newuser121 Posted January 27, 2013 Posted January 27, 2013 (edited) Hello, I used to make great use of this tool: http://www.wincert.net/forum/topic/3637-tool-ffam-v10211/ to create silent costumized addons for Firefox, with costumized extensions, flash player/shockwave and more plugins, about:config configurations, and all prefs.js alterations I had done on an installed copy in XP. However, the tool doesn't work anymore, and I would like to learn how to do it manually. I have read many tutorials that use different approaches, but don't include all the customizations I used to be able to do before: http://mike.kaply.com/2010/06/18/customizing-the-firefox-installer-on-windows/ I am able to create addons for less complex programs reading tutorials from Ricktendo: http://www.wincert.net/forum/topic/4659-video-how-to-make-silent-switch-installers/ But I can't go beyond using the /ms switch using those methods. Any hints, or help would be much appreciated! Edited January 27, 2013 by newuser121 Quote
ricktendo Posted January 27, 2013 Posted January 27, 2013 You can extract the installer, edit/add/remove files (search plugins, browser-addons, etc) and you can also use a INI to customize it a bit further (this is how I install mine using WPI) to not install desktop shortcut and skip the maintenance service install https://wiki.mozilla.org/Installer:Command_Line_Arguments I delete the directx and visual c++ runtimes (because I install them in full) Quote
