venerable13 Posted November 24, 2012 Posted November 24, 2012 1.I get an Error when I try to download from dropbox on commands-internet-download a programI put "?dl=1" at final of the linkWith "wget" it works or putting it on the adress bar.2.I try also with this linkI put this -> http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10019223&ontId=2239_4&spi=6f9090653428d3331f2257339658eb21&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=12808071&mfgId=85737&merId=85737&pguid=UK9hpwoOYJMAACcZHcoAAAAq&destUrl=http%3A%2F%2Fsoftware-files-a.cnet.com%2Fs%2Fsoftware%2F12%2F80%2F80%2F71%2Favast_free_antivirus_setup.exe%3Ftoken%3D1353706996_003427b3fdf5573511c347f24070bd02%26lop%3Dlink%26ptype%3D3000%26ontid%3D2239%26siteId%3D4%26edId%3D3%26spi%3D6f9090653428d3331f2257339658eb21%26pid%3D12808071%26psid%3D10019223%26fileName%3Davast_free_antivirus_setup.exeoncommands-internet-download a programAnd "Error" is showed.Thanks for readme. Quote
venerable13 Posted November 25, 2012 Author Posted November 25, 2012 Actually I'm testing to do 1 and 2 with bitcasa and works ok, so for any reason dropbox links and second type of links don't works ok with WPI, but bitcasa works perfect. Bitcasa can works with direct links but dropbox now even putting "?dl=1" at final of the link doesn't works ok with WPI. WPI, dropbox or incompatibility problem. Quote
