Etz Posted December 11, 2012 Posted December 11, 2012 Currently it completely ignores *.vbs files.Scripts are visible in Preset file and GUI, but isnt actually integrated at all... Quote
Legolash2o Posted December 12, 2012 Posted December 12, 2012 I'm assuming you mean the 'Files' tab? Quote
Etz Posted December 12, 2012 Author Posted December 12, 2012 (edited) I'm assuming you mean the 'Files' tab?Youre assumption is correct FYI also "stable" 1.4.0.77 behaves the very same way... Edited December 12, 2012 by Etz Quote
Legolash2o Posted December 13, 2012 Posted December 13, 2012 So it doesn't copy the file to your destination at all? Or was you expecting it to run after install automatically? Quote
Etz Posted December 13, 2012 Author Posted December 13, 2012 (edited) I wont expect it to run... (hence this tab is for replacing/intergating files, not for running them)It just doesnt get copied into image at all.EDIT:Nevermind, I`m an complete idiot...by pasting preset file here, I discovered I made a small mistake in destination "path", hence I never found that file after integration...Also ofcourse it wouldnt run, as its in a completely wrong location...All works fine actually, sorry for reporting non-existent issue... Edited December 13, 2012 by Etz Quote
Legolash2o Posted December 13, 2012 Posted December 13, 2012 You silly sausage, marked as solved. We all have one of those days so don't worry about it Quote
