Virtual CloneDrive works and behaves just like a physical CD/DVD drive, however it exists only virtually. Image files generated with CloneDVD or CloneCD can be mounted onto a virtual drive from your hard-disk or from a network drive and used in the same manner as inserting them into a normal CD/DVD drive.
Probably the best virtual drive software, Virtual CloneDrive allows you to enjoy the freedom of a virtual drive and is completely free.
Features
  • Supports all common image formats such as ISO, BIN, CCD
  • Supports up to 8 virtual drives at the same time
  • Easy to use - just double-click an image file to mount as a drive
  • Virtual CloneDrive is freeware, you may use it at no cost.
- Desktop icon is removed
- Autostart of Daemon tray is disabled by default, if you want it, use /ai switch
MD5: 0a5270e9b4414cf1bd47bc2f69c2c19c
Virtual Clone Drive 5.4.7.0 AddOn.rar
  • 4 months later...
  • 3 months later...
