  • Replies 70
  • Views 24.1k
  • it would be great to have an ability to choose between "dism removing style" and "rt7lite/vlite removing style" it wold be really great!!!!!!!!!!!!!!!!!!!
I was planning on allowing users to delete anything else apart from those on the links.
Hiim!
This is good idea :)
I think that the necessary fonts are protected from being deleted on a running system. If so, to find out which fonts are necessary to keep you could try the following: (I have not tested this method, but I think it should work.)
1) First, copy all existing fonts to another folder so you can put them back if you need/want to.
2) Second, revert your system to the fonts included by a default install of Windows by following the instructions here - http://www.online-tech-tips.com/windows-7/windows-7-fonts/
3) Then you can go to your fonts folder and try to remove fonts one at a time. The necessary fonts should be protected from removal, if I understand things correctly.
You might want to install Office first, to make sure that any fonts required by Office remain.
This page - http://office.microsoft.com/en-us/office-xp-resource-kit/administering-fonts-HA001136393.aspx lists fonts used by Office XP, I assume it is the same or similar to what is used in other versions of Office.
Here is another link that lists specific fonts that should not be deleted - http://graphicssoft.about.com/od/aboutgraphics/a/fontoverload_3.htm. The page was originally written in 1999, but the fonts it lists should be appropriate, but there might be more fonts that should also not be deleted.
I hope this info is helpful.
How about a reverse feature? One that will allow installing fonts (irritates me whenever I do a fresh install and open up a document I made with non-standard fonts, since I forgot to reinstall my fonts).
  • 4 weeks later...
I want option with witch I can be able to delete Speech Support like in RT 7 Lite
- this option is soo unused for other languages then English, and I want to use it for Windows 8 what RT7 Lite cannot handle.
,Thanks
Edited by MAXtoriX
  • 4 weeks later...
can you please add these into Win Toolkit Please so that can be availiable to remove from image file pleaase!!!
Accessibility
Calculator
Mobility Center
On-Screen Magnifier
People near me
Projector Connectivity
Speech Support
Stickey Notes
Welcome Center
Windows Fax and Scanner
Windows Sidebar
what about adding Drivers like a list which drivers do you want to remove
Windows Sideshow Driver
What about adding Printers like a list where you can remove Printers except the one that you have
What about adding Scanners like a list where you can remove Scanners except the one that you have
Tv Turner
BlueTooth
Fax
Floppy Drive
What about adding wherer you can remove Languages: except the ones that you want to keep
Mobile Pc Presentation
Sample Music and Video
Windows Media Center
Connect To Network Projector
Remote Desktop Assistance
Remote Desktop Connection
Bluetooth
Fax
Media Center Extender Service
Parential Controls
Tablet Pc Input Services
Windows Card Space
Windows Media Center Receciver Services
Windows Media Center Schedular Services
Narrator
Tablet Pc
Windows Easy Transfer
Thank you for your help keep up the excellent Work!!
  • 4 weeks later...
I've read alot of post in this topic that request to hack the Sh!t out windows 7. I hope that Windows Toolkit does'nt turn into a vLite RT7 hatchet. The operative word here is Toolkit.
Edited by dotfusion
anyone know of a topic regarding win toolkit and things that are safe to remove (or unused/unecessary for the most part)? my iso ballooned to over 7gb, and i've hardly done anything but add the update files etc.
@ccl0
I face the same issue as you do aswell. My iso has reached 7gb in size. However, removing components (If I remember correctly about a dozen or so) did not yeild muh more than a 1gb in savings. If it helps any, I removed all themes (except the default aero theme) and some other components like sticky notes, media player stuff, dvd maker and other non essential accessories.
Edited by dotfusion
I'm using Win Toolkit 1.4.0.77 to remove components from Win 8 Pro including System Restore, Remote Assistance, Remote Desktop, Tablet PC Components, Common Modem Drivers, Languages, Speech and Language Support. It runs well and is very stable. Remote Desktop still ran as Manual in services so I had to disable.
Please add these to the list for possible removal: To completely remove or totally disable Modern/Metro UI. Remove Windows Firewall, Family Safety, Fax, Security Center, Windows Defender, Windows Update.
I also tried a differnet Win 8 Pro install with the following additional tweaks which was not stable: Turn Off Windows Firewall (turned off in services runs Automatically), Disable UAC (can be renabled with restart), Disable Auto Restart on BSOD, Show the following Dekstop items: Computer, Networking, User Folder; Show Hidden Files and Folders, Show System Files and Folders. Not sure why.
Noticed the following Win 8 dependencies: UAC is needed to run Modern/Metro apps. Windows Firewall needs to be running to install Windows updates or Modern/Metro updates. But even with UAC and Windows Firewall turned on the install was not stable.
I've used Nlite quite extensively in the past on other OS's, and while it took some time to get up to speed with Win Toolkit; it's a great tool and I look forward to it's further development. I understand the way it goes about removing components is totally different and it doesn't leave a smaller footprint. But I appreciate it's ability to install only the Windows components I choose and not everything Microsoft thinks we should have running. Thanks Lego!
Edited by gahhrryy
  • 5 weeks later...
An option to remove Paint and WordPad, please! :)
Did I mention this program is awesome?
Bump for these two!
Edited by feet
  • 11 months later...
Whats about "not more needed stuff" for delete option?
I mean such files like never loading dlls, old pictures they no more used, double files/folders or empty folders..
Update:
Another wish: Option to remove the non-aero themes withouht basic and classic.
Or better: You can choose specific theme u want to remove at a time, - or:
Option to remove - nonaeros, classic, basic, customs, - entres.
I would want to keep customs, original windows aero (non local), basic and classic, - all other can be erased. :)
Edited by BrokenZer0
Another suggestion:
At start the CR mount the Image.. a "cancel"-button is need.
Wrong choose and then i have to wait for finishing mount or kill the process, not good. :/
Update:
Another suggestion:
"Load preset" for Component Remover is missing.
Update:
1+ remove-option Windows Defender
