Can you add "Get drivers from current Sistem", or "Backup current drivers from Sistem" to integrated with Win Toolkit...? :P
Regards... ;-)
Do this, in the meantime. it's real simple and clean. Download Double Driver and backup your live system drivers. DD will organize all your current drivers and in a nicely organized folder of your choosing. The only thing left to do after that is to integrate the backup with Win Toolkit AIO integrator. If you have any questions, just reply to this thread and I'll fill in the gabs if I can.
Edited by dotfusion
Do this, it's real simple and clean. Download Double Driver, backup your live system drivers, and DD will organize all your current (Live) drivers and in a nicely designated target directory/folder of your choice. The only thing left to do after that is integrate what you backed up in the drivers tab of Win Toolkit. If you have any questions, doubt or concerns, just reply to this thread and I'll fill in the gabs if I can.
Thanks by your answer... Double Driver it's a good Free program...
Regards... ;-)
