It seems this is linking to the x86 version instead of the x64 version :(
This is the right link:
http://www.xptsp.com/tools/get.php?url=Vista/x64/x64_MegaPack.7z
By example, in All-In-One Integrator... in Updates I can't sort list by name, description, size or other, clicking in column tittle...
Regards... ;-)
post-27023-0-57502100-1351234540_thumb.j
Edited by alfreire
The reason they don't have sort-able column headers is because some columns don't get sorted properly i.e. Size and Date (anything numerical). It also a bit pointless as it won't affect the integration.
Ok, I understand... :)
Thank you... ;-)
Just so you know they are already in date order anyway as the KBxxxxx increases with each new update :) There's no point integrating by file size either. All of the important updates which require being integrated first such as IE9, gets moved to the top so Win Toolkit integrates it first.
You requested a nice feature but at the end of the day when it comes to integration, it's a bit pointless and adds more problems than solves. Sorry.
P.S: The sort buttons on the left hand size do effect integration order. Feel free to PM me if you want me to unlock this topic and debate it further.
