Posted October 22, 201212 yr HiFound a little bug in 150-1_test4 All in One Integrator - Advanced - Files.I was not able to add "Hosts" File.Trying to save this "Save to: %SystemDrive%\Windows\System32\drivers\etc\HOSTS" the App shows the Message "Add a File name and Extension to Save to Path".With 140xx this Problem did not exist.
October 23, 201212 yr If this is bugged, then I also vote for a fix ASAP. A very good registry tool - jv16 PowerTools - has a ''block malicious websites'' tool, that you can read about here, that adds to the hosts file such links from a known public database.So it's really important.
October 25, 201212 yr Another issue occurs now in test 12. You can see here the screenshot. It says the savepath must start with %SystemDrive%, although I've introduced it.Not to mention the default location (save path) or preset in Wintoolkit when I load the hosts file is ''%SystemDrive%\Windows\System32\hosts''; it should be ''%SystemDrive%\Windows\System32\drivers\etc'', and hopefully will work without errors in the next build.
October 25, 201212 yr Fixed the error message. (Uploaded test 13)It will always default to System32 no matter which file you choose. If you would like that changing, then put it in the request forum
October 25, 201212 yr Ok, great! No need for a request, I thought the preset was linked only to the hosts file. My mistake.
