Posted October 23, 201212 yr Tried versions 1.4.0.77 and 1.4.0.75.Both unable to connect to the update servers.The old version shows the update notification,so its not a internet connectivity issue.Tried disabling antivirus and firewall (Comodo Internet Security Pro).Everything worked fine yesterday before MacRip updated his server (aded new and removed old updates)http://hotfix2.cesidian.info/
October 23, 201212 yr I think McRip has changed some server settings as the pings returned error 500, however i've updated my code and now detects if the server is online correctly..HOWEVER: When you select an item from the list it returns an error 403: Forbidden, so McRip has definitely changed some settings. This is out of my hands.EDIT: I've managed to fix the second issue as well, so McRip doesn't need to change anything
October 23, 201212 yr Same here. Win Toolkit .77 Dialog saysServers OfficeNeither McRip or SoloR Update servers seem to be active. This error will also occur if you have no internet connection or if you are behind a proxy server.I would post a screenshot but it appears the ImageShack servers are down aswell. lol. 403 Forbiden. :lock:Tested on three machines. No rush just though I report that the seervers appear to be still offline. Cheers!
October 24, 201212 yr As i said above, the error is because some server settings have been changed and it has already been fixed (beta).EDIT: KUC server seems to be down now, despite pinging fine :/
October 24, 201212 yr @compstuffI can confirm that the update catalog servers are working in the Win Toolkit1.5.0-1 beta. It's quite impressive. I intend to use it in the interim. Maybe play around with some of the tweaks and do some beta testing.I'm sure the .77 catalog error will be resolved soon enough. Regards. Edited October 24, 201212 yr by dotfusion
October 24, 201212 yr Author V 1.5.0.1Thanks for adding KUC to the update catalog :dancing:Only KUC is avilable.MacRip is still not working in the toolkit. It is online at the time of this post. :doh: Edited October 24, 201212 yr by amaltom61
October 24, 201212 yr Author As i said above, the error is because some server settings have been changed and it has already been fixed (beta).EDIT: KUC server seems to be down now, despite pinging fine :/KUC and MacRip are ONLINE.It is not fixed in the latest 1.5.0.1 beta 10(At least not working for me)KUC is running fine
October 24, 201212 yr McRip is really having server issues. For some users the server is online, for other it isn't. So no need to bug Lego with this issue, it probably makes him waste more time than needed for a non-existent Win Toolkit problem.
October 24, 201212 yr McRip servers are fine when using the latest beta, i think he's just made some config changes to his server.McRip server don't work in the latest stable build 1.4.0.77
October 24, 201212 yr Hello guysI order to secure the server I had to harden it on a very high level. Since a few days, according to my logs, people tried to hack the server or ddos the server, cross site scripting and all this crap. So I had to block most of the proxy servers around the globe, block many user agents, block several IP-ranges that were trying to abuse the server.Also at the moment Win7 Toolkit says the server is down, but it's not. I don't know what kind of user agent this tool uses.If you think you have been blocked send me your IP over pm only. I will check this IP first. If the IP is ok, I will add it to the allow list (IP-range).I am very sorry for this, but I am totally ****ing fed up with people who try to hack the server.If you find your IP on that list, so let me know. That's on htaccess level. Additionally I had to configure some stuff that I don't want to describe here.http://www.mcrip.org/list.txt
October 24, 201212 yr v1.4.0.x doesn't have a user agent, v1.5.0 does which i won't post publicly just in case. But feel free to PM me McRip.I don't blame you for trying to secure your server.
October 24, 201212 yr Investigating now serg, what happens exactly?Also that should have gone in its own topic.UPDATE: It shows as red but it integrates fine, should be fine in beta test 12.
October 24, 201212 yr Hello! I can not integrate the update Windows6.1-KB2592687-x86.msu.Wrong Topic.However, if it is in Additional Folder, just do not integrate this one.Additional information on http://support.microsoft.com/kb/2592687/en-us
October 24, 201212 yr Hello! I can not integrate the update Windows6.1-KB2592687-x86.msu.If DISM cannot integrate it, then very likely it's not integrable...Also, for me (Home Premium x86), that ''update'' (it's more of an ehancement), the same as the related 2574819 update, cannot be installed on a live system.Also, Remote Desktop Protocol is a very server-oriented feature, for home-users third-party entry-level utilities like TeamViewer are recommended.
October 24, 201212 yr It integrates fine, as i've said MANY MANY MANY MANY times. If it shows red, making sure to check the 'Integrated' tab, it was right at the very top. I've now made it show green.
October 24, 201212 yr It integrates fine, as i've said MANY MANY MANY MANY times. If it shows red, making sure to check the 'Integrated' tab, it was right at the very top. I've now made it show green.It may be integrable, but it surely isn't installable. Not for me that is, on a live system.
October 25, 201212 yr Your probably behind a proxy, wait until McRip replies. There's nothing i can really do about it anyway as I can't make Win Toolkit bypass firewalls, etc... otherwise that would be illegal.
