES% ---> does not work = Win7_x64
22823 = %USERPROFILE%\Pictures
22824 = %USERPROFILE%
22825 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
22827 = %COMMONPROGRAMFILES%
22828 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
22829 = %PROGRAMDATA%\Microsoft\Windows\Templates
22830 = %AllUsersProfile%\Public\Documents
22831 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
22832 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
22837 = %AllUsersProfile%\Public\Music
22838 = %AllUsersProfile%\Public\Pictures
22839 = %AllUsersProfile%\Public\Videos
22840 = %SystemRoot%\resources
22841 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
22842 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
22843 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
23040 = %USERPROFILE%\Desktop
23042 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
23045 = %USERPROFILE%\Documents
23046 = %USERPROFILE%\Favorites
23047 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
23048 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
23049 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
23051 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
23053 = %USERPROFILE%\Music
23054 = %USERPROFILE%\Videos
23056 = %USERPROFILE%\Desktop
23059 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
23060 = %SystemRoot%\Fonts
23061 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
23062 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
23063 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
23064 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
23065 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
23066 = %USERPROFILE%\AppData\Roaming
23067 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
23068 = %USERPROFILE%\AppData\Local
23069 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
23070 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
23071 = %USERPROFILE%\Favorites
23072 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
23073 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
23074 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
23075 = %PROGRAMDATA%
23076 = %SystemRoot%
23077 = %SystemRoot%\system32
23078 = %PROGRAMFILES% ---> does not work = Win7_x64
23079 = %USERPROFILE%\Pictures
23080 = %USERPROFILE%
23081 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
23083 = %COMMONPROGRAMFILES%
23084 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
23085 = %PROGRAMDATA%\Microsoft\Windows\Templates
23086 = %AllUsersProfile%\Public\Documents
23087 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
23088 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
23093 = %AllUsersProfile%\Public\Music
23094 = %AllUsersProfile%\Public\Pictures
23095 = %AllUsersProfile%\Public\Videos
23096 = %SystemRoot%\resources
23097 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
23098 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
23099 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
23296 = %USERPROFILE%\Desktop
23298 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
23301 = %USERPROFILE%\Documents
23302 = %USERPROFILE%\Favorites
23303 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
23304 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
23305 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
23307 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
23309 = %USERPROFILE%\Music
23310 = %USERPROFILE%\Videos
23312 = %USERPROFILE%\Desktop
23315 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
23316 = %SystemRoot%\Fonts
23317 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
23318 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
23319 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
23320 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
23321 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
23322 = %USERPROFILE%\AppData\Roaming
23323 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
23324 = %USERPROFILE%\AppData\Local
23325 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
23326 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
23327 = %USERPROFILE%\Favorites
23328 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
23329 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
23330 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
23331 = %PROGRAMDATA%
23332 = %SystemRoot%
23333 = %SystemRoot%\system32
23334 = %PROGRAMFILES% ---> does not work = Win7_x64
23335 = %USERPROFILE%\Pictures
23336 = %USERPROFILE%
23337 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
23339 = %COMMONPROGRAMFILES%
23340 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
23341 = %PROGRAMDATA%\Microsoft\Windows\Templates
23342 = %AllUsersProfile%\Public\Documents
23343 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
23344 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
23349 = %AllUsersProfile%\Public\Music
23350 = %AllUsersProfile%\Public\Pictures
23351 = %AllUsersProfile%\Public\Videos
23352 = %SystemRoot%\resources
23353 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
23354 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
23355 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
23552 = %USERPROFILE%\Desktop
23554 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
23557 = %USERPROFILE%\Documents
23558 = %USERPROFILE%\Favorites
23559 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
23560 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
23561 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
23563 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
23565 = %USERPROFILE%\Music
23566 = %USERPROFILE%\Videos
23568 = %USERPROFILE%\Desktop
23571 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
23572 = %SystemRoot%\Fonts
23573 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
23574 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
23575 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
23576 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
23577 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
23578 = %USERPROFILE%\AppData\Roaming
23579 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
23580 = %USERPROFILE%\AppData\Local
23581 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
23582 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
23583 = %USERPROFILE%\Favorites
23584 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
23585 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
23586 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
23587 = %PROGRAMDATA%
23588 = %SystemRoot%
23589 = %SystemRoot%\system32
23590 = %PROGRAMFILES% ---> does not work = Win7_x64
23591 = %USERPROFILE%\Pictures
23592 = %USERPROFILE%
23593 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
23595 = %COMMONPROGRAMFILES%
23596 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
23597 = %PROGRAMDATA%\Microsoft\Windows\Templates
23598 = %AllUsersProfile%\Public\Documents ---> does not work = Win7_x64
23599 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
23600 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
23605 = %AllUsersProfile%\Public\Music
23606 = %AllUsersProfile%\Public\Pictures
23607 = %AllUsersProfile%\Public\Videos
23608 = %SystemRoot%\resources
23609 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
23610 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
23611 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
23808 = %USERPROFILE%\Desktop
23810 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
23813 = %USERPROFILE%\Documents
23814 = %USERPROFILE%\Favorites
23815 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
23816 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
23817 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
23819 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
23821 = %USERPROFILE%\Music
23822 = %USERPROFILE%\Videos
23824 = %USERPROFILE%\Desktop
23827 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
23828 = %SystemRoot%\Fonts
23829 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
23830 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
23831 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
23832 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
23833 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
23834 = %USERPROFILE%\AppData\Roaming
23835 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
23836 = %USERPROFILE%\AppData\Local
23837 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
23838 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64 and winxp
23839 = %USERPROFILE%\Favorites
23840 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
23841 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
23842 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
23843 = %PROGRAMDATA%
23844 = %SystemRoot%
23845 = %SystemRoot%\system32
23846 = %PROGRAMFILES% ---> does not work = Win7_x64
23847 = %USERPROFILE%\Pictures
23848 = %USERPROFILE%
23849 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
23851 = %COMMONPROGRAMFILES%
23852 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
23853 = %PROGRAMDATA%\Microsoft\Windows\Templates
23854 = %AllUsersProfile%\Public\Documents
23855 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
23856 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
23861 = %AllUsersProfile%\Public\Music
23862 = %AllUsersProfile%\Public\Pictures
23863 = %AllUsersProfile%\Public\Videos
23864 = %SystemRoot%\resources
23865 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
23866 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
23867 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
24064 = %USERPROFILE%\Desktop
24066 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
24069 = %USERPROFILE%\Documents
24070 = %USERPROFILE%\Favorites
24071 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
24072 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
24073 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
24075 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
24077 = %USERPROFILE%\Music
24078 = %USERPROFILE%\Videos
24080 = %USERPROFILE%\Desktop
24083 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
24084 = %SystemRoot%\Fonts
24085 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
24086 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
24087 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
24088 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
24089 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
24090 = %USERPROFILE%\AppData\Roaming
24091 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
24092 = %USERPROFILE%\AppData\Local
24093 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24094 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
24095 = %USERPROFILE%\Favorites
24096 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
24097 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
24098 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
24099 = %PROGRAMDATA%
24100 = %SystemRoot%
24101 = %SystemRoot%\system32
24102 = %PROGRAMFILES% ---> does not work = Win7_x64
24103 = %USERPROFILE%\Pictures
24104 = %USERPROFILE%
24105 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
24107 = %COMMONPROGRAMFILES%
24108 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
24109 = %PROGRAMDATA%\Microsoft\Windows\Templates
24110 = %AllUsersProfile%\Public\Documents
24111 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
24112 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24117 = %AllUsersProfile%\Public\Music
24118 = %AllUsersProfile%\Public\Pictures
24119 = %AllUsersProfile%\Public\Videos
24120 = %SystemRoot%\resources
24121 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
24122 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
24123 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
24320 = %USERPROFILE%\Desktop
24322 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
24325 = %USERPROFILE%\Documents
24326 = %USERPROFILE%\Favorites
24327 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
24328 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
24329 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
24331 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
24333 = %USERPROFILE%\Music
24334 = %USERPROFILE%\Videos
24336 = %USERPROFILE%\Desktop
24339 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
24340 = %SystemRoot%\Fonts
24341 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
24342 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
24343 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
24344 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
24345 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
24346 = %USERPROFILE%\AppData\Roaming
24347 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
24348 = %USERPROFILE%\AppData\Local
24349 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
24350 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24351 = %USERPROFILE%\Favorites
24352 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
24353 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
24354 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
24355 = %PROGRAMDATA%
24356 = %SystemRoot%
24357 = %SystemRoot%\system32
24358 = %PROGRAMFILES% ---> does not work = Win7_x64
24359 = %USERPROFILE%\Pictures
24360 = %USERPROFILE%
24361 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
24363 = %COMMONPROGRAMFILES%
24364 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
24365 = %PROGRAMDATA%\Microsoft\Windows\Templates
24366 = %AllUsersProfile%\Public\Documents
24367 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
24368 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24373 = %AllUsersProfile%\Public\Music
24374 = %AllUsersProfile%\Public\Pictures
24375 = %AllUsersProfile%\Public\Videos
24376 = %SystemRoot%\resources
24377 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
24378 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
24379 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
24576 = %USERPROFILE%\Desktop
24578 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
24581 = %USERPROFILE%\Documents
24582 = %USERPROFILE%\Favorites
24583 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
24584 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
24585 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
24587 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
24589 = %USERPROFILE%\Music
24590 = %USERPROFILE%\Videos
24592 = %USERPROFILE%\Desktop
24595 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
24596 = %SystemRoot%\Fonts
24597 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
24598 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
24599 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
24600 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
24601 = %AllUsersProfile%\Public\Desktop
24602 = %USERPROFILE%\AppData\Roaming
24603 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
24604 = %USERPROFILE%\AppData\Local
24605 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24606 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24607 = %USERPROFILE%\Favorites
24608 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
24609 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
24610 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
24611 = %PROGRAMDATA%
24612 = %SystemRoot%
24613 = %SystemRoot%\system32
24614 = %PROGRAMFILES%
24615 = %USERPROFILE%\Pictures
24616 = %USERPROFILE%
24617 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
24618 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
24619 = %COMMONPROGRAMFILES%
24620 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
24621 = %PROGRAMDATA%\Microsoft\Windows\Templates
24622 = %AllUsersProfile%\Public\Documents
24623 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24624 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24629 = %AllUsersProfile%\Public\Music
24630 = %AllUsersProfile%\Public\Pictures
24631 = %AllUsersProfile%\Public\Videos
24632 = %SystemRoot%\resources
24633 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
24634 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
24635 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
24832 = %USERPROFILE%\Desktop
24834 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
24837 = %USERPROFILE%\Documents
24838 = %USERPROFILE%\Favorites
24839 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
24840 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
24841 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
24843 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
24845 = %USERPROFILE%\Music
24846 = %USERPROFILE%\Videos
24848 = %USERPROFILE%\Desktop
24851 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
24852 = %SystemRoot%\Fonts
24853 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
24854 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
24855 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
24856 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
24857 = %AllUsersProfile%\Public\Desktop
24858 = %USERPROFILE%\AppData\Roaming
24859 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
24860 = %USERPROFILE%\AppData\Local
24861 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24862 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
24863 = %USERPROFILE%\Favorites
24864 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
24865 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
24866 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
24867 = %PROGRAMDATA%
24868 = %SystemRoot%
24869 = %SystemRoot%\system32
24870 = %PROGRAMFILES%
24871 = %USERPROFILE%\Pictures
24872 = %USERPROFILE%
24873 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
24874 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
24875 = %COMMONPROGRAMFILES%
24876 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
24877 = %PROGRAMDATA%\Microsoft\Windows\Templates
24878 = %AllUsersProfile%\Public\Documents
24879 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24880 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
24885 = %AllUsersProfile%\Public\Music
24886 = %AllUsersProfile%\Public\Pictures
24887 = %AllUsersProfile%\Public\Videos
24888 = %SystemRoot%\resources
24889 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
24890 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
24891 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
25088 = %USERPROFILE%\Desktop
25090 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
25093 = %USERPROFILE%\Documents
25094 = %USERPROFILE%\Favorites
25095 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
25096 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
25097 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
25099 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
25101 = %USERPROFILE%\Music
25102 = %USERPROFILE%\Videos
25104 = %USERPROFILE%\Desktop
25107 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
25108 = %SystemRoot%\Fonts
25109 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
25110 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
25111 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
25112 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
25113 = %AllUsersProfile%\Public\Desktop
25114 = %USERPROFILE%\AppData\Roaming
25115 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
25116 = %USERPROFILE%\AppData\Local
25117 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25118 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25119 = %USERPROFILE%\Favorites
25120 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
25121 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
25122 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
25123 = %PROGRAMDATA%
25124 = %SystemRoot%
25125 = %SystemRoot%\system32
25126 = %PROGRAMFILES%
25127 = %USERPROFILE%\Pictures
25128 = %USERPROFILE%
25129 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
25130 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
25131 = %COMMONPROGRAMFILES%
25132 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
25133 = %PROGRAMDATA%\Microsoft\Windows\Templates
25134 = %AllUsersProfile%\Public\Documents
25135 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25136 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25141 = %AllUsersProfile%\Public\Music
25142 = %AllUsersProfile%\Public\Pictures
25143 = %AllUsersProfile%\Public\Videos
25144 = %SystemRoot%\resources
25145 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
25146 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
25147 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
25344 = %USERPROFILE%\Desktop
25346 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
25349 = %USERPROFILE%\Documents
25350 = %USERPROFILE%\Favorites
25351 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
25352 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
25353 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
25355 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
25357 = %USERPROFILE%\Music
25358 = %USERPROFILE%\Videos
25360 = %USERPROFILE%\Desktop
25363 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
25364 = %SystemRoot%\Fonts
25365 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
25366 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
25367 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
25368 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
25369 = %AllUsersProfile%\Public\Desktop
25370 = %USERPROFILE%\AppData\Roaming
25371 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
25372 = %USERPROFILE%\AppData\Local
25373 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25374 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25375 = %USERPROFILE%\Favorites
25376 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
25377 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
25378 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
25379 = %PROGRAMDATA%
25380 = %SystemRoot%
25381 = %SystemRoot%\system32
25382 = %PROGRAMFILES%
25383 = %USERPROFILE%\Pictures
25384 = %USERPROFILE%
25385 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
25386 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
25387 = %COMMONPROGRAMFILES%
25388 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
25389 = %PROGRAMDATA%\Microsoft\Windows\Templates
25390 = %AllUsersProfile%\Public\Documents
25391 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25392 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25397 = %AllUsersProfile%\Public\Music
25398 = %AllUsersProfile%\Public\Pictures
25399 = %AllUsersProfile%\Public\Videos
25400 = %SystemRoot%\resources
25401 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
25402 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
25403 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
25600 = %USERPROFILE%\Desktop
25602 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
25605 = %USERPROFILE%\Documents
25606 = %USERPROFILE%\Favorites
25607 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
25608 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
25609 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
25611 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
25613 = %USERPROFILE%\Music
25614 = %USERPROFILE%\Videos
25616 = %USERPROFILE%\Desktop
25619 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
25620 = %SystemRoot%\Fonts
25621 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
25622 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
25623 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
25624 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
25625 = %AllUsersProfile%\Public\Desktop
25626 = %USERPROFILE%\AppData\Roaming
25627 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
25628 = %USERPROFILE%\AppData\Local
25629 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25630 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25631 = %USERPROFILE%\Favorites
25632 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
25633 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
25634 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
25635 = %PROGRAMDATA%
25636 = %SystemRoot%
25637 = %SystemRoot%\system32
25638 = %PROGRAMFILES%
25639 = %USERPROFILE%\Pictures
25640 = %USERPROFILE%
25641 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
25642 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
25643 = %COMMONPROGRAMFILES%
25644 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
25645 = %PROGRAMDATA%\Microsoft\Windows\Templates
25646 = %AllUsersProfile%\Public\Documents
25647 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25648 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25653 = %AllUsersProfile%\Public\Music
25654 = %AllUsersProfile%\Public\Pictures
25655 = %AllUsersProfile%\Public\Videos
25656 = %SystemRoot%\resources
25657 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
25658 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
25659 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
25856 = %USERPROFILE%\Desktop
25858 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
25861 = %USERPROFILE%\Documents
25862 = %USERPROFILE%\Favorites
25863 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
25864 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
25865 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
25867 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
25869 = %USERPROFILE%\Music
25870 = %USERPROFILE%\Videos
25872 = %USERPROFILE%\Desktop
25875 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
25876 = %SystemRoot%\Fonts
25877 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
25878 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
25879 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
25880 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
25881 = %AllUsersProfile%\Public\Desktop
25882 = %USERPROFILE%\AppData\Roaming
25883 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
25884 = %USERPROFILE%\AppData\Local
25885 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25886 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
25887 = %USERPROFILE%\Favorites
25888 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
25889 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
25890 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
25891 = %PROGRAMDATA%
25892 = %SystemRoot%
25893 = %SystemRoot%\system32
25894 = %PROGRAMFILES%
25895 = %USERPROFILE%\Pictures
25896 = %USERPROFILE%
25897 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
25898 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
25899 = %COMMONPROGRAMFILES%
25900 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
25901 = %PROGRAMDATA%\Microsoft\Windows\Templates
25902 = %AllUsersProfile%\Public\Documents
25903 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25904 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
25909 = %AllUsersProfile%\Public\Music
25910 = %AllUsersProfile%\Public\Pictures
25911 = %AllUsersProfile%\Public\Videos
25912 = %SystemRoot%\resources
25913 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
25914 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
25915 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
26112 = %USERPROFILE%\Desktop
26114 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
26117 = %USERPROFILE%\Documents
26118 = %USERPROFILE%\Favorites
26119 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
26120 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
26121 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
26123 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
26125 = %USERPROFILE%\Music
26126 = %USERPROFILE%\Videos
26128 = %USERPROFILE%\Desktop
26131 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
26132 = %SystemRoot%\Fonts
26133 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
26134 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
26135 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
26136 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
26137 = %AllUsersProfile%\Public\Desktop
26138 = %USERPROFILE%\AppData\Roaming
26139 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
26140 = %USERPROFILE%\AppData\Local
26141 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26142 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26143 = %USERPROFILE%\Favorites
26144 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
26145 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
26146 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
26147 = %PROGRAMDATA%
26148 = %SystemRoot%
26149 = %SystemRoot%\system32
26150 = %PROGRAMFILES%
26151 = %USERPROFILE%\Pictures
26152 = %USERPROFILE%
26153 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
26154 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
26155 = %COMMONPROGRAMFILES%
26156 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
26157 = %PROGRAMDATA%\Microsoft\Windows\Templates
26158 = %AllUsersProfile%\Public\Documents
26159 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26160 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26165 = %AllUsersProfile%\Public\Music
26166 = %AllUsersProfile%\Public\Pictures
26167 = %AllUsersProfile%\Public\Videos
26168 = %SystemRoot%\resources
26169 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
26170 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
26171 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
26368 = %USERPROFILE%\Desktop
26370 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
26373 = %USERPROFILE%\Documents
26374 = %USERPROFILE%\Favorites
26375 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
26376 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
26377 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
26379 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
26381 = %USERPROFILE%\Music
26382 = %USERPROFILE%\Videos
26384 = %USERPROFILE%\Desktop
26387 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
26388 = %SystemRoot%\Fonts
26389 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
26390 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
26391 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
26392 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
26393 = %AllUsersProfile%\Public\Desktop
26394 = %USERPROFILE%\AppData\Roaming
26395 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
26396 = %USERPROFILE%\AppData\Local
26397 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26398 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26399 = %USERPROFILE%\Favorites
26400 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
26401 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
26402 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
26403 = %PROGRAMDATA%
26404 = %SystemRoot%
26405 = %SystemRoot%\system32
26406 = %PROGRAMFILES%
26407 = %USERPROFILE%\Pictures
26408 = %USERPROFILE%
26409 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
26410 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
26411 = %COMMONPROGRAMFILES%
26412 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
26413 = %PROGRAMDATA%\Microsoft\Windows\Templates
26414 = %AllUsersProfile%\Public\Documents
26415 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26416 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26421 = %AllUsersProfile%\Public\Music
26422 = %AllUsersProfile%\Public\Pictures
26423 = %AllUsersProfile%\Public\Videos
26424 = %SystemRoot%\resources
26425 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
26426 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
26427 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
26624 = %USERPROFILE%\Desktop
26626 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
26629 = %USERPROFILE%\Documents
26630 = %USERPROFILE%\Favorites
26631 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
26632 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
26633 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
26635 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
26637 = %USERPROFILE%\Music
26638 = %USERPROFILE%\Videos
26640 = %USERPROFILE%\Desktop
26643 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
26644 = %SystemRoot%\Fonts
26645 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
26646 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
26647 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
26648 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
26649 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
26650 = %USERPROFILE%\AppData\Roaming
26651 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
26652 = %USERPROFILE%\AppData\Local
26653 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26654 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
26655 = %USERPROFILE%\Favorites
26656 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
26657 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
26658 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
26659 = %PROGRAMDATA%
26660 = %SystemRoot%
26661 = %SystemRoot%\system32
26662 = %PROGRAMFILES% ---> does not work = Win7_x64
26663 = %USERPROFILE%\Pictures
26664 = %USERPROFILE%
26665 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
26667 = %COMMONPROGRAMFILES%
26668 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
26669 = %PROGRAMDATA%\Microsoft\Windows\Templates
26670 = %AllUsersProfile%\Public\Documents
26671 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26672 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26677 = %AllUsersProfile%\Public\Music
26678 = %AllUsersProfile%\Public\Pictures
26679 = %AllUsersProfile%\Public\Videos
26680 = %SystemRoot%\resources
26681 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
26682 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
26683 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
26880 = %USERPROFILE%\Desktop
26882 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
26885 = %USERPROFILE%\Documents
26886 = %USERPROFILE%\Favorites
26887 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
26888 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
26889 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
26891 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
26893 = %USERPROFILE%\Music
26894 = %USERPROFILE%\Videos
26896 = %USERPROFILE%\Desktop
26899 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
26900 = %SystemRoot%\Fonts
26901 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
26902 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
26903 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
26904 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
26905 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
26906 = %USERPROFILE%\AppData\Roaming
26907 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
26908 = %USERPROFILE%\AppData\Local
26909 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
26910 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
26911 = %USERPROFILE%\Favorites
26912 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
26913 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
26914 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
26915 = %PROGRAMDATA%
26916 = %SystemRoot%
26917 = %SystemRoot%\system32
26918 = %PROGRAMFILES% ---> does not work = Win7_x64
26919 = %USERPROFILE%\Pictures
26920 = %USERPROFILE%
26921 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
26923 = %COMMONPROGRAMFILES%
26924 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
26925 = %PROGRAMDATA%\Microsoft\Windows\Templates
26926 = %AllUsersProfile%\Public\Documents
26927 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
26928 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
26933 = %AllUsersProfile%\Public\Music
26934 = %AllUsersProfile%\Public\Pictures
26935 = %AllUsersProfile%\Public\Videos
26936 = %SystemRoot%\resources
26937 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
26938 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
26939 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
27136 = %USERPROFILE%\Desktop
27138 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
27141 = %USERPROFILE%\Documents
27142 = %USERPROFILE%\Favorites
27143 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
27144 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
27145 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
27147 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
27149 = %USERPROFILE%\Music
27150 = %USERPROFILE%\Videos
27152 = %USERPROFILE%\Desktop
27155 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
27156 = %SystemRoot%\Fonts
27157 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
27158 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
27159 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
27160 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
27161 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
27162 = %USERPROFILE%\AppData\Roaming
27163 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
27164 = %USERPROFILE%\AppData\Local
27165 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
27166 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
27167 = %USERPROFILE%\Favorites
27168 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
27169 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
Dirids - Part 3
27170 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
27171 = %PROGRAMDATA%
27172 = %SystemRoot%
27173 = %SystemRoot%\system32
27174 = %PROGRAMFILES% ---> does not work = Win7_x64
27175 = %USERPROFILE%\Pictures
27176 = %USERPROFILE%
27177 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
27179 = %COMMONPROGRAMFILES%
27180 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
27181 = %PROGRAMDATA%\Microsoft\Windows\Templates
27182 = %AllUsersProfile%\Public\Documents
27183 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
27184 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
27189 = %AllUsersProfile%\Public\Music
27190 = %AllUsersProfile%\Public\Pictures
27191 = %AllUsersProfile%\Public\Videos
27192 = %SystemRoot%\resources
27193 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
27194 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
27195 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
27392 = %USERPROFILE%\Desktop
27394 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
27397 = %USERPROFILE%\Documents
27398 = %USERPROFILE%\Favorites
27399 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
27400 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
27401 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
27403 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
27405 = %USERPROFILE%\Music
27406 = %USERPROFILE%\Videos
27408 = %USERPROFILE%\Desktop
27411 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
27412 = %SystemRoot%\Fonts
27413 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
27414 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
27415 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
27416 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
27417 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
27418 = %USERPROFILE%\AppData\Roaming
27419 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
27420 = %USERPROFILE%\AppData\Local
27421 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
27422 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
27423 = %USERPROFILE%\Favorites
27424 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
27425 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
27426 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
27427 = %PROGRAMDATA%
27428 = %SystemRoot%
27429 = %SystemRoot%\system32
27430 = %PROGRAMFILES% ---> does not work = Win7_x64
27431 = %USERPROFILE%\Pictures
27432 = %USERPROFILE%
27433 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
27435 = %COMMONPROGRAMFILES%
27436 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
27437 = %PROGRAMDATA%\Microsoft\Windows\Templates
27438 = %AllUsersProfile%\Public\Documents
27439 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
27440 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
27445 = %AllUsersProfile%\Public\Music
27446 = %AllUsersProfile%\Public\Pictures
27447 = %AllUsersProfile%\Public\Videos
27448 = %SystemRoot%\resources
27449 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
27450 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
27451 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
27648 = %USERPROFILE%\Desktop
27650 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
27653 = %USERPROFILE%\Documents
27654 = %USERPROFILE%\Favorites
27655 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
27656 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
27657 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
27659 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
27661 = %USERPROFILE%\Music
27662 = %USERPROFILE%\Videos
27664 = %USERPROFILE%\Desktop
27667 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
27668 = %SystemRoot%\Fonts
27669 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
27670 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
27671 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
27672 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
27673 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
27674 = %USERPROFILE%\AppData\Roaming
27675 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
27676 = %USERPROFILE%\AppData\Local
27677 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
27678 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
27679 = %USERPROFILE%\Favorites
27680 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
27681 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
27682 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
27683 = %PROGRAMDATA%
27684 = %SystemRoot%
27685 = %SystemRoot%\system32
27686 = %PROGRAMFILES% ---> does not work = Win7_x64
27687 = %USERPROFILE%\Pictures
27688 = %USERPROFILE%
27689 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
27691 = %COMMONPROGRAMFILES%
27692 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
27693 = %PROGRAMDATA%\Microsoft\Windows\Templates
27694 = %AllUsersProfile%\Public\Documents
27695 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
27696 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
27701 = %AllUsersProfile%\Public\Music
27702 = %AllUsersProfile%\Public\Pictures
27703 = %AllUsersProfile%\Public\Videos
27704 = %SystemRoot%\resources
27705 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
27706 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
27707 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
27904 = %USERPROFILE%\Desktop
27906 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
27909 = %USERPROFILE%\Documents
27910 = %USERPROFILE%\Favorites
27911 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
27912 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
27913 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
27915 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
27917 = %USERPROFILE%\Music
27918 = %USERPROFILE%\Videos
27920 = %USERPROFILE%\Desktop
27923 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
27924 = %SystemRoot%\Fonts
27925 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
27926 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
27927 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
27928 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
27929 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
27930 = %USERPROFILE%\AppData\Roaming
27931 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
27932 = %USERPROFILE%\AppData\Local
27933 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
27934 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
27935 = %USERPROFILE%\Favorites
27936 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
27937 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
27938 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
27939 = %PROGRAMDATA%
27940 = %SystemRoot%
27941 = %SystemRoot%\system32
27942 = %PROGRAMFILES% ---> does not work = Win7_x64
27943 = %USERPROFILE%\Pictures
27944 = %USERPROFILE%
27945 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
27947 = %COMMONPROGRAMFILES%
27948 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
27949 = %PROGRAMDATA%\Microsoft\Windows\Templates
27950 = %AllUsersProfile%\Public\Documents
27951 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
27952 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
27957 = %AllUsersProfile%\Public\Music
27958 = %AllUsersProfile%\Public\Pictures
27959 = %AllUsersProfile%\Public\Videos
27960 = %SystemRoot%\resources
27961 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
27962 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
27963 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
28160 = %USERPROFILE%\Desktop
28162 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
28165 = %USERPROFILE%\Documents
28166 = %USERPROFILE%\Favorites
28167 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
28168 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
28169 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
28171 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
28173 = %USERPROFILE%\Music
28174 = %USERPROFILE%\Videos
28176 = %USERPROFILE%\Desktop
28179 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
28180 = %SystemRoot%\Fonts
28181 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
28182 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
28183 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
28184 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
28185 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
28186 = %USERPROFILE%\AppData\Roaming
28187 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
28188 = %USERPROFILE%\AppData\Local
28189 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28190 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
28191 = %USERPROFILE%\Favorites
28192 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
28193 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
28194 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
28195 = %PROGRAMDATA%
28196 = %SystemRoot%
28197 = %SystemRoot%\system32
28198 = %PROGRAMFILES% ---> does not work = Win7_x64
28199 = %USERPROFILE%\Pictures
28200 = %USERPROFILE%
28201 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
28203 = %COMMONPROGRAMFILES%
28204 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
28205 = %PROGRAMDATA%\Microsoft\Windows\Templates
28206 = %AllUsersProfile%\Public\Documents
28207 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
28208 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28213 = %AllUsersProfile%\Public\Music
28214 = %AllUsersProfile%\Public\Pictures
28215 = %AllUsersProfile%\Public\Videos
28216 = %SystemRoot%\resources
28217 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
28218 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
28219 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
28416 = %USERPROFILE%\Desktop
28418 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
28421 = %USERPROFILE%\Documents
28422 = %USERPROFILE%\Favorites
28423 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
28424 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
28425 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
28427 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
28429 = %USERPROFILE%\Music
28430 = %USERPROFILE%\Videos
28432 = %USERPROFILE%\Desktop
28435 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
28436 = %SystemRoot%\Fonts
28437 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
28438 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
28439 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
28440 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
28441 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
28442 = %USERPROFILE%\AppData\Roaming
28443 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
28444 = %USERPROFILE%\AppData\Local
28445 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28446 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
28447 = %USERPROFILE%\Favorites
28448 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
28449 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
28450 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
28451 = %PROGRAMDATA%
28452 = %SystemRoot%
28453 = %SystemRoot%\system32
28454 = %PROGRAMFILES% ---> does not work = Win7_x64
28455 = %USERPROFILE%\Pictures
28456 = %USERPROFILE%
28457 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
28459 = %COMMONPROGRAMFILES%
28460 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
28461 = %PROGRAMDATA%\Microsoft\Windows\Templates
28462 = %AllUsersProfile%\Public\Documents
28463 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
28464 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28469 = %AllUsersProfile%\Public\Music
28470 = %AllUsersProfile%\Public\Pictures
28471 = %AllUsersProfile%\Public\Videos
28472 = %SystemRoot%\resources
28473 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
28474 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
28475 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
28672 = %USERPROFILE%\Desktop
28674 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
28677 = %USERPROFILE%\Documents
28678 = %USERPROFILE%\Favorites
28679 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
28680 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
28681 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
28683 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
28685 = %USERPROFILE%\Music
28686 = %USERPROFILE%\Videos
28688 = %USERPROFILE%\Desktop
28691 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
28692 = %SystemRoot%\Fonts
28693 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
28694 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
28695 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
28696 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
28697 = %AllUsersProfile%\Public\Desktop
28698 = %USERPROFILE%\AppData\Roaming
28699 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
28700 = %USERPROFILE%\AppData\Local
28701 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28702 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28703 = %USERPROFILE%\Favorites
28704 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
28705 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
28706 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
28707 = %PROGRAMDATA%
28708 = %SystemRoot%
28709 = %SystemRoot%\system32
28710 = %PROGRAMFILES%
28711 = %USERPROFILE%\Pictures
28712 = %USERPROFILE%
28713 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
28714 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
28715 = %COMMONPROGRAMFILES%
28716 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
28717 = %PROGRAMDATA%\Microsoft\Windows\Templates
28718 = %AllUsersProfile%\Public\Documents
28719 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28720 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28725 = %AllUsersProfile%\Public\Music
28726 = %AllUsersProfile%\Public\Pictures
28727 = %AllUsersProfile%\Public\Videos
28728 = %SystemRoot%\resources
28729 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
28730 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
28731 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
28928 = %USERPROFILE%\Desktop
28930 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
28933 = %USERPROFILE%\Documents
28934 = %USERPROFILE%\Favorites
28935 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
28936 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
28937 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
28939 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
28941 = %USERPROFILE%\Music
28942 = %USERPROFILE%\Videos
28944 = %USERPROFILE%\Desktop
28947 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
28948 = %SystemRoot%\Fonts
28949 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
28950 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
28951 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
28952 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
28953 = %AllUsersProfile%\Public\Desktop
28954 = %USERPROFILE%\AppData\Roaming
28955 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
28956 = %USERPROFILE%\AppData\Local
28957 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28958 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
28959 = %USERPROFILE%\Favorites
28960 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
28961 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
28962 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
28963 = %PROGRAMDATA%
28964 = %SystemRoot%
28965 = %SystemRoot%\system32
28966 = %PROGRAMFILES%
28967 = %USERPROFILE%\Pictures
28968 = %USERPROFILE%
28969 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
28970 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
28971 = %COMMONPROGRAMFILES%
28972 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
28973 = %PROGRAMDATA%\Microsoft\Windows\Templates
28974 = %AllUsersProfile%\Public\Documents
28975 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28976 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
28981 = %AllUsersProfile%\Public\Music
28982 = %AllUsersProfile%\Public\Pictures
28983 = %AllUsersProfile%\Public\Videos
28984 = %SystemRoot%\resources
28985 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
28986 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
28987 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
29184 = %USERPROFILE%\Desktop
29186 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
29189 = %USERPROFILE%\Documents
29190 = %USERPROFILE%\Favorites
29191 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
29192 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
29193 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
29195 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
29197 = %USERPROFILE%\Music
29198 = %USERPROFILE%\Videos
29200 = %USERPROFILE%\Desktop
29203 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
29204 = %SystemRoot%\Fonts
29205 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
29206 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
29207 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
29208 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
29209 = %AllUsersProfile%\Public\Desktop
29210 = %USERPROFILE%\AppData\Roaming
29211 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
29212 = %USERPROFILE%\AppData\Local
29213 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29214 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29215 = %USERPROFILE%\Favorites
29216 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
29217 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
29218 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
29219 = %PROGRAMDATA%
29220 = %SystemRoot%
29221 = %SystemRoot%\system32
29222 = %PROGRAMFILES%
29223 = %USERPROFILE%\Pictures
29224 = %USERPROFILE%
29225 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
29226 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
29227 = %COMMONPROGRAMFILES%
29228 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
29229 = %PROGRAMDATA%\Microsoft\Windows\Templates
29230 = %AllUsersProfile%\Public\Documents
29231 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29232 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29237 = %AllUsersProfile%\Public\Music
29238 = %AllUsersProfile%\Public\Pictures
29239 = %AllUsersProfile%\Public\Videos
29240 = %SystemRoot%\resources
29241 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
29242 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
29243 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
29440 = %USERPROFILE%\Desktop
29442 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
29445 = %USERPROFILE%\Documents
29446 = %USERPROFILE%\Favorites
29447 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
29448 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
29449 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
29451 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
29453 = %USERPROFILE%\Music
29454 = %USERPROFILE%\Videos
29456 = %USERPROFILE%\Desktop
29459 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
29460 = %SystemRoot%\Fonts
29461 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
29462 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
29463 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
29464 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
29465 = %AllUsersProfile%\Public\Desktop
29466 = %USERPROFILE%\AppData\Roaming
29467 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
29468 = %USERPROFILE%\AppData\Local
29469 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29470 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29471 = %USERPROFILE%\Favorites
29472 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
29473 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
29474 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
29475 = %PROGRAMDATA%
29476 = %SystemRoot%
29477 = %SystemRoot%\system32
29478 = %PROGRAMFILES%
29479 = %USERPROFILE%\Pictures
29480 = %USERPROFILE%
29481 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
29482 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
29483 = %COMMONPROGRAMFILES%
29484 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
29485 = %PROGRAMDATA%\Microsoft\Windows\Templates
29486 = %AllUsersProfile%\Public\Documents
29487 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29488 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29493 = %AllUsersProfile%\Public\Music
29494 = %AllUsersProfile%\Public\Pictures
29495 = %AllUsersProfile%\Public\Videos
29496 = %SystemRoot%\resources
29497 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
29498 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
29499 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
29696 = %USERPROFILE%\Desktop
29698 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
29701 = %USERPROFILE%\Documents
29702 = %USERPROFILE%\Favorites
29703 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
29704 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
29705 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
29707 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
29709 = %USERPROFILE%\Music
29710 = %USERPROFILE%\Videos
29712 = %USERPROFILE%\Desktop
29715 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
29716 = %SystemRoot%\Fonts
29717 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
29718 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
29719 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
29720 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
29721 = %AllUsersProfile%\Public\Desktop
29722 = %USERPROFILE%\AppData\Roaming
29723 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
29724 = %USERPROFILE%\AppData\Local
29725 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29726 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29727 = %USERPROFILE%\Favorites
29728 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
29729 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
29730 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
29731 = %PROGRAMDATA%
29732 = %SystemRoot%
29733 = %SystemRoot%\system32
29734 = %PROGRAMFILES%
29735 = %USERPROFILE%\Pictures
29736 = %USERPROFILE%
29737 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
29738 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
29739 = %COMMONPROGRAMFILES%
29740 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
29741 = %PROGRAMDATA%\Microsoft\Windows\Templates
29742 = %AllUsersProfile%\Public\Documents
29743 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29744 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
29749 = %AllUsersProfile%\Public\Music
29750 = %AllUsersProfile%\Public\Pictures
29751 = %AllUsersProfile%\Public\Videos
29752 = %SystemRoot%\resources
29753 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
29754 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
29755 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
29952 = %USERPROFILE%\Desktop
29954 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
29957 = %USERPROFILE%\Documents
29958 = %USERPROFILE%\Favorites
29959 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
29960 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
29961 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
29963 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
29965 = %USERPROFILE%\Music
29966 = %USERPROFILE%\Videos
29968 = %USERPROFILE%\Desktop
29971 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
29972 = %SystemRoot%\Fonts
29973 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
29974 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
29975 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
29976 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
29977 = %AllUsersProfile%\Public\Desktop
29978 = %USERPROFILE%\AppData\Roaming
29979 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
29980 = %USERPROFILE%\AppData\Local
29981 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29982 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
29983 = %USERPROFILE%\Favorites
29984 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
29985 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
29986 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
29987 = %PROGRAMDATA%
29988 = %SystemRoot%
29989 = %SystemRoot%\system32
29990 = %PROGRAMFILES%
29991 = %USERPROFILE%\Pictures
29992 = %USERPROFILE%
29993 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
29994 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
29995 = %COMMONPROGRAMFILES%
29996 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
29997 = %PROGRAMDATA%\Microsoft\Windows\Templates
29998 = %AllUsersProfile%\Public\Documents
29999 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30000 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30005 = %AllUsersProfile%\Public\Music
30006 = %AllUsersProfile%\Public\Pictures
30007 = %AllUsersProfile%\Public\Videos
30008 = %SystemRoot%\resources
30009 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
30010 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
30011 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
30208 = %USERPROFILE%\Desktop
30210 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
30213 = %USERPROFILE%\Documents
30214 = %USERPROFILE%\Favorites
30215 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
30216 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
30217 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
30219 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
30221 = %USERPROFILE%\Music
30222 = %USERPROFILE%\Videos
30224 = %USERPROFILE%\Desktop
30227 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
30228 = %SystemRoot%\Fonts
30229 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
30230 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
30231 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
30232 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
30233 = %AllUsersProfile%\Public\Desktop
30234 = %USERPROFILE%\AppData\Roaming
30235 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
30236 = %USERPROFILE%\AppData\Local
30237 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
30238 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
30239 = %USERPROFILE%\Favorites
30240 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
30241 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
30242 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
30243 = %PROGRAMDATA%
30244 = %SystemRoot%
30245 = %SystemRoot%\system32
30246 = %PROGRAMFILES%
30247 = %USERPROFILE%\Pictures
30248 = %USERPROFILE%
30249 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
30250 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
30251 = %COMMONPROGRAMFILES%
30252 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
30253 = %PROGRAMDATA%\Microsoft\Windows\Templates
30254 = %AllUsersProfile%\Public\Documents
30255 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30256 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30261 = %AllUsersProfile%\Public\Music
30262 = %AllUsersProfile%\Public\Pictures
30263 = %AllUsersProfile%\Public\Videos
30264 = %SystemRoot%\resources
30265 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
30266 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
30267 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
30464 = %USERPROFILE%\Desktop
30466 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
30469 = %USERPROFILE%\Documents
30470 = %USERPROFILE%\Favorites
30471 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
30472 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
30473 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
30475 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
30477 = %USERPROFILE%\Music
30478 = %USERPROFILE%\Videos
30480 = %USERPROFILE%\Desktop
30483 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
30484 = %SystemRoot%\Fonts
30485 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
30486 = %PROGRAMDATA%\Microsoft\Windows\Start Menu
30487 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs
30488 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup
30489 = %AllUsersProfile%\Public\Desktop
30490 = %USERPROFILE%\AppData\Roaming
30491 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
30492 = %USERPROFILE%\AppData\Local
30493 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
30494 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
30495 = %USERPROFILE%\Favorites
30496 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
30497 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
30498 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
30499 = %PROGRAMDATA%
30500 = %SystemRoot%
30501 = %SystemRoot%\system32
30502 = %PROGRAMFILES%
30503 = %USERPROFILE%\Pictures
30504 = %USERPROFILE%
30505 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
30506 = %PROGRAMFILES(X86)% ---> does not work = WinXP_x32
30507 = %COMMONPROGRAMFILES%
30508 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
30509 = %PROGRAMDATA%\Microsoft\Windows\Templates
30510 = %AllUsersProfile%\Public\Documents
30511 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30512 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30517 = %AllUsersProfile%\Public\Music
30518 = %AllUsersProfile%\Public\Pictures
30519 = %AllUsersProfile%\Public\Videos
30520 = %SystemRoot%\resources
30521 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
30522 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
30523 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
30720 = %USERPROFILE%\Desktop
30722 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
30725 = %USERPROFILE%\Documents
30726 = %USERPROFILE%\Favorites
30727 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
30728 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
30729 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
30731 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
30733 = %USERPROFILE%\Music
30734 = %USERPROFILE%\Videos
30736 = %USERPROFILE%\Desktop
30739 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
30740 = %SystemRoot%\Fonts
30741 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
30742 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
30743 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
30744 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
30745 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
30746 = %USERPROFILE%\AppData\Roaming
30747 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
30748 = %USERPROFILE%\AppData\Local
30749 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
30750 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
30751 = %USERPROFILE%\Favorites
30752 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
30753 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
30754 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
30755 = %PROGRAMDATA%
30756 = %SystemRoot%
30757 = %SystemRoot%\system32
30758 = %PROGRAMFILES% ---> does not work = Win7_x64
30759 = %USERPROFILE%\Pictures
30760 = %USERPROFILE%
30761 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
30762 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
30763 = %COMMONPROGRAMFILES%
30764 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
30765 = %PROGRAMDATA%\Microsoft\Windows\Templates
30766 = %AllUsersProfile%\Public\Documents
30767 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
30768 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
30773 = %AllUsersProfile%\Public\Music
30774 = %AllUsersProfile%\Public\Pictures
30775 = %AllUsersProfile%\Public\Videos
30776 = %SystemRoot%\resources
30777 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
30778 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
30779 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
30976 = %USERPROFILE%\Desktop
30978 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
30981 = %USERPROFILE%\Documents
30982 = %USERPROFILE%\Favorites
30983 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
30984 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
30985 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
30987 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
30989 = %USERPROFILE%\Music
30990 = %USERPROFILE%\Videos
30992 = %USERPROFILE%\Desktop
30995 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
30996 = %SystemRoot%\Fonts
30997 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
30998 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
30999 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
31000 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
31001 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
31002 = %USERPROFILE%\AppData\Roaming
31003 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
31004 = %USERPROFILE%\AppData\Local
31005 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
31006 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
31007 = %USERPROFILE%\Favorites
31008 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
31009 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
31010 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
31011 = %PROGRAMDATA%
31012 = %SystemRoot%
31013 = %SystemRoot%\system32
31014 = %PROGRAMFILES% ---> does not work = Win7_x64
31015 = %USERPROFILE%\Pictures
31016 = %USERPROFILE%
31017 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
31018 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
31019 = %COMMONPROGRAMFILES%
31020 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
31021 = %PROGRAMDATA%\Microsoft\Windows\Templates
31022 = %AllUsersProfile%\Public\Documents
31023 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
31024 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
31029 = %AllUsersProfile%\Public\Music
31030 = %AllUsersProfile%\Public\Pictures
31031 = %AllUsersProfile%\Public\Videos
31032 = %SystemRoot%\resources
31033 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
31034 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
31035 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
31232 = %USERPROFILE%\Desktop
31234 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
31237 = %USERPROFILE%\Documents
31238 = %USERPROFILE%\Favorites
31239 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
31240 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
31241 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
31243 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
31245 = %USERPROFILE%\Music
31246 = %USERPROFILE%\Videos
31248 = %USERPROFILE%\Desktop
31251 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
31252 = %SystemRoot%\Fonts
31253 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
31254 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
31255 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
31256 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
31257 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
31258 = %USERPROFILE%\AppData\Roaming
31259 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
31260 = %USERPROFILE%\AppData\Local
31261 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
31262 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
31263 = %USERPROFILE%\Favorites
31264 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
31265 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
31266 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
31267 = %PROGRAMDATA%
31268 = %SystemRoot%
31269 = %SystemRoot%\system32
31270 = %PROGRAMFILES% ---> does not work = Win7_x64
31271 = %USERPROFILE%\Pictures
31272 = %USERPROFILE%
31273 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
31274 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
31275 = %COMMONPROGRAMFILES%
31276 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
31277 = %PROGRAMDATA%\Microsoft\Windows\Templates
31278 = %AllUsersProfile%\Public\Documents
31279 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
31280 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
31285 = %AllUsersProfile%\Public\Music
31286 = %AllUsersProfile%\Public\Pictures
31287 = %AllUsersProfile%\Public\Videos
31288 = %SystemRoot%\resources
31289 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
31290 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
31291 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
31488 = %USERPROFILE%\Desktop
31490 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
31493 = %USERPROFILE%\Documents
31494 = %USERPROFILE%\Favorites
31495 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
31496 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
31497 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
31499 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
31501 = %USERPROFILE%\Music
31502 = %USERPROFILE%\Videos
31504 = %USERPROFILE%\Desktop
31507 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
31508 = %SystemRoot%\Fonts
31509 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
31510 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
31511 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
31512 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
31513 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
31514 = %USERPROFILE%\AppData\Roaming
31515 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
31516 = %USERPROFILE%\AppData\Local
31517 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
31518 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
31519 = %USERPROFILE%\Favorites
31520 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
31521 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
31522 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
31523 = %PROGRAMDATA%
31524 = %SystemRoot%
31525 = %SystemRoot%\system32
31526 = %PROGRAMFILES% ---> does not work = Win7_x64
31527 = %USERPROFILE%\Pictures
31528 = %USERPROFILE%
31529 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
31530 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
31531 = %COMMONPROGRAMFILES%
31532 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
31533 = %PROGRAMDATA%\Microsoft\Windows\Templates
31534 = %AllUsersProfile%\Public\Documents
31535 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
31536 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
31541 = %AllUsersProfile%\Public\Music
31542 = %AllUsersProfile%\Public\Pictures
31543 = %AllUsersProfile%\Public\Videos
31544 = %SystemRoot%\resources
31545 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
31546 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
31547 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
31744 = %USERPROFILE%\Desktop
31746 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
31749 = %USERPROFILE%\Documents
31750 = %USERPROFILE%\Favorites
31751 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
31752 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
31753 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
31755 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
31757 = %USERPROFILE%\Music
31758 = %USERPROFILE%\Videos
31760 = %USERPROFILE%\Desktop
31763 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
31764 = %SystemRoot%\Fonts
31765 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
31766 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
31767 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
31768 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
31769 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
31770 = %USERPROFILE%\AppData\Roaming
31771 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
31772 = %USERPROFILE%\AppData\Local
31773 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
31774 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
31775 = %USERPROFILE%\Favorites
31776 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
31777 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
31778 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
31779 = %PROGRAMDATA%
31780 = %SystemRoot%
31781 = %SystemRoot%\system32
31782 = %PROGRAMFILES% ---> does not work = Win7_x64
31783 = %USERPROFILE%\Pictures
31784 = %USERPROFILE%
31785 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
31786 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
31787 = %COMMONPROGRAMFILES%
31788 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
31789 = %PROGRAMDATA%\Microsoft\Windows\Templates
31790 = %AllUsersProfile%\Public\Documents
31791 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
31792 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
31797 = %AllUsersProfile%\Public\Music
31798 = %AllUsersProfile%\Public\Pictures
31799 = %AllUsersProfile%\Public\Videos
31800 = %SystemRoot%\resources
31801 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
31802 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
31803 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
32000 = %USERPROFILE%\Desktop
32002 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
32005 = %USERPROFILE%\Documents
32006 = %USERPROFILE%\Favorites
32007 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
32008 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
32009 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
32011 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
32013 = %USERPROFILE%\Music
32014 = %USERPROFILE%\Videos
32016 = %USERPROFILE%\Desktop
32019 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
32020 = %SystemRoot%\Fonts
32021 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
32022 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
32023 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
32024 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
32025 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
32026 = %USERPROFILE%\AppData\Roaming
32027 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
32028 = %USERPROFILE%\AppData\Local
32029 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
32030 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
32031 = %USERPROFILE%\Favorites
32032 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
32033 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
32034 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
32035 = %PROGRAMDATA%
32036 = %SystemRoot%
32037 = %SystemRoot%\system32
32038 = %PROGRAMFILES% ---> does not work = Win7_x64
32039 = %USERPROFILE%\Pictures
32040 = %USERPROFILE%
32041 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
32042 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
32043 = %COMMONPROGRAMFILES%
32044 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
32045 = %PROGRAMDATA%\Microsoft\Windows\Templates
32046 = %AllUsersProfile%\Public\Documents
32047 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
32048 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
32053 = %AllUsersProfile%\Public\Music
32054 = %AllUsersProfile%\Public\Pictures
32055 = %AllUsersProfile%\Public\Videos
32056 = %SystemRoot%\resources
32057 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
32058 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
32059 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
32256 = %USERPROFILE%\Desktop
32258 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
32261 = %USERPROFILE%\Documents
32262 = %USERPROFILE%\Favorites
32263 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
32264 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
32265 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
32267 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
32269 = %USERPROFILE%\Music
32270 = %USERPROFILE%\Videos
32272 = %USERPROFILE%\Desktop
32275 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
32276 = %SystemRoot%\Fonts
32277 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
32278 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
32279 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
32280 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
32281 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
32282 = %USERPROFILE%\AppData\Roaming
32283 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
32284 = %USERPROFILE%\AppData\Local
32285 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
32286 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
32287 = %USERPROFILE%\Favorites
32288 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
32289 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
32290 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
32291 = %PROGRAMDATA%
32292 = %SystemRoot%
32293 = %SystemRoot%\system32
32294 = %PROGRAMFILES% ---> does not work = Win7_x64
32295 = %USERPROFILE%\Pictures
32296 = %USERPROFILE%
32297 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
32298 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
32299 = %COMMONPROGRAMFILES%
32300 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
32301 = %PROGRAMDATA%\Microsoft\Windows\Templates
32302 = %AllUsersProfile%\Public\Documents
32303 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
32304 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
32309 = %AllUsersProfile%\Public\Music
32310 = %AllUsersProfile%\Public\Pictures
32311 = %AllUsersProfile%\Public\Videos
32312 = %SystemRoot%\resources
32313 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
32314 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
32315 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
32512 = %USERPROFILE%\Desktop
32514 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
32517 = %USERPROFILE%\Documents
32518 = %USERPROFILE%\Favorites
32519 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
32520 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
32521 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
32523 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
32525 = %USERPROFILE%\Music
32526 = %USERPROFILE%\Videos
32528 = %USERPROFILE%\Desktop
32531 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
32532 = %SystemRoot%\Fonts
32533 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
32534 = %PROGRAMDATA%\Microsoft\Windows\Start Menu ---> does not work = Win7_x64
32535 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs ---> does not work = Win7_x64
32536 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64
32537 = %AllUsersProfile%\Public\Desktop ---> does not work = Win7_x64
32538 = %USERPROFILE%\AppData\Roaming
32539 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
32540 = %USERPROFILE%\AppData\Local
32541 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = WinXP_x64;WinXP_x32
32542 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Startup ---> does not work = Win7_x64;WinXP_x64;WinXP_x32
32543 = %USERPROFILE%\Favorites
32544 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
32545 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
32546 = %USERPROFILE%\AppData\Local\Microsoft\Windows\History
32547 = %PROGRAMDATA%
32548 = %SystemRoot%
32549 = %SystemRoot%\system32
32550 = %PROGRAMFILES% ---> does not work = Win7_x64
32551 = %USERPROFILE%\Pictures
32552 = %USERPROFILE%
32553 = %SystemRoot%\system32 ;OR %SystemRoot%\SysWOW64 in X64
32554 = %PROGRAMFILES(X86)% ---> does not work = Win7_x64;Win7_x32;WinXP_x32
32555 = %COMMONPROGRAMFILES%
32556 = %COMMONPROGRAMFILES(x86)% ---> does not work = WinXP_x32
32557 = %PROGRAMDATA%\Microsoft\Windows\Templates
32558 = %AllUsersProfile%\Public\Documents
32559 = %PROGRAMDATA%\Microsoft\Windows\Start Menu\Programs\Administrative Tools ---> does not work = Win7_x64
32560 = %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
32565 = %AllUsersProfile%\Public\Music
32566 = %AllUsersProfile%\Public\Pictures
32567 = %AllUsersProfile%\Public\Videos
32568 = %SystemRoot%\resources
32569 = %SystemRoot%\resources\0409 ---> does not work = Win7_x64
32570 = %PROGRAMDATA%\OEM Links ---> does not work = WinXP_x64;WinXP_x32
32571 = %USERPROFILE%\AppData\Local\Microsoft\Windows\Burn\Burn
