Posted November 5, 201212 yr dear legoi can not add theme pack i created in windows 8maybe wintoolkit do not support theme pack format deskthemepack
December 18, 201212 yr Deskthemepack format is only compatible with Windows 8... (there isnt any internal differences though, if you extract it, it will work on windows 7 also)
