Hi,
i installed win8 pro, i turn on adsl modem but local area connection is limited always and with yellow
exclamation on task-bar.sometimes it connect to the Internet about 30 second and then yellow
exclamation is revert back. i disabled ipv6 with this command but still dont work.
netsh interface ipv6 6to4 set state disabled
netsh interface teredo set state disabled.
is there anyway to fix this?
this is a ipconfig.all that windows genereted.
Windows IP Configuration   Host Name . . . . . . . . . . . . : hoampc   Primary Dns Suffix  . . . . . . . :    Node Type . . . . . . . . . . . . : Hybrid   IP Routing Enabled. . . . . . . . : No   WINS Proxy Enabled. . . . . . . . : NoPPP adapter Broadband Connection:   Connection-specific DNS Suffix  . :    Description . . . . . . . . . . . : Broadband Connection   Physical Address. . . . . . . . . :    DHCP Enabled. . . . . . . . . . . : No   Autoconfiguration Enabled . . . . : Yes   IPv4 Address. . . . . . . . . . . : 4.199.110.168(Preferred)    Subnet Mask . . . . . . . . . . . : 255.255.255.255   Default Gateway . . . . . . . . . : 0.0.0.0   DNS Servers . . . . . . . . . . . : i removed this                                       4.2.2.1   NetBIOS over Tcpip. . . . . . . . : DisabledEthernet adapter Ethernet:   Connection-specific DNS Suffix  . :    Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller   Physical Address. . . . . . . . . : 00-0F-EA-63-7D-B0   DHCP Enabled. . . . . . . . . . . : Yes   Autoconfiguration Enabled . . . . : Yes   IPv4 Address. . . . . . . . . . . : 189.100.30.100(Preferred)    Subnet Mask . . . . . . . . . . . : 255.255.255.0   Lease Obtained. . . . . . . . . . : i removed this   Lease Expires . . . . . . . . . . : i removed this   Default Gateway . . . . . . . . . : 189.100.30.50   DHCP Server . . . . . . . . . . . : 189.100.30.50   DNS Servers . . . . . . . . . . . : 189.100.30.50                                       189.100.30.50   NetBIOS over Tcpip. . . . . . . . : Disabled
route.print.txt
===========================================================================Interface List 20...........................Broadband Connection 12...00 0f ea 63 7d b0 ......Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller  1...........................Software Loopback Interface 1===========================================================================IPv4 Route Table===========================================================================Active Routes:Network Destination        Netmask          Gateway       Interface  Metric          0.0.0.0          0.0.0.0    189.100.30.50   189.100.30.100   4245          0.0.0.0          0.0.0.0         On-link     4.199.110.168     21    4.199.110.168  255.255.255.255         On-link     4.199.110.168    276        127.0.0.0        255.0.0.0         On-link         127.0.0.1   4531        127.0.0.1  255.255.255.255         On-link         127.0.0.1   4531  127.255.255.255  255.255.255.255         On-link         127.0.0.1   4531     189.100.30.0    255.255.255.0         On-link    189.100.30.100   4501   189.100.30.100  255.255.255.255         On-link    189.100.30.100   4501   189.100.30.255  255.255.255.255         On-link    189.100.30.100   4501        224.0.0.0        240.0.0.0         On-link         127.0.0.1   4531        224.0.0.0        240.0.0.0         On-link    189.100.30.100   4501        224.0.0.0        240.0.0.0         On-link     4.199.110.168     21  255.255.255.255  255.255.255.255         On-link         127.0.0.1   4531  255.255.255.255  255.255.255.255         On-link    189.100.30.100   4501  255.255.255.255  255.255.255.255         On-link     4.199.110.168    276===========================================================================Persistent Routes:  NoneIPv6 Route Table===========================================================================Active Routes: If Metric Network Destination      Gateway  1    306 ::1/128                  On-link  1    306 ff00::/8                 On-link===========================================================================Persistent Routes:  None
Edited by mona
You can't have a Class A IP address, a broadcast subnet and a 0.0.0.0 Gateway at the same time?
You need to fix the subnet and enter the gateway IP at the least. Or enable DHCP, which the router should support.
Cheers
how do this?
DHCP Enabled. . . . . . . . . . . : No, there must be "Yes". Open Network Center, Change Adapter settings, right click, properties,
Internet Protocol Version 4 (TCP/IPv4, obtain IP address automatically.
