jaynbe Posted October 25, 2012 Posted October 25, 2012 (edited) Adobe Reader XI AddOns ENU, FRA and NLDRepacked installer with removed VC++ Runtimesand disabled AdobeARM service startup.Installers require VC9 and VC10 prior to install.AddOns integrate with RVMI, nLite and DX-Integrator.Installers can be found by unpacking the AddOns.Available multimode switches for all Windows:silent: " -gm2 -qn"pasive: " -qb"live install with GUIAdobe_Reader_XI.0.6_ENU_AddOn.cab MD5: E57E97E381CE360C53BF52A726B7FC22Size: 40,29 MBUrl.: http://www.sendspace.com/file/t8hjno Adobe_Reader_XI.0.6_FRA_AddOn.cab MD5: 69DD4929CA2C4D569B24627009419442Size: 40,28 MBUrl.: http://www.sendspace.com/file/3ghqxd Adobe_Reader_XI.0.6_NLD_AddOn.cab MD5: F7E523C9AC7AA226AB0BDB01349F5C78Size: 40,92 MBUrl.: http://www.sendspace.com/file/b8hp8f Edited April 26, 2014 by jaynbe updated title Quote
SunLion Posted October 25, 2012 Posted October 25, 2012 (edited) Thank you for sharing. How to make the addon in pt-BR, please? :worthy: Edited October 25, 2012 by xspeed_one Quote
yogurt Posted October 25, 2012 Posted October 25, 2012 Thanks for this addon. Will test in VM and report my findings. However I think I'll stick with Ricks [Tweaked] Version X. Quote
Whatsup Posted October 27, 2012 Posted October 27, 2012 Thank you jaynbe.ill take the NLD version^^ :music: thx men!! Quote
jaynbe Posted January 8, 2013 Author Posted January 8, 2013 Updated to Adobe Reader XI 11.0.01 hotfix: AdbeRdrUpd11001.msp (20130108) MS-VC10 required for this repacked installer. Quote
jaynbe Posted February 20, 2013 Author Posted February 20, 2013 Updated to Adobe Reader XI v.11.0.02 hotfix: AdbeRdrSecUpd11002.msp (20130220) VC++ Runtimes required for this installer. Quote
Ctrl Posted February 23, 2013 Posted February 23, 2013 thank you :cap: if the next release,, please remove AdobeARM from Startup... :prop: Quote
jaynbe Posted May 14, 2013 Author Posted May 14, 2013 Updated to Adobe Reader XI v.11.0.3 hotfix: AdbeRdrUpd11003.msp (20130514) with AdobeARM service disabled VC++ Runtimes required for this installer Quote
Ctrl Posted May 14, 2013 Posted May 14, 2013 thanks you very much jaynbe for AdobeARM service disabled :worthy:downloading............................................ Quote
jaynbe Posted September 12, 2013 Author Posted September 12, 2013 Updated to Adobe Reader XI v.11.0.4 hotfix: AdbeRdrUpd11004.msp (20130910) with AdobeARM service disabled VC++ Runtimes required for this installer Quote
jaynbe Posted October 9, 2013 Author Posted October 9, 2013 (edited) Updated to Adobe Reader XI v.11.0.5 hotfix: AdbeRdrSecUpd11005.msp (20131009) with AdobeARM service disabled VC++ Runtimes required for this installer Edited October 9, 2013 by jaynbe Quote
jaynbe Posted January 15, 2014 Author Posted January 15, 2014 Updated to Adobe Reader XI v.11.0.6 hotfix: AdbeRdrUpd11005.msp (20140114) with AdobeARM service disabled VC++ Runtimes required for this installer Quote
koim Posted January 17, 2014 Posted January 17, 2014 there seems to an error with your latest packages (at least with the french and english ones) VC++ runtimes are installed on my system and your package version 11.0.05 works fine Quote
jaynbe Posted January 19, 2014 Author Posted January 19, 2014 I can't reproduce the error you have.I installed without problem both english and french on Vista 32bit and Win 7-64bit.Are you sure that the Vc Runtimes are correctly installed before the Adobe Reader installer runs? Are there any others experiencing this error? Quote
koim Posted January 20, 2014 Posted January 20, 2014 (edited) thought my somewhat outdated vc runtimes pack was at fault, so I uninstalled them, DLed them straight from microsoft.com, installed them => still the same error I opened your installer's msi, removed a few lines mentioning msvcr90.dll in "FeatureComponents" and "ModuleComponents" (I have no knowledge about msi editing, so I have no idea what I actually did) => works like a charm. I tried to open a pdf and it worked as well I took a quick look at your 11.0.5 installer's msi for reference, it found only one entry with "msvcr90.dll", while it found several in the 11.0.6's msi. once again, I have little to no clue about msi editing, so I don't know if it's the source of the problem or just my paranoïd mind at work Edited January 20, 2014 by koim Quote
efdeb Posted April 13, 2014 Posted April 13, 2014 Hi, French XI.0.6 addon seems no more available.could you please reupload ?Many thanks ! Quote
Igloop Posted February 6, 2016 Posted February 6, 2016 On 1/20/2014 at 4:36 PM, koim said: thought my somewhat outdated vc runtimes pack was at fault, so I uninstalled them, DLed them straight from microsoft.com, installed them => still the same error Same here. Maybe it's just out of date? Quote
