yogurt Posted November 19, 2012 Share Posted November 19, 2012 (edited) KB2670838 Failed to integrate Windows 7 SP1 (7601) Anyone else have the same issue?EDIT :: This update integrates fine when adding it to Advanced :: Silent Installers using the /Q switch. KB2670838 can not be integrated as an update in 1.4.0.77. Version 1.5 does not have this issue. Edited November 20, 2012 by dotfusion Quote Link to comment Share on other sites More sharing options...
compstuff Posted November 19, 2012 Share Posted November 19, 2012 I just did an x64 integration test yesterday but I used 5.01v38 and it seemed to integrate fine Quote Link to comment Share on other sites More sharing options...
yogurt Posted November 19, 2012 Author Share Posted November 19, 2012 Thanks compstuff, I will add it to my silent installs for the time being or I posibly integrate using the latest 1.5.0.1 Test 38. Thanks for the confirmation, much appreciated. Quote Link to comment Share on other sites More sharing options...
sp0iledbrat Posted November 20, 2012 Share Posted November 20, 2012 It's not even offered on Windows Update in Win7x86, although I downloaded the package from MS Download Center. I'm a bit concerned about the PRE-RELEASE wording. What does that mean? Testing only? Will there be newer, more stable versions? For the time being, I'm not going to install it. Quote Link to comment Share on other sites More sharing options...
