hi there!
gr8 app you've wrote so kudos for that, Legolash2o.
i've met a peculiar error, though.
i was on lited (by rt7+rt7booster) win7x64sp1 and when i was trying to integrate any update to new image (oem from ms site) it would fail: red color, not integrated.
so i thought it was my old (host) os fault and went on another pc with clean default win7x64sp1 on it.
everything wen smooth there: all updates were integrated, winsxs backup removed and speech/natural language removed.
then i went back on my pc, installed the created os on it and everything works just fine: all apps working, updates working, just perfect.
now i launched the wintoolkit again on this freshly installed os and again all updates failed to integrate!
how is this possible? what's wrong with my pc? i couldn't find any log of integration procedure so i'm in the dark now and can't figure this out.
help?
right, so i'm done with rt7 and would like to lite my new win7 and install it fresh but CAN'T due to those integration errors :/
i'm trying to integrate updates (downloaded from ms sites directly) into Windows 7 SP1 EN x64 [X17-59186] iso.
why can't i do that?
Posted (edited)
memtest after almost 1h of testing said 'PASS' so no problem there
i've reinstalled clean w7 and gonna try again..
UPDATE:
nope, still the same!
clean os and non of the updates want to integrate :(
WTH??
Edited by aeMaeTH
ok, so i've got something:
i've installed the same clean w7 on VM (vbox) and there started the integration in wintoolkit and... IT WORKS!
why?? dunno
as for languages, no problem there since i'm on english host trying to make english iso.
also on my other pc was Polish w7 and made integration of English w7 just fine
my last thought is RAMDisk, 'cause you mentioned it in the other thread.
but i'm using ramdisk just for profile folder for Firefox and nothing else!
the whole integration procedure takes place on HDD (source files, KBs, wintoolkit)..
anyway, when the VM finishes the integration (116 updates) i'll try disabling the ramdisk and fire up WinT on my host os
will get back to you..
ps.
why you mentioned (in the other thread):
"A secondary advantage generating the ISO within the VirtualBox: the run is (in my case) 40-45% faster; but this is not so important."??
how come? mine is slower since it has less of RAM and less of CPU (2 instead of 4 cores) and more stress on pc itself (2 OSes)..
right so i've run WT several times in different conditions and still i get all red updates..
i uninstalled RAMdisk, comodo firewall, enabled UAC and even installed all those things on VM and the WT works just fine on VM!
i give up.. gonna go since it's midnight here and got some exams tomorrow ;/
gonna have to make the whole WT integration/removal/tweaking procedure in VM :<
bummer!
man, i did just that!
i've installed unmodified Windows 7 SP1 EN x64 [X17-59186], then intel and nvidia drivers, Firefox and VBox.
and i'm getting red integrations on my host and green one on my guest os.
why there's no logging in WT is beyond my understanding :(
Posted (edited)
i've got 1,5TB hdd:
OS is on 20gb (8gb free)
WT and KBs are on 100gb (60gb free)
WT_Mount is on 950gb (300gb free)
no problem here
ps.
can't see if you're online so sorry for the delay in reply
Edited by aeMaeTH
found the DISM.log, why nobody said about it's existence?
once again reinstalled pure retail win 7 prof x64 sp1, installed only drivers for motherboard and fired up WT to test few updates:
(...)2013-01-25 12:06:25, Info                  DISM   DISM.EXE:2013-01-25 12:06:25, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->2013-01-25 12:06:25, Info                  DISM   DISM.EXE:2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Host machine information: OS Version=6.1.7601, Running architecture=amd64, Number of processors=42013-01-25 12:06:25, Info                  DISM   DISM.EXE: Executing command line: "C:\Windows\System32\Dism.exe" /Remount-Wim /MountDir:"D:\WinToolkit_Temp\Mount"2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Loading Provider from location C:\Windows\System32\Dism\WimProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Connecting to the provider located at C:\Windows\System32\Dism\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Loading Provider from location C:\Windows\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Loading Provider from location C:\Windows\System32\Dism\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Connecting to the provider located at C:\Windows\System32\Dism\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: WimManager2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: WimManager.2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: FolderManager2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Compatibility Manager2013-01-25 12:06:25, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Compatibility Manager.2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Getting Provider WimManager - CDISMProviderStore::GetProvider2013-01-25 12:06:25, Info                  DISM   DISM Provider Store: PID=1104 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:26, Error                 DISM   DISM WIM Provider: PID=1104 Failed to remount the image. - CWimImage::Remount(hr:0xc1420126)2013-01-25 12:06:26, Error                 DISM   DISM WIM Provider: PID=1104 d:\w7rtm\base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:1146 - CWimManager::InternalOpRemount(hr:0xc1420126)2013-01-25 12:06:26, Error                 DISM   DISM WIM Provider: PID=1104 d:\w7rtm\base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:2506 - CWimManager::InternalCmdRemount(hr:0xc1420126)2013-01-25 12:06:26, Error                 DISM   DISM WIM Provider: PID=1104 Error executing command - CWimManager::InternalExecuteCmd(hr:0xc1420126)2013-01-25 12:06:26, Error                 DISM   DISM WIM Provider: PID=1104 d:\w7rtm\base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:516 - CWimManager::ExecuteCmdLine(hr:0xc1420126)2013-01-25 12:06:26, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.2013-01-25 12:06:26, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->(...)2013-01-25 12:06:27, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->(...)2013-01-25 12:06:41, Error                 DISM   DISM Provider Store: PID=1056 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:06:41, Info                  DISM   DISM Provider Store: PID=1056 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:41, Info                  DISM   DISM Provider Store: PID=1056 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:41, Info                  DISM   DISM Provider Store: PID=1056 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:41, Info                  DISM   DISM Provider Store: PID=1056 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:41, Info                  DISM   DISM Provider Store: PID=1056 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:42, Info                  DISM   DISM OS Provider: PID=1056 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:06:42, Info                  DISM   DISM Provider Store: PID=1056 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:42, Error                 DISM   DISM Proxy Image Session: PID=2136 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:06:42, Warning               DISM   DISM Manager: PID=2136 A problem ocurred loading the image session. Retrying...  - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:06:43, Info                  DISM   DISM Manager: PID=2136 Successfully loaded the ImageSession at "C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3" - CDISMManager::LoadImageSession2013-01-25 12:06:43, Info                  DISM   DISM Image Session: PID=2352 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore2013-01-25 12:06:43, Info                  DISM   DISM Provider Store: PID=2352 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect2013-01-25 12:06:43, Info                  DISM   DISM Provider Store: PID=2352 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:43, Info                  DISM   DISM Provider Store: PID=2352 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3\OSProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:43, Info                  DISM   DISM Provider Store: PID=2352 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:43, Info                  DISM   DISM OS Provider: PID=2352 Defaulting SystemPath to D:\WinToolkit_Temp\Mount - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:06:43, Info                  DISM   DISM OS Provider: PID=2352 Defaulting Windows folder to D:\WinToolkit_Temp\Mount\Windows - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3\LogProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Getting Provider OSServices - CDISMProviderStore::GetProvider2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:46, Error                 DISM   DISM Provider Store: PID=2352 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:46, Info                  DISM   DISM Provider Store: PID=2352 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:47, Info                  DISM   DISM OS Provider: PID=2352 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:06:47, Info                  DISM   DISM Provider Store: PID=2352 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:47, Error                 DISM   DISM Proxy Image Session: PID=2136 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:06:47, Error                 DISM   DISM Manager: PID=2136 Failed to load the image session from the temporary location: C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\4CDB9539-A2A9-4203-8128-324107E67FE3 - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:06:47, Error                 DISM   DISM.EXE: Could not load the image session. HRESULT=800700052013-01-25 12:06:47, Error                 DISM   DISM.EXE: Unable to start the servicing process for the image at 'D:\WinToolkit_Temp\Mount'. HRESULT=800700052013-01-25 12:06:47, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.2013-01-25 12:06:47, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->(...)2013-01-25 12:06:48, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->(...)2013-01-25 12:06:53, Error                 DISM   DISM Provider Store: PID=2720 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:06:53, Info                  DISM   DISM Provider Store: PID=2720 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:53, Info                  DISM   DISM Provider Store: PID=2720 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:53, Info                  DISM   DISM Provider Store: PID=2720 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:53, Info                  DISM   DISM Provider Store: PID=2720 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:53, Info                  DISM   DISM Provider Store: PID=2720 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:54, Info                  DISM   DISM OS Provider: PID=2720 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:06:54, Info                  DISM   DISM Provider Store: PID=2720 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:54, Error                 DISM   DISM Proxy Image Session: PID=2656 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:06:54, Warning               DISM   DISM Manager: PID=2656 A problem ocurred loading the image session. Retrying...  - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:06:55, Info                  DISM   DISM Manager: PID=2656 Successfully loaded the ImageSession at "C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470" - CDISMManager::LoadImageSession2013-01-25 12:06:55, Info                  DISM   DISM Image Session: PID=2460 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore2013-01-25 12:06:55, Info                  DISM   DISM Provider Store: PID=2460 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect2013-01-25 12:06:55, Info                  DISM   DISM Provider Store: PID=2460 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:55, Info                  DISM   DISM Provider Store: PID=2460 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470\OSProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:55, Info                  DISM   DISM Provider Store: PID=2460 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:55, Info                  DISM   DISM OS Provider: PID=2460 Defaulting SystemPath to D:\WinToolkit_Temp\Mount - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:06:55, Info                  DISM   DISM OS Provider: PID=2460 Defaulting Windows folder to D:\WinToolkit_Temp\Mount\Windows - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470\LogProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Getting Provider OSServices - CDISMProviderStore::GetProvider2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:06:58, Error                 DISM   DISM Provider Store: PID=2460 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:58, Info                  DISM   DISM Provider Store: PID=2460 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:59, Info                  DISM   DISM OS Provider: PID=2460 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:06:59, Info                  DISM   DISM Provider Store: PID=2460 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:06:59, Error                 DISM   DISM Proxy Image Session: PID=2656 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:06:59, Error                 DISM   DISM Manager: PID=2656 Failed to load the image session from the temporary location: C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\7B6E9670-1075-4C32-AE46-40D430009470 - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:06:59, Error                 DISM   DISM.EXE: Could not load the image session. HRESULT=800700052013-01-25 12:06:59, Error                 DISM   DISM.EXE: Unable to start the servicing process for the image at 'D:\WinToolkit_Temp\Mount'. HRESULT=800700052013-01-25 12:06:59, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.2013-01-25 12:06:59, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->(...)2013-01-25 12:07:00, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->(...)2013-01-25 12:07:05, Error                 DISM   DISM Provider Store: PID=2556 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:07:05, Info                  DISM   DISM Provider Store: PID=2556 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:05, Info                  DISM   DISM Provider Store: PID=2556 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:05, Info                  DISM   DISM Provider Store: PID=2556 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:05, Info                  DISM   DISM Provider Store: PID=2556 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:05, Info                  DISM   DISM Provider Store: PID=2556 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:06, Info                  DISM   DISM OS Provider: PID=2556 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:07:06, Info                  DISM   DISM Provider Store: PID=2556 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:06, Error                 DISM   DISM Proxy Image Session: PID=924 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:07:06, Warning               DISM   DISM Manager: PID=924 A problem ocurred loading the image session. Retrying...  - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:07:07, Info                  DISM   DISM Manager: PID=924 Successfully loaded the ImageSession at "C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10" - CDISMManager::LoadImageSession2013-01-25 12:07:07, Info                  DISM   DISM Image Session: PID=2732 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore2013-01-25 12:07:07, Info                  DISM   DISM Provider Store: PID=2732 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect2013-01-25 12:07:07, Info                  DISM   DISM Provider Store: PID=2732 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:07, Info                  DISM   DISM Provider Store: PID=2732 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10\OSProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:07, Info                  DISM   DISM Provider Store: PID=2732 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:07:07, Info                  DISM   DISM OS Provider: PID=2732 Defaulting SystemPath to D:\WinToolkit_Temp\Mount - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:07:07, Info                  DISM   DISM OS Provider: PID=2732 Defaulting Windows folder to D:\WinToolkit_Temp\Mount\Windows - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10\LogProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Getting Provider OSServices - CDISMProviderStore::GetProvider2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:11, Error                 DISM   DISM Provider Store: PID=2732 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:11, Info                  DISM   DISM Provider Store: PID=2732 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:12, Info                  DISM   DISM OS Provider: PID=2732 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:07:12, Info                  DISM   DISM Provider Store: PID=2732 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:12, Error                 DISM   DISM Proxy Image Session: PID=924 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:07:12, Error                 DISM   DISM Manager: PID=924 Failed to load the image session from the temporary location: C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\05E5F694-58FC-44D7-8295-FADEC2E30A10 - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:07:12, Error                 DISM   DISM.EXE: Could not load the image session. HRESULT=800700052013-01-25 12:07:12, Error                 DISM   DISM.EXE: Unable to start the servicing process for the image at 'D:\WinToolkit_Temp\Mount'. HRESULT=800700052013-01-25 12:07:12, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.2013-01-25 12:07:12, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->(...)2013-01-25 12:07:12, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->(...)2013-01-25 12:07:17, Error                 DISM   DISM Provider Store: PID=1904 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:07:17, Info                  DISM   DISM Provider Store: PID=1904 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:17, Info                  DISM   DISM Provider Store: PID=1904 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:17, Info                  DISM   DISM Provider Store: PID=1904 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:17, Info                  DISM   DISM Provider Store: PID=1904 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:17, Info                  DISM   DISM Provider Store: PID=1904 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:18, Info                  DISM   DISM OS Provider: PID=1904 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:07:18, Info                  DISM   DISM Provider Store: PID=1904 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:18, Error                 DISM   DISM Proxy Image Session: PID=2128 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:07:18, Warning               DISM   DISM Manager: PID=2128 A problem ocurred loading the image session. Retrying...  - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:07:19, Info                  DISM   DISM Manager: PID=2128 Successfully loaded the ImageSession at "C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305" - CDISMManager::LoadImageSession2013-01-25 12:07:19, Info                  DISM   DISM Image Session: PID=2280 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore2013-01-25 12:07:19, Info                  DISM   DISM Provider Store: PID=2280 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect2013-01-25 12:07:19, Info                  DISM   DISM Provider Store: PID=2280 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:19, Info                  DISM   DISM Provider Store: PID=2280 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305\OSProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:19, Info                  DISM   DISM Provider Store: PID=2280 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:07:19, Info                  DISM   DISM OS Provider: PID=2280 Defaulting SystemPath to D:\WinToolkit_Temp\Mount - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:07:19, Info                  DISM   DISM OS Provider: PID=2280 Defaulting Windows folder to D:\WinToolkit_Temp\Mount\Windows - CDISMOSServiceManager::Final_OnConnect2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Loading Provider from location C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305\LogProvider.dll - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Connecting to the provider located at C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Getting Provider OSServices - CDISMProviderStore::GetProvider2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider2013-01-25 12:07:22, Error                 DISM   DISM Provider Store: PID=2280 Failed to initialized the logger. - CDISMProviderStore::Internal_InitializeLogger(hr:0x80070005)2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:22, Info                  DISM   DISM Provider Store: PID=2280 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:23, Info                  DISM   DISM OS Provider: PID=2280 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect2013-01-25 12:07:23, Info                  DISM   DISM Provider Store: PID=2280 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider2013-01-25 12:07:23, Error                 DISM   DISM Proxy Image Session: PID=2128 Failed to get the provider store from the image session object. - CProxyImageSession::InitializePointers(hr:0x80070005)2013-01-25 12:07:23, Error                 DISM   DISM Manager: PID=2128 Failed to load the image session from the temporary location: C:\Users\aeM\AppData\Local\Temp\WinToolkit\ScratchDir\368E4292-A73D-489E-A971-0CB3BDFC9305 - CDISMManager::CreateImageSession(hr:0x80070005)2013-01-25 12:07:23, Error                 DISM   DISM.EXE: Could not load the image session. HRESULT=800700052013-01-25 12:07:23, Error                 DISM   DISM.EXE: Unable to start the servicing process for the image at 'D:\WinToolkit_Temp\Mount'. HRESULT=800700052013-01-25 12:07:23, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.2013-01-25 12:07:23, Info                  DISM   DISM.EXE:2013-01-25 12:07:23, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->2013-01-25 12:07:23, Info                  DISM   DISM.EXE:
made a few searches but couldn't find solution :(
any feedback from you guys?
dism.zip
