Posted November 23, 201212 yr So RT7 has an option which allows the administrator to "enable God Mode." I haven't found anything similar to this option in Win Toolkit, and haven't found anything on this forum using the Search. Is there some "God Mode" enabler for Win Toolkit?
November 24, 201212 yr I could have sworn that this was available as a tweak, but looking quickly just now I didn't see it. I'm sure if it had been a snake it would have bit me. LOL Perhaps some kind soul will enlighten us?Cheers and Regards
November 24, 201212 yr Create a new folder with the name:GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}That's it.
November 24, 201212 yr Author No, Mr_Smartepants, the RT7 option makes some sort of option whenever you right-click on blank space, and then there's an option that reads "Enable God Mode" which like grants full administrator privileges, lets you get into folders which even normally the "Administrator" account can't get into, and stuff like that. Edited November 24, 201212 yr by gungrave4ever
November 25, 201212 yr That's not the "GodMode" that I've always heard about. I've heard about the one that Mr_Smartepants mentioned. (And I still thought that there was a tweak in Win Toolkit to enable that.) The one that allows you to have easy access in Win7 to all the various control settings in one place. See here, here, and here among many, many links that say that this is called "GodMode". Those are just the first three links given to a Google search for "GodMode", without the quotes. If RT7 has co-opted the term GodMode to mean something else this is the first I have heard of it.Cheers and Regards
December 12, 201212 yr Whichever one you mean, it needs to be in the request forum. Also, i'm pretty sure 'All Tasks' mentioned above is the same thing. Unless you're on about the God Mode where you are higher than administrator or something like that.
