Thiersee Posted October 27, 2012 Posted October 27, 2012 (edited) Hi Lego,there is something wrong!On starting 1.5.0.1_Test21 appears 1.4.0.1; the program's size is significantly smaller: 7,2 MB against 9,2 Mb of Test20.And AddOn-Tab is empty (and no errors). Edited October 27, 2012 by Thiersee Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 Also, a very small issue in beta / test 21 - it bugs me about updating to ''stable'' 1.4.0.77. Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 My small update issue was fixed. And probably the smaller size ain't a problem, but a feature. Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 I found a bug with the update checker to temporarily changed the WT version to 1.4 to test if it works, forgot to change it back Quote
Thiersee Posted October 27, 2012 Author Posted October 27, 2012 Does it mean, it is version 1.5.0.1, only the display is 1.4.0.1? Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 Yeah. I didn't upload v1.4 by mistake, i just manually lowered it version number to check the update notification feature. Besides i hope you like it since that is the first time you seen the new method (system tray tooltip) Quote
Thiersee Posted October 27, 2012 Author Posted October 27, 2012 OK!The only remaining (for me) problem is the error with the AddOns... Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 Can you do me a favour and add Internet Explorer 9 MSU or CAB file to the updates list. The name should be 'Internet Explorer 9' if that fails it will revert back to the filename.It will tell me if it's the addon or extraction code being the problem Also are you using x86 or x64 Windows?EDIT: I'm uploading test 23 now, it should output a extractiondata.txt when you try and add an addon. Please tell me what it says Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 (edited) I'm quicker than the wind! The info needed regarding addons below (I'm on x86 7 HP and trying to integrate the x64 addons on an x64 7 UL):Microsoft Windows [Version 6.1.7601]Copyright © 2009 Microsoft Corporation. All rights reserved.C:\Users\Administrator\Desktop\WinToolkit150-1_Test23>Set SEE_MASK_NOZONECHECKS=1C:\Users\Administrator\Desktop\WinToolkit150-1_Test23>"C:\Users\Administrator\Desktop\WinToolkit150-1_Test23\7z.exe" x "C:\WinToolkit_Temp\Temp_19484.WA" Tasks.txt -o"C:\WinToolkit_Temp\AddonT" -yC:\Users\Administrator\Desktop\WinToolkit150-1_Test23>exit Edited October 27, 2012 by RicaNeaga Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 Thanks Rica, how about the IE9 thing i mentioned above please? Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 The update is added to the list with the named changed from ''IE9-win7'' to ''Internet Explorer 9'' as you can see attached. Am I supposed to do anything else? The problems with addons is that they won't load at all... Quote
Thiersee Posted October 27, 2012 Author Posted October 27, 2012 (edited) Even if I don't really understand, here two screenshots.1 AddOn_error_cab.jpg2 AddOn_error_msu.jpgI tried it with the file IE9-win7_x64.cab and .msu (nirmally I use IE9.exe).Edit: I'm using x64 Edited October 27, 2012 by Thiersee Quote
dareckibmw Posted October 27, 2012 Posted October 27, 2012 I get the same thing as RicaNeaga except i am on x86 Quote
Thiersee Posted October 27, 2012 Author Posted October 27, 2012 (edited) Same extractiondata.txt for me.P.S.: Don't forget to turn back your watch tonight Edited October 27, 2012 by Thiersee Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 Test 24AB should be uploaded now, please tell me if either WinToolkitA or WinToolkitB works please Thanks, but everything is done automagically :fun: Quote
Thiersee Posted October 27, 2012 Author Posted October 27, 2012 (edited) 24B works and shows AddOn, but the preset loading takes a very long time, compared with v19; new AddOn are loaded too.v19: 15secv24B: 90sec!Edit: I'll try tomorrow, if this problem is solved with v24B. Edited October 27, 2012 by Thiersee Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 Nope the addons problem still persists with both.For A, here is the error code...Microsoft Windows [Version 6.1.7601]Copyright © 2009 Microsoft Corporation. All rights reserved.C:\Users\Administrator\Desktop\WinToolkitAB150-1_Test24\WinToolkitA>Set SEE_MASK_NOZONECHECKS=1C:\Users\Administrator\Desktop\WinToolkitAB150-1_Test24\WinToolkitA>"C:\Users\Administrator\Desktop\WinToolkitAB150-1_Test24\WinToolkitA\7z.exe" x "C:\WinToolkit_Temp\Temp_915036.WA" Tasks.txt -o"C:\WinToolkit_Temp\AddonT" -yC:\Users\Administrator\Desktop\WinToolkitAB150-1_Test24\WinToolkitA>exitFor B, I don't have any, only a screenshot... Quote
RicaNeaga Posted October 27, 2012 Posted October 27, 2012 Once again, I am running a x86 Home Premium Windows 7, and trying to integrate the x64 addons in a x64 windows 7 Ultimate.I'm not an expert, but I think you've changed how addons are decompressed, and the new tool maybe it more rigid. I think. :g: Quote
Legolash2o Posted October 27, 2012 Posted October 27, 2012 I feel stupid for including an x64 7z.exe. AHHHHHHHHHHHH, I'm experimenting now with a x86 7z in VirtualBox. Quote
dareckibmw Posted October 27, 2012 Posted October 27, 2012 Once again, I am running a x86 Home Premium Windows 7, and trying to integrate the x64 addons in a x64 windows 7 Ultimate.I'm not an expert, but I think you've changed how addons are decompressed, and the new tool maybe it more rigid. I think. :g:I still have the same errors as You with an A & B, and I am running Ultimate x86. Quote
dareckibmw Posted October 27, 2012 Posted October 27, 2012 (edited) 15 addons loaded up along with 97 hotfixes! so far so good! I'll let it finish and run it in vmware. Thanks!I don't recall this name in my hotfixes? this is new. oh, I see it now. nvm Edited October 28, 2012 by dareckibmw Quote
dareckibmw Posted October 28, 2012 Posted October 28, 2012 On first run all 15 addons were integrated fine.In second & third I got an error with one of them. Quote
Legolash2o Posted October 28, 2012 Posted October 28, 2012 It should have produced an error log with that message, can you attach it please Quote
