There is a known UPnP vulnerability in some routers, its very serious and you should test your network see if you are affected (mine is O.K.)
Read more: http://www.reuters.com/article/2013/01/29/us-cybersecurity-bugs-idUSBRE90S06320130129
View more: http://twit.tv/show/security-now/389
Test yourself: https://www.grc.com (go to Services > ShieldsUP! and you will find a "instant UPnP exposure test" button)
With or without my software firewall (Outpost Free), my router is safe:
THE EQUIPMENT AT THE TARGET IP ADDRESS
DID NOT RESPOND TO OUR UPnP PROBES!
You can get a more detailed scan on this site, it tells you what version UPnP/OS your router has (needs Java)
http://netalyzr.icsi.berkeley.edu/
Here is why I am not affected
This device appears to run "POSIX UPnP/1.0 linux/5.60.127.2901".
A device that is affected shows this
This device appears to run "Linux/2.6.35.8, UPnP/1.0, Portable SDK for UPnP devices/1.6.6". This system may be vulnerable to CVE-2012-5958 and CVE-2012-5959
Portable SDK for UPnP Devices has been updated to resolve this issue
