Posted October 28, 201212 yr Two questions:1) Where is the difference in integrating IE9 as .EXE or .msu/cab?2) What does it mean in WT "blue highligth" in the update-tab?TNX, Thiersee
October 28, 201212 yr 1) no difference2) I don't remember setting a blue colour in the updates tab :/
October 30, 201212 yr Quote What does it mean in WT "blue highligth" in the update-tab?Thiersee, perhaps you mean the blue highlighted entries under the drivers tab?If so, They are duplicate files (same md5sum)
November 30, 201212 yr Author On 10/30/2012 at 7:16 PM, dotfusion said: Thiersee, perhaps you mean the blue highlighted entries under the drivers tab?If so, They are duplicate files (same md5sum)No, I mean in the Updates-Tab; may be the meaning is the same.
December 1, 201212 yr That looks like it was the last entry you clicked on and it has been highlighted with blue.But, what does pink mean?? Integration Failed? Edited December 2, 201212 yr by ElmerBeFuddled
December 12, 201212 yr Pink means Win Toolkit could not detect if it integrated correctly, however check the 'Integrated' tab at the end.Also please report any pink KB numbers please
December 13, 201212 yr Hi Lego,Might not be the right place to answer, but that never stops me!! These are the four updates that I now run in my setupcomplete file as they've never seemed to "take".KB2533552-x64.msu You know about this one I believe.KB2592687-x64.msuKB2603229-x64.msuKB917607-x64.msu This is for compatibility with the older Windows help (.hlp) files. Edited December 13, 201212 yr by ElmerBeFuddled
December 13, 201212 yr Author On 12/13/2012 at 1:07 AM, ElmerBeFuddled said: Hi Lego,Might not be the right place to answer, but that never stops me!! These are the four updates that I now run in my setupcomplete file as they've never seemed to "take".KB2533552-x64.msu You know about this one I believe.KB2592687-x64.msuKB2603229-x64.msuKB917607-x64.msu This is for compatibility with the older Windows help (.hlp) files.KB2533552: WTK puts this one under Silent-Installer-SFX; this patch is present under Windows-Update, even if it has been already installed.KB2592687: WTK puts this one under Silent-Installer-SFX; for this patch to install you need KB2574819 installed (WTK puts this one in the prerequisite).KB2603229: WTK puts this one under Silent-Installer-SFX.Regards, Thiersee
