Posted October 25, 201212 yr Fail in WinToolkit v150-1_Test19 & WinToolkit v1.4.0.77... with version 1.4.0.75 works perfect... Error in Copy to clipboard and Save to text file too...Regards... ;-)Exception:Microsoft Windows [Versi¢n 6.1.7601]Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.C:\temp\Windows 7 Toolkit\Beta>Set SEE_MASK_NOZONECHECKS=1C:\temp\Windows 7 Toolkit\Beta>imagex /Info "L:\sources\Install.swm"ImageX Tool for WindowsCopyright (C) Microsoft Corp. All rights reserved.Version: 6.1.7601.21716WIM Information:----------------Path: L:\sources\Install.swmGUID: {67a059fa-42be-4b76-8f53-19cbf61aadb5}Image Count: 3Compression: LZXPart Number: 1/2Attributes: 0x18 Relative path junction SpannedAvailable Image Choices:------------------------<WIM><TOTALBYTES>4716233098</TOTALBYTES><IMAGE INDEX="1"><DIRCOUNT>10811</DIRCOUNT><FILECOUNT>63075</FILECOUNT><TOTALBYTES>11880918137</TOTALBYTES><CREATIONTIME> <HIGHPART>0x01CB8901</HIGHPART> <LOWPART>0xEF63352E</LOWPART></CREATIONTIME><LASTMODIFICATIONTIME> <HIGHPART>0x01CDAAEA</HIGHPART> <LOWPART>0x108D8ACA</LOWPART></LASTMODIFICATIONTIME><WINDOWS> <ARCH>0</ARCH> <PRODUCTNAME>Sistema operativo Microsoft® Windows®</PRODUCTNAME> <EDITIONID>Starter</EDITIONID> <INSTALLATIONTYPE>Client</INSTALLATIONTYPE> <HAL>acpiapic</HAL> <PRODUCTTYPE>WinNT</PRODUCTTYPE> <PRODUCTSUITE>Terminal Server</PRODUCTSUITE> <LANGUAGES> <LANGUAGE>es-ES</LANGUAGE> <DEFAULT>es-ES</DEFAULT> </LANGUAGES> <VERSION> <MAJOR>6</MAJOR> <MINOR>1</MINOR> <BUILD>7601</BUILD> <SPBUILD>22099</SPBUILD> <SPLEVEL>1</SPLEVEL> </VERSION> <SYSTEMROOT>WINDOWS</SYSTEMROOT></WINDOWS><NAME>Windows 7 Starter</NAME><DESCRIPTION>Windows 7 STARTER</DESCRIPTION><FLAGS>Starter</FLAGS><HARDLINKBYTES>3116159044</HARDLINKBYTES><DISPLAYNAME>Windows 7 Starter</DISPLAYNAME><DISPLAYDESCRIPTION>Windows 7 Starter</DISPLAYDESCRIPTION></IMAGE><IMAGE INDEX="2"><DIRCOUNT>11191</DIRCOUNT><FILECOUNT>62789</FILECOUNT><TOTALBYTES>9826374549</TOTALBYTES><CREATIONTIME> <HIGHPART>0x01CB8901</HIGHPART> <LOWPART>0xEF63352E</LOWPART></CREATIONTIME><LASTMODIFICATIONTIME> <HIGHPART>0x01CDAAEA</HIGHPART> <LOWPART>0x156340DA</LOWPART></LASTMODIFICATIONTIME><WINDOWS> <ARCH>0</ARCH> <PRODUCTNAME>Sistema operativo Microsoft® Windows®</PRODUCTNAME> <EDITIONID>Professional</EDITIONID> <INSTALLATIONTYPE>Client</INSTALLATIONTYPE> <HAL>acpiapic</HAL> <PRODUCTTYPE>WinNT</PRODUCTTYPE> <PRODUCTSUITE>Terminal Server</PRODUCTSUITE> <LANGUAGES> <LANGUAGE>es-ES</LANGUAGE> <DEFAULT>es-ES</DEFAULT> </LANGUAGES> <VERSION> <MAJOR>6</MAJOR> <MINOR>1</MINOR> <BUILD>7601</BUILD> <SPBUILD>17932</SPBUILD> <SPLEVEL>1</SPLEVEL> </VERSION> <SYSTEMROOT>WINDOWS</SYSTEMROOT></WINDOWS><NAME>Windows 7 PROFESSIONAL</NAME><DESCRIPTION>Windows 7 PROFESSIONAL</DESCRIPTION><FLAGS>Professional</FLAGS><HARDLINKBYTES>3389925227</HARDLINKBYTES><DISPLAYNAME>Windows 7 Professional</DISPLAYNAME><DISPLAYDESCRIPTION>Windows 7 Professional</DISPLAYDESCRIPTION></IMAGE><IMAGE INDEX="3"><DIRCOUNT>16558</DIRCOUNT><FILECOUNT>86765</FILECOUNT><TOTALBYTES>17456531755</TOTALBYTES><CREATIONTIME> <HIGHPART>0x01CB8936</HIGHPART> <LOWPART>0x131F339A</LOWPART></CREATIONTIME><LASTMODIFICATIONTIME> <HIGHPART>0x01CDAAEA</HIGHPART> <LOWPART>0x44C2B78D</LOWPART></LASTMODIFICATIONTIME><WINDOWS> <ARCH>9</ARCH> <PRODUCTNAME>Sistema operativo Microsoft® Windows®</PRODUCTNAME> <EDITIONID>Professional</EDITIONID> <INSTALLATIONTYPE>Client</INSTALLATIONTYPE> <HAL>acpiapic</HAL> <PRODUCTTYPE>WinNT</PRODUCTTYPE> <PRODUCTSUITE>Terminal Server</PRODUCTSUITE> <LANGUAGES> <LANGUAGE>es-ES</LANGUAGE> <DEFAULT>es-ES</DEFAULT> </LANGUAGES> <VERSION> <MAJOR>6</MAJOR> <MINOR>1</MINOR> <BUILD>7601</BUILD> <SPBUILD>22099</SPBUILD> <SPLEVEL>1</SPLEVEL> </VERSION> <SYSTEMROOT>WINDOWS</SYSTEMROOT></WINDOWS><NAME>Windows 7 Professional x64</NAME><DESCRIPTION>Windows 7 PROFESSIONAL</DESCRIPTION><FLAGS>Professional</FLAGS><HARDLINKBYTES>4945434269</HARDLINKBYTES><DISPLAYNAME>Windows 7 Professional</DISPLAYNAME><DISPLAYDESCRIPTION>Windows 7 Professional</DISPLAYDESCRIPTION></IMAGE></WIM>C:\temp\Windows 7 Toolkit\Beta>exit Edited October 25, 201212 yr by alfreire
October 25, 201212 yr Do you have any dll files in the WinToolkit directory?Fixed the WIM Merger issue.
October 26, 201212 yr Author Do you have any dll files in the WinToolkit directory?Fixed the WIM Merger issue.No, there is not dll in WinToolkit directory...Regards... ;-)
October 26, 201212 yr I managed to replicate the issue, still not sure what's causing it. Can't really check until I finish University.
