Posted December 19, 201212 yr most suggestions i've read say to look in a couple areas. when i look under \Resources\Themes it isnt there.when i look under %LocalAppData%\Microsoft\Windows\Themes it lists one "oem" theme but it is only 2kb in size, so that cant be it. it also has a custom background image when you log-on/log-off and i'd like to save that as well
December 30, 201212 yr Author after lots of research and online help i was able to find all the pieces to the theme. i found out that you can open a .theme file with notepad and see where all the file locations are. with that info i was able to save all the images/bakgrounds etc so i can re-create the theme manually.
