Posted November 3, 201212 yr Hi Lego,I will be very happy if you can add:- an option to have MS Update enabled (instead of Windows Update) done see this- an option to disable system restore done see this- an option to disable Windows Defender edit: not the service.- an option to not not show the "send to recycle bin" confirmation when you hit the "supp" key.Thank you ! Edited October 26, 201311 yr by mooms
November 3, 201212 yr ....- an option to have MS Update enabled (instead of Windows Update)...Sorry for asking!What is the difference between Windows- and Microsoft-Update?TNX, Thiersee
November 3, 201212 yr Author Windows Update is only for Windows, Microsoft Update is for all Microsoft products.
November 3, 201212 yr Author Oh, i see, so disabling the service is enough ?Thanks dareckibmwedit: that's not the same thing!Just tested, if you disable the service, you can't install Malicious Software Removal Tool from Windows/MS Update, and Windows Defender throws an error if you try to configure it.The latter one is rather logical and expected, but the former is unexpected and proves that MRT relies on Windows Defender service.Disabling the service is too much, disabling only the software is the better option i think. (It can be easily re-enabled by an average user, not the service, and errors frighten the average user) Edited November 3, 201212 yr by mooms
November 3, 201212 yr Use autounattend.xml to disable it and system restore (the toolkit may have those options in unattended)
November 5, 201212 yr Author Thanks Ricks but i don't want to use autounattend.xml because i want to be able to choose any editions of win7 at install.
November 5, 201212 yr You can use autounattended and still have the option, just dont fill out certain parts
November 6, 201212 yr Author Even if I merge X86 and X64 images ? It's good to know i will try. Thanks !
November 11, 201212 yr Hi Lego,I will be very happy if you can add:- an option to have MS Update enabled (instead of Windows Update)Thank you !If it's possible, thx
November 23, 201212 yr If it's possible, thxNot possible, as this component gets directly downloaded from MS servers if enabled.Its not built in feature, so there is nothing you can enable in offline image.Workaround is to integrate something from Microsoft as Installer (Silverlight, NET framework, Security Essentials, etc) and if network is available during install, it gets downloaded and enabled automatically. Edited November 23, 201212 yr by Etz
November 23, 201212 yr Author It's certainly possible if we know what is done when you activate MS Update.An addon would be great.
November 23, 201212 yr I`m actually doing a clean modified install this weekend, so I could actually do Packet Capturing to actually see what is getting downloaded and from where, when this option is activated by hand.
November 23, 201212 yr Author next time i install Windows 7 i will do a capture with regshot, but i don't know if it will be enough.
November 23, 201212 yr Last week I build a Win7-Prof-DVD with all the McRip-Updates with a couple of additional updates (prä-SP1 for post-SP1 and windows-Update-Agent); after Win-installation I installed Microsoft Office 2010; after this I checked Windows-Update and I got a couple of updates for windows and ALL the updates for other Microsoft products (in my case Office 2010).@EtzWorkaround is to integrate something from Microsoft as Installer (Silverlight, NET framework, Security Essentials, etc) and if network is available during install, it gets downloaded and enabled automatically.This is not enough I did an install together with Security Essentials, but the Box for "Other Microsoft Updates" was still present.Regards, Thiersee
November 23, 201212 yr For me it is usually enough to install Silverlight via WinToolkit Installer to get it activated... :g:
November 23, 201212 yr If you install silverlight you can probably run this to enable it"%ProgramFiles%\Microsoft Silverlight\5.1.10411.0\Silverlight.Configuration.exe" -enableMU
November 26, 201212 yr Author Its just a few reg entries I thinknext time i install Windows 7 i will do a capture with regshot, but i don't know if it will be enough.I have tested a capture with Regshot before and after enabling MS Update:As i was afraid, it's not just some registry keys.I don't use silverlight so i'm still looking for an other way.edit:I have attached the capture if someone want to look at it.Hive.rar Edited November 26, 201212 yr by mooms
October 26, 201311 yr It's certainly possible if we know what is done when you activate MS Update.An addon would be great. Discovered a way to do it... Set ServiceManager = CreateObject("Microsoft.Update.ServiceManager")ServiceManager.ClientApplicationID = "My App"'add the Microsoft Update Service, GUIDSet NewUpdateService = ServiceManager.AddService2("7971f918-a847-4430-9279-4a52d1efe18d",7,"") Save as *.vbs and run it for example with SetupComplete.cmd or create addon.It will enable Microsoft Update instead of plain windows Update.
October 26, 201311 yr Author Thank you Etz, I've made a sfx for the fun and it works: MU.zip System restore can be disabled with Autounattend.xml : (here example for AiO x86/x64)<settings pass="specialize"> <component name="Microsoft-Windows-SystemRestore-Main" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableSR>1</DisableSR> </component> <component name="Microsoft-Windows-SystemRestore-Main" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableSR>1</DisableSR> </component> </settings> If someone found a way to not not show the "send to recycle bin" confirmation when you hit the "supp" key it will be great.
October 26, 201311 yr Thank you Etz, I've made a sfx for the fun and it works: MU.zip System restore can be disabled with Autounattend.xml : (here example for AiO x86/x64)<settings pass="specialize"> <component name="Microsoft-Windows-SystemRestore-Main" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableSR>1</DisableSR> </component> <component name="Microsoft-Windows-SystemRestore-Main" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <DisableSR>1</DisableSR> </component> </settings> Well, it doesnt work on windows 8.1, System restore still runs as usual...debugging at the moment, why...Still it works fine on Windows 7, dont know about Vista and Windows 8 though...as I skipped those... Edited October 26, 201311 yr by Etz
October 26, 201311 yr It does work on windows 8.1, the only thing is for some reason when you install certain updates it turns itself back on
October 26, 201311 yr It does work on windows 8.1, the only thing is for some reason when you install certain updates it turns itself back on Ok, thanks for the tip, then it must be one of those: KB2883200KB2884101KB2884846KB2886439KB2894029KB2894179KB2895219KB2896459KB2901549 Which I integrate into image... At least now, I know, why it didnt seem to work... Edited October 26, 201311 yr by Etz
