Posted November 19, 201212 yr Hi Al.Me add AutoUnattend.xml In Win Iso But No Test In Vmware Not Read ProductKey + Netframework 3.5 SP1 Offline Install.Plz Help Me For Fixed.WinToolkit150-1_Test38 Unattended Creator.Thanks a Lot.<?xml version="1.0" encoding="utf-8"?><unattend xmlns="urn:schemas-microsoft-com:unattend"><servicing> <package action="configure"> <assemblyIdentity name="Microsoft-Windows-Foundation-Package" version="6.2.8102.0" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="" /> <selection name="NetFx3" state="true" /> </package></servicing> <servicing> <package action="configure"> <assemblyIdentity name="Microsoft-Windows-Foundation-Package" version="6.2.8102.0" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="" /> <selection name="NetFx3" state="true" /> </package></servicing><settings pass="windowsPE"> <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <UserData> <AcceptEula>true</AcceptEula> <ProductKey> <Key>CCCC-CCCC-CCCC-CCCC-CCCC</Key> <WillShowUI>Always</WillShowUI> </ProductKey> </UserData> </component> <component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <UserData> <AcceptEula>true</AcceptEula> <ProductKey> <Key>CCCC-CCCC-CCCC-CCCC-CCCC</Key> <WillShowUI>Always</WillShowUI> </ProductKey> </UserData> </component></settings><settings pass="specialize"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <ProductKey>CCCC-CCCC-CCCC-CCCC-CCCC</ProductKey> </component> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <ProductKey>CCCC-CCCC-CCCC-CCCC-CCCC</ProductKey> </component></settings><settings pass="oobeSystem"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <OOBE> <HideEULAPage>true</HideEULAPage> </OOBE> <TimeZone>US Standard Time</TimeZone> </component> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <OOBE> <HideEULAPage>true</HideEULAPage> </OOBE> <TimeZone>US Standard Time</TimeZone> </component></settings></unattend> Edited November 19, 201212 yr by AhrimanSefid
November 19, 201212 yr I use ei.cfg to skip the dialog during the beginning of setup and I inject the key into my mounted image to not get it during oobe...my autounattend.xml does not need to have a serialIts better to inject your serial especially if you have multiple images in your wim, this way you can use the same autounattend.xml with ALL
November 19, 201212 yr Author tanx for your help but I didn't get exactly what you mean can you give me a sample a tutorial so I can understand better. tanx agian.
