Posted December 5, 201212 yr Hello Legolash2o and all other member's. I have some problems with using a Win Toolkit I dont know is that maybe a Bug or something like that.I will attach pic. to you can see what hapen.Okay here's the thing:Im downloaded last Win Toolkit (1.5.0.1) I''m also try 1.4 version and the same error appear.When i click All in One Integration and select .wim file or folder of Win 7 installation this error apear (attachament)Im downloaded Win 7 SP1 x86 from Win Toolkit links. If you can help or give me some advice what is causing error. Tnq
December 6, 201212 yr Author Its Windows 7 Ultimate SP1 32-bit I try to work with iso that doesn't contain SP1 slipstreamed and it can read the wim file corectly but the windows i downloaded cant that error apear.GRMCULFRER_EN_DVD ---> WorkGSP1RMCULFRER_EN_DVD ---> Doesn't work (downloaded)EDIT_1: Im notice that my iso shows 2.00 GB but when download start's it's show 2,4 GB,think the iso is corupted i will download again and reply to post.EDIT_2: Same problem again. :SDownload iso from another site (torrent) with same hash and MD5 and it shows 2,4 GB Its fine now Fixed Admin can close it Edited December 6, 201212 yr by Husein Pilipovic
