December 12, 201213 yr Hi Liam,sorry the KB 2761465 can not be integrated in my image which as the IE10release preview for Win7 already integrated. It breaks with an error message.
December 13, 201213 yr Author I will check it this weekend. Then I make a screenshot,Here is the new hotfix, which can not be itegrated by wintoolkit.I have succesfully integrated the IE 10 preview in my Win7_SP1_ISO.
December 13, 201213 yr Author Hi Liam,I have just tested the new version 39 and it does not appear any more.Congratulation !
December 15, 201212 yr Author Hi Liam, I have tested for a second time and the result is, that KB 2761465 is not integrated. There is no error message. But the IE10 preview release runs perfectly. Regards
December 16, 201212 yr Please tell me? How to integrate IE 10 in the distribution of Windows 7 see here :rtfm:
December 16, 201212 yr Hello! To integrate IE 10 should be the update: IE10-Win7.cab, Windows6.1-KB2670838.msu, Windows6.1-KB2731771.msu, Windows6.1-KB2729094-V2.msu, Windows6.1-KB2758857.msu. Edited December 16, 201212 yr by serg130270
December 16, 201212 yr Author Hi Liam, another sceenshot. The Hotfix KB 2761465 can not be integrated with the wintoolkit.I have an ISO-File in which the IE10 is already integrated. Have a look at the message from "Vandit" from today.Regards Edited December 16, 201212 yr by pedilover
December 16, 201212 yr Author Hi serg130270,why do you try to integrate a language pack for IE9 when you want to integrated IE10 ??KB 2761465 is not possible to integrate with the current version of Wintoolkit, but we hope that Liam make a change ....?
December 16, 201212 yr Hi serg130270,why do you try to integrate a language pack for IE9 when you want to integrated IE10 ??KB 2761465 is not possible to integrate with the current version of Wintoolkit, but we hope that Liam make a change ....?Remove the installer IE10-Windows6.1-x64-ru-ru.exe command: E: \ IE10-Windows6.1-x64-ru-ru.exe / x: E: \ IE10 and see for yourself
December 18, 201212 yr Do you have a link to KB2761465 please? the one you are using. The update being shows as IE9 Langpack should say IE10 Langpack, i will fix that now.
December 18, 201212 yr Do you have a link to KB2761465 please? the one you are using. Cumulative Security Update for Internet Explorer 10 Release Preview for Windows 7 for x64-based Systems (KB2761465)
December 18, 201212 yr You can turn 'Compatibility Check' setting off in the 'Options' tab. UPDATE 1: There are different versions of that update depending on your OS. You can always extract the cab file from the msu and integrate that instead. UPDATE 2: It should add to the list in the next release.
December 18, 201212 yr I'm using IE9 and KB2761465 has been integrated without problems.The problem could be that the official update KB2761465 is not for IE10 under Win7, look here. P.S.: Grüß dich, Daniel :welcome: Edited December 18, 201212 yr by Thiersee
December 18, 201212 yr Hello!Here are links to Cumulative Security Update for Internet Explorer 10 in Windows 7 x64-x86 (KB2761465)http://www.microsoft.com/en-us/download/details.aspx?id=35908http://www.microsoft.com/en-us/download/details.aspx?id=35855
December 18, 201212 yr Thank you very much! Now everything works with a bang. You just clever. Edited December 18, 201212 yr by serg130270
December 18, 201212 yr Author Hi Liam,even with the newest version 1.4.1.2 the same error: KB2761465 not compatible with this update.Regards
December 18, 201212 yr They are different MSU files for different version of Windows. Either integrate the cab file or turn of 'Compatibility Check' in the options tab.
December 19, 201212 yr Hi Liam,even with the newest version 1.4.1.2 the same error: KB2761465 not compatible with this update.Regards Here are links to Cumulative Security Update for Internet Explorer 10 in Windows 7 x64-x86 (KB2761465)http://www.microsoft...s.aspx?id=35908http://www.microsoft...s.aspx?id=35855
December 19, 201212 yr To integrate IE 10 should be the update: Windows6.1-KB2670838.msu, Windows6.1-KB2731771.msu, Windows6.1-KB2729094-V2.msu, Windows6.1-KB2758857.msu. Edited December 19, 201212 yr by serg130270
