Posted February 4, 201312 yr Hi all, I've just started using WinToolkit and it's done woners tomy Win7 disc, however after integrating IE9 MSU every time i enter the browser additional tab launches (http://windows.microsoft.com/en-us/internet-explorer/products/ie-9/welcome-upgrade2). My question: is there a way to avoid it or fix it? Thanx for any directions in advance
February 4, 201312 yr Check the tweaks in the IE category from AIO. It's very intuitive which to select. If you have further issues, ask again.
February 9, 201312 yr @dhjana I've also had this issue with my integrations that involve IE 9. I have searched the tweaks section also looking for something I may have overlooked and the only thing that I can find that might effect this odd behavior is setting a custom home page. However, the problem for me seems to be random, I wish I had something more for you. Rica, seems to have an idea, Rica, can you be more specific?
February 9, 201312 yr It's Disable First Run Customize from Internet Explorer Tweeks Now to not rebuild and install again just use this reg entry Windows Registry Editor Version 5.00;Disable IE9 Welcome Screen[HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Internet Explorer\Main]"DisableFirstRunCustomize"=dword:00000001 Edited February 9, 201312 yr by ianymaty
February 9, 201312 yr Or you can use unattended.xml <component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <AllowedSites>http://www.google.ee;http://www.hinnavaatlus.ee;http://www.vwklubi.ee</AllowedSites> <BlockPopups>yes</BlockPopups> <FilterLevel>High</FilterLevel> <PlaySound>false</PlaySound> <ShowInformationBar>true</ShowInformationBar> <DisableFirstRunWizard>true</DisableFirstRunWizard> <DisableOOBAccelerators>true</DisableOOBAccelerators> <DisableWelcomePage>true</DisableWelcomePage> <LockToolbars>true</LockToolbars> <Home_Page>http://www.google.ee</Home_Page> <LocalIntranetSites>file://192.168.1.2;file://192.168.1.3;file://192.168.1.4</LocalIntranetSites> <SearchScopes> <Scope wcm:action="add"> <ScopeDefault>true</ScopeDefault> <ScopeDisplayName>Google</ScopeDisplayName> <ScopeKey>SearchProvider1</ScopeKey> <ScopeUrl>http://www.google.ee/search?q={searchTerms}</ScopeUrl> <FaviconURL>http://www.google.com/favicon.ico</FaviconURL> <SuggestionsURL>http://clients5.google.com/complete/search?q={searchTerms}&client=ie8&mw={ie:maxWidth}&sh={ie:sectionHeight}&rh={ie:rowHeight}&inputencoding={inputEncoding}&outputencoding={outputEncoding}</SuggestionsURL> </Scope> <Scope wcm:action="add"> <ScopeDisplayName>Bing</ScopeDisplayName> <ScopeKey>SearchProvider2</ScopeKey> <ScopeUrl>http://www.bing.com/search?q={searchTerms}&form=IE8SRC&src=IE-SearchBox</ScopeUrl> <FaviconURL>>http://www.bing.com/favicon.ico</FaviconURL> <SuggestionsURL>http://api.bing.com/qsml.aspx?query={searchTerms}&market={Language}&form=IE8SSC&maxwidth={ie:maxWidth}&rowheight={ie:rowHeight}§ionHeight={ie:sectionHeight}</SuggestionsURL> </Scope> </SearchScopes> <FavoritesList> <FavoriteItem wcm:action="add"> <FavID>1</FavID> <FavTitle>Intel Driver Update Utility</FavTitle> <FavURL>http://www.intel.com/p/en_US/support/detect</FavURL> </FavoriteItem> <FavoriteItem wcm:action="add"> <FavID>2</FavID> <FavTitle>Eset Online Scanner</FavTitle> <FavURL>http://www.eset.com/us/online-scanner</FavURL> </FavoriteItem> <FavoriteItem wcm:action="add"> <FavID>3</FavID> <FavTitle>Bitdefender QuickScan</FavTitle> <FavURL>http://quickscan.bitdefender.com</FavURL> </FavoriteItem> <FavoriteItem wcm:action="add"> <FavID>4</FavID> <FavTitle>VirusTotal</FavTitle> <FavURL>https://www.virustotal.com</FavURL> </FavoriteItem> <FavoriteItem wcm:action="add"> <FavID>5</FavID> <FavTitle>Microsoft Safety Scanner</FavTitle> <FavURL>http://www.microsoft.com/security/scanner</FavURL> </FavoriteItem> </FavoritesList> <FeedList> <FeedItem wcm:action="add"> <FeedKey>Feed1</FeedKey> <FeedTitle>Delfi</FeedTitle> <FeedURL>http://feeds2.feedburner.com/delfiuudised</FeedURL> </FeedItem> </FeedList> </component> This should do the trick <DisableWelcomePage>true</DisableWelcomePage><DisableFirstRunWizard>true</DisableFirstRunWizard> Edited February 9, 201312 yr by Etz
February 9, 201312 yr Etz that is AWESOME info... I have an autounattend.xml but I did't even know you could do that Edited February 9, 201312 yr by compstuff
February 12, 201312 yr Hi, because of your very excellent autounattended.xml where is your information source of whats all possible with an autounattended.xml?Are there Tools available where i can choose what for a xml i need and it creates it? Greetz X23
February 12, 201312 yr In the Windows 7 forum, took me 2 seconds to find: http://www.wincert.net/forum/topic/9178-create-your-own-autounattendxml-all-in-one-x86amd64/ x23piracy: general advice: lurk more !
February 12, 201312 yr Hi, thank you man! On 2/12/2013 at 1:52 PM, mooms said: x23piracy: general advice: lurk more ! I vow to improve. Something else: If i add a changed autounattended.xml it takes some time to see that it works, integration into image,installation on a vm. Is there any tool out that validates an autounattended.xml?Would be nice to know if the xml is ok without needing to test every little change. Greetz X23 Edited February 12, 201312 yr by x23piracy
February 12, 201312 yr WAIK can say if the syntax is OK, but not if the autounattend works and does, what you want. Thiersee
February 12, 201312 yr Hi, On 2/12/2013 at 7:47 PM, Thiersee said: WAIK can say if the syntax is OK, but not if the autounattend works and does, what you want. ok thank you i will take a look at WAIK, never seen or used before Greetz X23
