Exception:
Tool Name: All-In-One Integrator (1.4.0.77) (Windows 7 ULTIMATE)
Image Name: Windows 7 ULTIMATE
Argument: /Unmount "C:\WinToolkit_Temp\Mount" /commit
WIM File: C:\Windows_7_x64_DVD_Ultimate_rawDSK\SOURCES\install.wim
Mount Logging: True
Drive Type: Fixed
Free Space: 352.89 GB
IsReady: True
File Exists: True
Directory Exists: True
Files:
Directories: *C:\WinToolkit_Temp\Mount\Program Files *C:\WinToolkit_Temp\Mount\Windows
Setting taskbar Progress
Setting taskbar Colour
Dumping Registry
Detecting cause of error #1
Detecting cause of error #2
Detecting cause of error #3
Detecting cause of error #4
ImageX Tool for Windows
Copyright © Microsoft Corp. All rights reserved.
Version: 6.1.7601.21716
Committing: [C:\WinToolkit_Temp\Mount]...
Unmount Error: Did not find an image mounted to [C:\WinToolkit_Temp\Mount].
Fixed
C:\
352.89 GB
ERROR.txt
ERROR_2.txt
AIO_Settings_ini_WIN6_1_SP1_x64_DSK.ini
Posted (edited)
@Phöbus
After a new test, I see that the folders "WinToolkit_Temp\Mount" are created now using WinToolkit !
When the image is successfully commited the temp folder "Mount" is removed and all works fine. And when we exit WinToolkit the temp folder "WinToolkit_Temp" is removed.
It seems the trouble is the "Mount" folder wasn't empty in this case.
Here is my result test (Logs\Mount Logs):
[4452] [ INFO ] Mounting new image.
Wim: [C:\Win7_SP1\sources\install.wim]
Image Index: [5]
Mount Path: [C:\WinToolkit_Temp\Mount]
[4452] [ INFO ] Wimserv process started for guid e433dace-d32e-46a6-97bd-5c87907a0ad7. Id is 4852
[4852] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at C:\Win7_SP1\sources\install.wim.
[4852] [ INFO ] Mounted image at C:\WinToolkit_Temp\Mount.
[4852] [ INFO ] Received unmount request for image with guid e433dace-d32e-46a6-97bd-5c87907a0ad7.
[4852] [ INFO ] Unmount for image at C:\WinToolkit_Temp\Mount complete.
*Edit:
You can try to do like this:
Exit WinToolkit
Browse to the folder WinToolkit_Temp\Mount if exists
Select the folder and use on your keyboard "Shift + Del" to remove this one
Go to the registry and look at this key:
HKLM\SOFTWARE\Microsoft\WIMMount\Mounted Images
Remove this key
Try again to launch WinToolkit and the temp folders will be created a new time.
Edited by myselfidem
That sort of stuff only happens if the user was browsing those folders and forgot to close the explorer window.
