Posted November 9, 201212 yr Hello guys!First I wanna say that this tool is very intuitive. I'm loving. I had some problems but I got everything what I need reading these forums.Except for one thing, inside Wintoolkit 1.40 > All-In-One Integrator in Options > Addons.What "Enable CMD" really is?1) Is something to do with "OpenCMD Shell Addon from Reaper"?2) Or is it something related to "use this option if you need Command Prompt support while installing SFX silent installers or batches" ?Thanks in advance.PS: Check screenshot for details.
November 9, 201212 yr The 'Enable CMD' option turns on the 'Command Tab' found in the AddOn Maker tool of Win Toolkit 1.4 and 1.5. Quote These are commands which are opened during integration. An example would be..."DISM.exe /Image:%WIM% /Disable-feature /FeatureName:WindowsMediaPlayer /Featurename:MediaCenter" Quote %WIM% - This will be translated into the default mount folder during integration (C:\WinToolkit_Temp\Mount\) as some people change their Win Toolkit Temp folder so its best to use the enviroment variable %WIM%. Edited November 9, 201212 yr by dotfusion
November 10, 201212 yr By default addons are allowed to run the DISM/PKGMGR command however if an addon requires another command then that option has to be ticked. I wouldn't like a cheeky sod to make an addon which formatted computers.EDIT: The option is now disable as default.
November 11, 201212 yr @Legolash2oL0L... As a practice I always look under the hood to see whats in there. I remember a time when I a cut and paste a script I found on the net without giving much thought to what commands it may contain, thinking tthat it it was from a trusted source I ran the script without skipping a beat.Instead of helping me fix the problem it screwed my webserver and I lost all my data. Never again shall I be so careless. Edited November 13, 201212 yr by dotfusion
