Posted February 3, 201312 yr Attached - latest WinToolkit141-15_Test1.7z used. It's the windows update cabs. one of them going red.
February 3, 201312 yr Same bug from me here Another small thing: E:\Windows_7_Toolkit-Ausführen\Updates\McRipWindows 7x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-ActiveX-x64.cabgoes red
February 3, 201312 yr The .cab-Update is going green now, but there is 4 time a strange behavior, always with cab-files; for the last two is the OK-button not accessible.1.4.1.15_Test2; no other error during integration, I'm going now to install in a VM. Regards, Thiersee Edit: no errors during installation in the VirtualBox. Edited February 3, 201312 yr by Thiersee
February 15, 201312 yr I have the same update going red in the stable 1.4.1.14 and the latest test build .15I don't have a lot of old versions but WinToolkit 140-77 installs this ActiveX cab fineEDIT: Rica, if you read this you may want to remove the "Solved" from the subject line Edited February 17, 201312 yr by compstuff
March 6, 201312 yr Author Sorry, haven't been around lately... so is this solved in the latest build? Going to check this also tommorow probably...
March 6, 201312 yr I also haven't checked yet but I am going to try today... Thiersee reported that .16 worked but .17 didn't... http://www.wincert.net/forum/topic/11068-windows-update-agent-not-integrated-in-v14117/?p=96636Sorry, haven't been around lately... so is this solved in the latest build? Going to check this also tommorow probably...
