Problem with removing IE9 from Exclusive ISO
I removed IE9 from a Win7SP1disk along with some other green components and after all those components were removed, IE9 still appeared in the list screen. So I checked it for removal again and finally created an iso.
After installation I noticed that Computer Management is not working properly anymore due to this:
http://postimage.org/image/cjp7tg4gn/
Same thing happened with the latest test version.
I'm pretty sure it has something to do with some of the integrated updates for IE9, because I don't have this issue with the regular refreshed Win7 iso.
I meant to say was Internet Explorer in general. I think the component is called Internet Explorer when trying to remove it with the advanced component removal tool.
AFAIK tou cannot completely remove IE after upgradeing it, as it contains many integral Windows components also.
Yes I know this, but like I said, I never had a problem removing Internet Explorer b4 with the Win7 refresh ISO from this site. Just with the Januari Exclusive one, because it has some IE updates integrated in it.
I guess, since you are not going to use IE, you could try removing all the updates to IE first, then try to remove IE itself.
Yes, you can do that this way, should work also as bphlpt described...but I never haved tried to update it first and then remove it...as it probably wouldnt work out...
