compstuff Posted November 3, 2012 Posted November 3, 2012 After using my old folders with v1.5 and having files moved to the OLD directory I decided to start from scratch with no previous anything so here are my questions and observations before I make any comments:I noticed their are folders in the additional items that are not included even as options to download... is this intentional?Update changelog.txt file not availableno KB2728973-rvkroots.exeno Integrate to installation media/KB2023591/no KB890830.Microsoft.Windows.Malicious.Software.Removal.Tool/ no KB2506143.Windows.Management.Framework.3.0.CTP/no KB2724074MicrosoftBitLockerAdministrationAndMonitoring/no Silverlight/no VPC/ Quote
RicaNeaga Posted November 3, 2012 Posted November 3, 2012 Win Toolkit now scans only for .cab and .msu files, so only integratable files from komm / McRip servers. If you don't like this behaviour, you can leave a request, but it's better also to give reasons on why you want it.My request (that Legolash thought to solve it in this manner) was to make Win Toolkit's Update Catalog more begginer-friendly. And I think it's very ok right now. Advanced users can make those exe files silent installers without checking each month for updates, or checking only for the ones they need. Quote
compstuff Posted November 3, 2012 Author Posted November 3, 2012 In a way I can understand about the beginner friendly idea but I for one really don't like this. For me one of the strengths in the toolkit is the ability to be more of a "one stop" tool that gives everyone what they want. I would much prefer the ability to make a choice about downloading files and if needed have some info, popups, mouse overs etc regarding the need.I'm not sure what you mean about not checking each month for updates or only for the ones that are needed... this stuff always changes and some items above change monthly so how exactly is one to easily check those and download those items... before the toolkit did it for me in one single shot and then I determined what changed and how to apply the items.McRip and Komm do an unbelievable job but even with that its still a heck of a task to get all of this straight each month so for me this actually made things harder and not easier. Quote
amaltom61 Posted November 4, 2012 Posted November 4, 2012 (edited) :crying_anim02: A bad news to everyone.It seemes that Komm's KUC sever is offline for some time :crying_anim02: Edited November 4, 2012 by amaltom61 Quote
Legolash2o Posted November 4, 2012 Posted November 4, 2012 I can add an option in 'Win Toolkit Options' which allow you to select to either just show MSU/CAB files or display everything? George King and compstuff 2 Quote
RicaNeaga Posted November 4, 2012 Posted November 4, 2012 I can add an option in 'Win Toolkit Options' which allow you to select to either just show MSU/CAB files or display everything?Such an advanced option that can be checked by advanced users can be fantastic, and adress everyone's needs. compstuff 1 Quote
compstuff Posted November 4, 2012 Author Posted November 4, 2012 Simply AWESOME I can add an option in 'Win Toolkit Options' which allow you to select to either just show MSU/CAB files or display everything? Quote
yogurt Posted November 4, 2012 Posted November 4, 2012 @Legolash2oI really like the new filtered updates catalog, and would welcome an Advanced option such as the one you are suggesting. It's simple yet effective. Bravo! Quote
amaltom61 Posted November 5, 2012 Posted November 5, 2012 (edited) KUC is still offlinehttp://forums.mydigi...ll=1#post663622Edit- KUC is again ONLINE :D with no upades or hotfixes Edited November 5, 2012 by amaltom61 Quote
Eric666 Posted November 7, 2012 Posted November 7, 2012 (edited) I just checked KUC's site manually and indeed no MSU/EXE/CAB are present, only the additional TXT and HTM files. Did M$ tell him to remove all those? Or are those not listed/hidden in order to reduce traffic? Because when running KUC I can still download needed updates.Regards, Eric666Edit: the effect is now that all material in the update repository is moved to the Old subfolder, leaving a blank x86/x64 Update folder... Edited November 7, 2012 by Eric666 Quote
amaltom61 Posted November 7, 2012 Posted November 7, 2012 (edited) By KUC,do you meen the software created by komm.Komm removed the updates due to high traffic -- http://forums.mydigi...ll=1#post663622 Edited November 7, 2012 by amaltom61 Quote
Eric666 Posted November 7, 2012 Posted November 7, 2012 Yes, I read that thread, but I did not understand that Komm meant that he removed all updates, since he talked about zips. And KUC (Komm's Update Checker) was still able to download some updates for my system. But possibly those were obtained from some other location.Regards, Eric666 Quote
amaltom61 Posted November 8, 2012 Posted November 8, 2012 (edited) The zip file he mentioned are two zip files which contain all the updates and hotfixes for 32 bit and 64 bit (like the 7z files in macrips servers http://hotfix2.cesidian.info/ )It cannot be downloaded by the toolkit, it can only be downloaded by going to the site.Maybe KUC downloads the updates directly from Microsoft's severs.Its a lot faster than his site. Edited November 8, 2012 by amaltom61 Quote
Eric666 Posted November 8, 2012 Posted November 8, 2012 The zip file he mentioned are two zip files which contain all the updates and hotfixes for 32 bit and 64 bit (like the 7z files in macrips servers http://hotfix2.cesidian.info/ )It cannot be downloaded by the toolkit, it can only be downloaded by going to the site.Maybe KUC downloads the updates directly from Microsoft's severs.Its a lot faster than his site.OK, I finally understand. Still, also all exe/msu/cab have been removed from his site, which were previously there, and could be downloaded with WTK. I think your guess on KUC directly downloading from MS servers is probably right.Regards, Eric666 Quote
Legolash2o Posted November 10, 2012 Posted November 10, 2012 I've added the filter option in 'Options', it's enabled by default. Quote
RicaNeaga Posted November 10, 2012 Posted November 10, 2012 (edited) In test 38, when the filter is disabled, McRip's servers still have it (only cab and msu are shown). Also, please take a look here.Also, how about changing the description of the option with another sentence: ''The unfiltered results are useful for advanced users familiar with the contents of those servers''.LE: That filter shows all the folders on those servers? My request was to hide some not integratable files, however advanced users may need those. This was also the request here, to show not only other files than .msu and .cab, but also to not block some folders. Edited November 10, 2012 by RicaNeaga Quote
Legolash2o Posted November 10, 2012 Posted November 10, 2012 Is it me or has all of the updates in KUC server gone missing? Quote
amaltom61 Posted November 10, 2012 Posted November 10, 2012 Lego Please read the posts no 9,10,11,12,13,14 and the link on post no 11. Quote
RicaNeaga Posted November 10, 2012 Posted November 10, 2012 Is it me or has all of the updates in KUC server gone missing?Yes, it's down for the moment, only non-update small files are present. The reason - see here. Quote
amaltom61 Posted November 10, 2012 Posted November 10, 2012 I has been almost a week since KUC was down. Now Only Macrip's servers are up and runningThe initila reason for the shutdown of the site was due to heavy traffic.The heavy traffic maybe mostly caused by the win toolkit 1.5.01 users.So maybe its us who destroyed his site Quote
yogurt Posted November 10, 2012 Posted November 10, 2012 I made Komm an offer to host his website for free for a month or two while he gets things sorted out with his current ISP, but I have yet to receive a response.Komm, if your reading this, the offer still stands. Send me a PM if your interested and I'll setup an FTP account. Were talking about a server over at Hostgator or Rackspace. My current SLA reads unlimited bandwidth allowance. Of course I'll have to double check with my sales rep first to be sure. But let me know if your interested. Quote
amaltom61 Posted November 11, 2012 Posted November 11, 2012 (edited) Already saw it on MDL forums,but there is no sight of Komm sice that post on MDL forum Edited November 11, 2012 by amaltom61 Quote
yogurt Posted November 11, 2012 Posted November 11, 2012 (edited) @amaltom61 @KommISP's can be picky regardless of SLA's. Something is going-on that's for sure, Come on Komm, you got nothing to loose. Keep up the good work, I support your efforts. Edited November 11, 2012 by dotfusion Quote
Legolash2o Posted November 11, 2012 Posted November 11, 2012 Have you sent him a PM via MDL? Or posted on the forum itself? Quote
yogurt Posted November 11, 2012 Posted November 11, 2012 Sent him a PM and droped post in the forum. Quote
