Hello
I used win toolkit successfully and built my iso, I still keep my temp installation folder, but now I would edit my Silent Installers List without changing anything else, I wonder how to edit my silent installers list manually without using win toolkit.
Thanks.
If you want to update a setup program just simply replace the file in the DVD\\Apps folder
If you want to remove a setup program you can just delete the exe.
Sorry for being away a long time I hope I am back now. Thanks for your reply and BTW I use this at times, I mean I replace the file in the DVD\Apps folder and it works.
But actually I want to replace for example "ccleaner.msi" by "ccleaner.exe" they have two different extentions and I am sure this method will not work. What's your suggestion please?
Thank you.
dotfusion
Thank you... that also helps... but it depends on what people type in search, I tried this : "Editing Silent Installers List" it gave nothing.
