Posted October 17, 201213 yr If I enter a command for each user created to run from runonce what I should do?If I use wim registry editor and load "users\default\ntuser.dat" and add my command to:HKEY_LOCAL_MACHINE\WIM_Default\Software\Microsoft\Windows\CurrentVersion\RunOnceWill it run every time a user is created?I Know that I could test but I'm in hurry to reinstall windows 7 in 3 Pc home network before my trip there ends.... And I'm not that familiar with 7. That is something I would have done in the same case for XP.Also I cannot figure how does the changes been saved? If I close registry editor and save the image will these just be saved?
October 17, 201213 yr If I enter a command for each user created to run from runonce what I should do?If I use wim registry editor and load "users\default\ntuser.dat"and add my command to:HKEY_LOCAL_MACHINE\WIM_Default\Software\Microsoft\Windows\CurrentVersion\RunOnce1. Will it run every time a user is created?I Know that I could test but I'm in hurry to reinstall windows 7 in 3 Pc home network before my trip there ends.... And I'm not that familiar with 7. That is something I would have done in the same case for XP.2. Also I cannot figure how does the changes been saved? If I close registry editor and save the image will these just be saved?1. Yes.2. Yes
October 17, 201213 yr Author Thanks for instant respond... you saved me maybe a lot of time testing in pour hardware pcs.Thanks also for fixing previously toolkit for larger DPI view. Now I can see all text in 125% view. Edited October 18, 201213 yr by stsaerox
October 20, 201213 yr Author Why this registry file won't run then ?Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce]"TITLE"="Setting Windows and applications"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce\096]"1"="C:\\ProgramData\\RegSets\\applyREg.bat"I've tried to run manually the batch file and runs ok. But I need to run this every time a user is created. Regsets folders contains .reg files with HKCU content, from each tweak is made and program setting which will run every time a user is created to provide currently suggested default settings... Edited October 20, 201213 yr by stsaerox
October 21, 201213 yr If you go to AIO Integrator > Tweaks > Add *.reg, it should add it for you.I think you also need to add it to WIM_Admin as well as WIM_Default.
October 21, 201213 yr Author Ok. I need some time to test it.Off topic:I've also added the files I've removed If you like to check in this topichttp://www.wincert.net/forum/topic/10500-solved-invisible-main-form/ Edited October 21, 201213 yr by stsaerox
October 21, 201213 yr @stsaerox, you need to fix your link in the OT spoiler. I'm assuming you did a straight copy/paste when you should of done a copy link address/paste.Cheers and Regards Edited October 21, 201213 yr by bphlpt
October 21, 201213 yr Author I've Found a funny solution at last. I've created in:%systemdrive%\users\DEFAULT\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StartupA file "RunREG.bat" which contains:@echo OFFecho Setting default windows and applications settingsfor %%a in (%allusersprofile%\RegSets\*.reg) do regedit /S "%%a"del "%userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\RunREG.bat"pauseAs you may already understand (just explaining for newbies) when a new user is created the personal folder will be copied from the default user containing the RunREG.bat which will run all registry files in the "%allusersprofile%\RegSets\" and delete itself!!! That means that windows won't find again the same file to run again and again. It is like a custom runonce.So next time I only have to add this on DVD root: Sources.rarI was searching all day and got sick of it.. I've tested one or two methods but most of I could not understand.Here are some of my findings. Solutions that may work also for anyone searching.http://www.symantec....ofile-user-windhttp://www.mombu.com...75259-last.htmlThe last two may contain a proper solution but I got really tired of it.... and I could not understand.
October 21, 201213 yr Author @stsaerox, you need to fix your link in the OT spoiler. I'm assuming you did a straight copy/paste when you should of done a copy link address/paste.Cheers and RegardsI've fixed it tested and working. Thank you.
