I had to abort unattended on my current image build, when I tried to put in the 30 day trial key for the unattended option it auto pasted one of my private key's the one in use on this pc, I cant use this as the image will be used by family and friends also ;)
This is on 1.4 so I will try this again on 1.5 when build is done to see if same thing happens.
I confirm the issue!
WinToolkit pasted my own Key and it was not possible to correct it in the first tab (Main) of unattended-creator, only in the editor.
An import of the corrected autounattend.xml shows then the trial key in the Main-tab.
Issue with both v1.4.0.77 and 1.5.0.1_Test4; with up to v1.4.0.75 no issue.
Regards, Thiersee
Edited by Thiersee
.... by default it should be unticked. Once ticked, it will prompt you to either keep the value or enter your own.
That's right, but if you tick it and put a default (trial) code in, the Unattended Creator does NOT keep it and put in the code from the current machine again!
You can correct it manually in the editor and save it, then it remains.
As I wrote this behavior was not present until v1.4.0.75.
Edited by Thiersee
