Hello all,
I've been using Win Toolkit for a while now, doing so with the All in one and only by selecting one image. Now, I would like to have an updated disc/USB with, for example, Win7 x64 Home, Pro, and Ultimate. Is it necessary to select all images and integrate updates, thereby integrating updates into all selected images?
I'm hoping for a quicker way to integrate updates since it can sometimes take hours if I select multiple images in the AIO creator.
Thank you!
Hi Legolash2o,
Thank you for the reply. I think I was using incorrect terminology in my original question. I selected the one image, such as the extracted contents of a Win7 x64 disc, then select the individual WIM files for each version (Home, Pro, Ultimate). I'm guessing by your reply that there's no way around selecting the individual WIM's for doing the updates.
