Using WinToolkit150-1_Test36
I stumbled leftover files/folders from WinToolkit in the slipstreamed os.
Still left in the slipstreamed OS (x86):
A) Files:
1) C:\Windows\System32\WinToolkit_RunOnceLog.txt Rather keep
2) C:\Windows\WinToolkitDrivers.txt Rather keep
3) C:\Windows\System32\WinToolkitRunOnce.exe
4) C:\Windows\System32\UTH.exe
B ) Folder:
1) C:\Windows\WinToolkit\Addons
Let's WinToolkit know what addons are integrated
i) Should WTK perform/schedule a cleanup or does it serve some purpose by leaving it there?
ii) If it is there for log purpose, can they be moved to 1 common location/folder? Done
iii) In all cases, even if it is there for a purpose (I assume it is generally use for post review/debug only), can you let user have a choice whether user wish to keep these logs/folder or clean up everything? (I would prefer all cleaned up :) ) NO
Your thought... :)
Can an alternate option be set in options to have log files stored in same directory as exe or letting user select folder location please.
