Posted January 6, 201312 yr Your Uninstaller! How do I unpack ? I get an error with innounp http://innounp.sourceforge.net ....Can you help please Edited January 6, 201312 yr by ..FLaky..
January 6, 201312 yr I also get an error Signature detected: Inno Setup Setup Data (5.4.3) (u)This is not directly supported, but i'll try to unpack it as version 5402; Version detected: 5403 (Unicode)Critical error: The setup files are corrupted. Please obtain a new copy of the program.Unpacking failed. This version is not supported. Some inno installers (like klite codec pack) are password prottected to prevent extraction, I dont know if this installer is the same Maybe its a problem with innounp.exe, I see you or sum1 already report it
