Thiersee Posted January 30, 2013 Posted January 30, 2013 (edited) Starting integration on every tab, but NOT on "Updates + Languages"!, causes this box to appear then pressing OK the program continues normally; I did not see any other effects. Another small thing: E:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-ActiveX-x64.cabgoes redE:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Aux-TopLevel-x64.cabE:\Windows_7_Toolkit-Ausführen\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Core-TopLevel-x64.cabboth go green. Is it OK? Regards, Thiersee Edited January 30, 2013 by Thiersee Quote
Legolash2o Posted January 30, 2013 Posted January 30, 2013 Don't worry about it, however it's now fixed. Don't forget, I will release a test build for it in a couple of hours Quote
