Posted January 25, 201312 yr Hello!Im using Wintoolkit to make my win 7 custom instalation iso And i put some addons and silent installers like winrar Freamwork 4, 4.5 ccleaner cpuz and VBCFJRedist_AIO_x86_x64 But only NET Freamwork and ccleaner are integrated nothing else ! Any ideas ? Advice ?
January 25, 201312 yr Author 1.4.1.9 Think it's the last one... EDIT: Shold i try BETA version ?? Lego Edited January 25, 201312 yr by Husein Pilipovic
January 25, 201312 yr Author Its from an iso Image installing in Virtal Box ... Edited January 25, 201312 yr by Husein Pilipovic
January 25, 201312 yr Author Okay I seen an aplication RunOnce.exe and i run it it's start installationm of Redist,Adobe FP Plugin and Adobr ActiveX and here is the log WinToolkit_RunOnceLog.txtAlso Im checked the folder Apps on iso and there is no Winrar Cpuz and Cleaner but cleaner is integrated O.o
January 26, 201312 yr Author Yes but there is no winrar in CP add remove programs or in Program files Dir. :S I will try with beta version again and reply okay ? EDIT: Okay i try again with last version and some of them are integrated and showed in CP add remove programs but not all Then i run an aplicaton Wintoolkit Runonce and it's install the rest of aplications Edited January 29, 201312 yr by Husein Pilipovic
