If I've run WTK and then decide I should have disabled a couple of services, do I need to select components again from my loaded settings .ini file.
At the moment I'm running a "standard" settings file but if I need to run WTK again the only option I don't choose in the standard file is the updates as they're already there.
I ran it once without choosing a settings file and all the "tweaks" were not applied, hence the method I use now.
But I would like to speed up the second etc. runs a bit! So the minimum number of options I need to select would be a help!!
