Posted November 10, 201212 yr WinCDEmu 3.6 - the easiest way to mount an ISODescription: A free lightweight alternative to Daemon-Tools.Official website: http://wincdemu.sysprogs.org/Arch type: x86 / x64Silent switches: not needed.Note #1: Auto-installs SysProgs certificate as TrustedPublisher so it installs it's drivers without prompting and then finally installs WinCDEmu.Note #2: Installer made with 7z Sfx Builder. If you want to learn how I made it, just open this installer with 7z Sfx Builder to understand the installer sourcecode.MD5 Hash: 41E52A9324CDF9CE04716127D347AB06Size: 980 KB (1.003.746 bytes)Download here:http://www.4shared.com/file/3ai5mery/WinCDEmu-36-silent.html Edited November 13, 201212 yr by Kormann
November 10, 201212 yr If it's not to much to ask, could you please post MD5 Hashes so users are able to verify the integrity of their downloads. Many Thanks for this addon. Edited November 10, 201212 yr by dotfusion
November 10, 201212 yr Size, in bytes, is typically also provided just so the user knows what to expect before downloading.Cheers and Regards Edited November 10, 201212 yr by bphlpt
November 12, 201212 yr Author Sure, here I go again File information updated with "MD5 Hash" and "Size".Fix: Installer fixed for dual arch support (x86 / x64) Edited November 13, 201212 yr by Kormann
February 5, 201312 yr Hi Kormann,Many thanks for this helpful solution!Just a question, how can I to add an additional language to be installed together with WinCDEmu? Not all languages comes with the default installer and I would to add my language and erase the rest if is possible to do this task. I tried modifying your package through the 7z Sfx Builder tool that you mention but I don't know why I can't insert the file .among cert & setup file (nor what option I need to select; RunProgram, AutoInstall/x, ExecuteFile)... THANK YOU SO MUCH!Benny
April 15, 201410 yr here my version installer winrarul.to/kmxqp0vnorginal setup + certinstallSetup=certutil -addstore TrustedPublisher wincdemu36.cerSetup=WinCDEmu-3.6.exe /UNATTENDEDTempModeSilent=1Overwrite=1
