  • Installe SumatraPDF dans la langue du système et dans %ProgramFiles%.
  • Compatible Vista-7-8-10-11 32/64 bits.
  • Installable en live.
  • Associe les fichiers PDF à Sumatra (sauf sur 10+).
  • Désinstallable via Ajout/Suppression de Programmes.
  • La version Dual installe SumatraPDF dans l'architecture CPU correspondante à celle de Windows (x86/x64).
 SFX_SumatraPDF_3.5.2_Dual.exe
 Taille: 12,2 Mo
 SFX_SumatraPDF_3.5.2_x64.exe
 Taille: 6,56 Mo
 SFX_SumatraPDF_3.5.2_x86.exe
 Taille: 6,05 Mo
maj
2.2.1 (2013-01-12)
Changes in this release:
  • fixed ebooks sometimes not remembering the viewing position
  • fixed Sumatra not exiting when opening files from a network drive
  • fixes for most frequent crashes and PDF parsing robustness fixes
  • 4 months later...
maj en v2.3
Changelog:
# Changes:
- Greater configurability via advanced settings
- "Go To Page" in ebook ui
- add View/Manga Mode menu item for Comic Book (CBZ/CBR) files
- new key bindings:
> Ctrl-Up : page up
> Ctrl-Down : page down
- add support for OpenXPS documents
- support Deflate64 in Comic Book (CBZ/CBR) files
- fixed missing paragraph indentation in EPUB documents
- printing with "Use original page sizes" no longer centers pages on paper
- reduced size. Installer is ~1MB smaller
  • 3 months later...
    full-screen mode for ebooks (Ctrl-L)
    new key bindings:
        F9 - show/hide menu (not remembered after quitting)
        F8 - show/hide toolbar
    support WebP images (standalone and in comic books)
    support for RAR5 compressed comic books
    fixed multiple crashes
  • 4 weeks later...
  • 6 months later...
  • 2 page view for ebooks
  • new keybindings:
    • Ctrl+PgDn, Ctrl+Right : go to next page
    • Ctrl+PgUp, Ctrl+Left : go to previous page
  • 10x faster ebook layout
  • support JP2 images
  • new advanced settings: ShowMenuBar, ReloadModifiedDocuments, CustomScreenDPI
  • left/right clicking no longer changes pages in fullscreen mode (use Presentation mode if you rely on this feature)
  • fixed multiple crashes and made multiple minor improvements
  • 5 months later...
mise à jour vers la v3.0, ajout d'un switch pour installer les plugins.
3.0 (2014-10-18)
  • Tabs! Enabled by default. Use Settings/Options... menu to go back to the old UI
  • support table of contents and links in ebook UI
  • add support for PalmDoc ebooks
  • add support for displaying CB7 and CBT comic books (in addition to CBZ and CBR)
  • add support for LZMA and PPMd compression in CBZ comic books
  • allow saving Comic Book files as PDF
  • swapped keybindings:
    • F11 : Fullscreen mode (still also Ctrl+Shift+L)
    • F5 : Presentation mode (also Shift+F11, still also Ctrl+L)
  • added a document measurement UI. Press 'm' to start. Keep pressing 'm' to change measurement units
  • new advanced settings: FullPathInTitle, UseSysColors (no longer exposed through the Options dialog), UseTabs
  • replaced non-free UnRAR with a free RAR extraction library. If some CBR files fail to open for you, download unrar.dll from http://www.rarlab.com/rar_add.htmand place it alongside SumatraPDF.exe
  • deprecated browser plugin. We keep it if was installed in earlier version
  • 11 months later...
mise à jour vers la v3.1, le SFX installe maintenant la version correspondant à l’architecture de l'os (x86 ou x64)
3.1 (2015-10-24)
  • 64bit builds
  • all documents are restored at startup if a window with multiple tabs is closed (or if closing happened through File -> Exit); this can be disabled through the RestoreSession advanced setting
  • printing happens (again) always as image which leads to more reliable results at the cost of requiring more printer memory; the "Print as Image" advanced printing option has been removed
  • scrolling with touchpad (e.g. on Surface Pro) now works
  • many crash and other bug fixes
MAJ vers 3.1.1
 3.1.1 (2015-11-02)
  • (re)add support for old processors that don’t have SSE2
  • support newer versions of unrar.dll
  • allow keeping browser plugin if it’s already installed
  • crash fixes
3.1.2 (2016-08-14)
    fixed issue with icons being purple in latest Windows 10 update
    tell Windows 10 that SumatraPDF can open supported file types
  • 1 year later...
  • mooms changed the title to SumatraPDF 3.3
  • added support for adding / removing / editing annotations in PDF files. Read the tutorial
  • new toolbar
    • changed toolbar to scale with DPI by using new, vector icons
    • added rotate left / right to the toolbar
    • new toolbar:
  • added ability to hide scrollbar (more screen space for the document). Use right-click context menu.
  • add -paperkind=${num} printing option (checkin)
Minor improvements and bug-fixes::
  • advanced setting to change font size in bookmarks / favorites tree view e.g. TreeFontSize = 12
  • support newer versions of ghostscript (≥ 9.54) for opening .ps files
  • support jpeg-xr images in .xps files
  • restore tooltips (regression in 3.2)
  • update mupdf to latest version
  • make silent installation always silent
  • don't crash when attempting to zoom in on home page
  • don't show "manga" view menu item for documents that are not comic books
  • allow opening fb2.zip files (#1657)
  • restore ability to save embedded files (fixes #1557)
  • Alt + Space opens a sys menu
