ElmerBeFuddled Posted December 8, 2012 Posted December 8, 2012 Even though I check (tick) Recent Docs and specify hide under > Tweaks > Start Menu it still shows up. To hide it I have to run a reg file afterwards. Quote
ElmerBeFuddled Posted December 13, 2012 Author Posted December 13, 2012 (edited) I just ran a quick image through 1.50 t38 on Professional.The settings.ini shows: Recent Docs::HideBut in the registry log it's showing:13-12-2012_01:51AM | WriteValue: HKEY_LOCAL_MACHINE\WIM_Admin\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced | Start_ShowRecentDocs=1| DWordNo error reports generated but I can upload the files that were generated if you require them. Edited December 13, 2012 by ElmerBeFuddled Quote
ElmerBeFuddled Posted December 14, 2012 Author Posted December 14, 2012 (edited) No. It's you who deserves the Thanks.Hope Santy Claus is nice to you!! Edited December 14, 2012 by ElmerBeFuddled Quote
dareckibmw Posted December 15, 2012 Posted December 15, 2012 I don't want to make another thread, so I'll post it here since its related to this build.Its not a bug, more like cosmetic thingy, I've noticed that in test38 and test39 as well. I don't add any silence installers via Toolkit and this window pops up.It doesn't show up in test28 Quote
Legolash2o Posted December 18, 2012 Posted December 18, 2012 Have you ever added silent installers to the image in the past? Luckily i programmed it in a way that it will close automatically Quote
dareckibmw Posted December 18, 2012 Posted December 18, 2012 Yes, I do add few silence apps., in $OEM$ using setupcomlete.cmd., but not thru Win Toolkit.It does closed automatically after a "countdown", that's why I said its more like cosmetic thing, not a bug. Little annoying I would say. And I haven't notice that in earlier build. Thanks! Quote
