EaseUS Partition Master Professional Edition is an ALL-IN-ONE partition solution and disk management utility. It allows you to extend partition, especially for system drive, settle low disk space problem, manage disk space easily on MBR and GUID partition table (GPT) disk under 32 bit and 64 bit Windows 2000/XP/Vista/Windows 7 SP1/Windows 8.
The most popular hard disk management functions are brought together with powerful data protection including: Partition Manager, Disk & Partition Copy Wizard and Partition Recovery Wizard. Moreover, you can create bootable CD/DVD in case of system boot failure.
The most common partition problem for computer users is that the Windows system partition runs out of space, the Windows system partition needs to be expanded. But for most users, changing partition structure requires Windows operating system reinstallation and formatting. The built-in partition manager function of EaseUS Partition Master is right to meet the need. It can expand the Windows system partition without Windows reinstallation and data loss.
Furthermore, increasing volumes of information requires companies to make better use of their hard drive capacity, so the need to reasonably resize, move, split, merge the partitions is more important than ever.
Any operations with hard drives are critical, so the reliability of performance is one of the most important requirements when choosing partition software. EaseUS Partition Master is not only reliable itself but also integrated with the Disk & Partition Copy Wizard and Partition Recovery Wizard to ensure 100% data security.
The Disk Copy feature is designed to copy your entire disk to a new hard drive. There was a time when upgrading to a new hard drive meant hours of downloading your data, applications, and operating systems to disks; then more hours of reinstalling everything to the new hard drive. With Disk and Partition Copy Wizard, you can quickly and easily create an exact copy of your hard disk, including the operating system, applications, preferences, settings, and data.
Partition Copy is designed to back up your partitions before the partition operations applied to the hard disk to prevent any data lost from program error or some other accidental incidents.
Disk and Partition Copy Wizard can also copy dynamic volume safely to basic disk and resize it indirectly.
Partition Recovery Wizard included into EaseUS Partition Master completely protects your partition, allowing you to recover deleted or lost partitions due to a hardware or software failure. Together with Partition Manager, Copy Wizard and other useful features, you can do mostly anything you want on hard disk with EaseUS Partition Master.
You must have this Partition Recovery Wizard if you care for safety of your partition and wish to be fully armed and ready for any personal, hardware or software failure, virus attack, or hacker's intrusive destruction partition loss. You can recover the deleted or lost partition with Partition Recovery Wizard - a reliable partition recovery tool.
We are giving away 5 Easeus Partition Master Professional licenses worth $39.95 per license.
Giveaway NOTE (please read!)
To enter this giveaway please LIKE WinCert.net on FACEBOOK or add a plus on GOOGLE+ pages, add us to your circles and post your FULL NAME HERE.
If you have already Liked us on Facebook or Google+ pages, then just post your FULL NAME HERE and you will automatically enter the giveaway.
Giveaway will end on November 3rd, 2012 when we will announce our lucky winners. Please remember to follow the rules of this giveaway or your request won't be valid.
