x23piracy Posted February 6, 2013 Share Posted February 6, 2013 (edited) Hi, used 1.4.1-14 with Win 7 Pro x64 and integrated some stuff,Wintoolkit Installer will start but nothing happens, the status bar is never moving. Howto debug what happenend and howto manually start installer again? Anyone else experiencing this installer bug? I checked the forum and there are similar reports that installer dont work with olderversions. Is there a wintoolkit version out that is stable and working?I used this ini: http://pastebin.com/refwHSk2 EDIT: Someone in win-lite forum told me that maybe the integration of ati and nvidia gpu driversis the problem... LOL? For what else should be the driver integrations functionality might be? Greetz X23 Edited February 6, 2013 by x23piracy Quote Link to comment Share on other sites More sharing options...
bphlpt Posted February 6, 2013 Share Posted February 6, 2013 Just to get used to how things work, why don't you make as simple a build as possible - no extra drivers, no addons, no removals, etc, just to practice and convince yourself that the builder works. Remember to double check the MD5 of the Win-Toolkit download, temporarily disable any anti-virus and sandbox type programs, and use a short path for all your work folders, such as C:\WinTK. If that works, then you can try changing things and if you have problems you can bet that there is at least a 75% chance that you probably did something wrong. Cheers and Regards Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 6, 2013 Author Share Posted February 6, 2013 Hi, this is my runoncelog.txt 1.4.1.13 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)IDrive: D:\ (Looking for Installation Files...)Enumerating Installation [sOFTWARE\WinKit]... (Enumerating Installation [sOFTWARE\WinKit]...)Enumerating Installation [sOFTWARE\W7T]... (Enumerating Installation [sOFTWARE\W7T]...)Enumerating Installation [sOFTWARE\WinToolkit]... (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00000|7zip (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\7zip\7z920_x64.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00001|Acrobat Reader 11 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Acrobat_Reader 11\AdbeRdr11001_de_DE.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00002|Active Fax (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Active_Fax\actfax_setup_x64_ge.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00003|Flash Player 11 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Flash_Player 11\install_flash_player_11_active_x_ie.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00004|Greenshot (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Greenshot\Greenshot-INSTALLER-1.0.6.2228.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00005|Java 7u13 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Java_7u13\jdk-7u13-windows-x64.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00006|MegaView (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\MegaView\MegaView.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00007|MegaView3D (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\MegaView3D\MegaView3D.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00008|Navision (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Navision\setup.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00009|Office 2007 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Office_2007\SETUP.EXE* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00010|Office 2010 Home+Business (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Office_2010 Home+Business\X17-75062.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00011|Office 2010 Professional (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Office_2010 Professional\X16-32011.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00012|Shockwave (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\Shockwave\Shockwave_Installer_Full_other.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00013|TeamViewer (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\TeamViewer\TeamViewer.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00014|CheckPoint VPN Client (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\Apps\CheckPoint_VPN Client\VPN_x64.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)1.4.1.13 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)Found Drive: C:\ (Looking for alternatives...)Found Drive: D:\ (Looking for alternatives...)IDrive: (Looking for alternatives...)No IDrive Found: (Aborting: No installation files found...) Paths are correct and programs are in right place, what happens here?Also i found the wintoolkitrunonce binary! Greetz X23 Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 6, 2013 Share Posted February 6, 2013 What is your installation media? DVD, USB, etc... Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 6, 2013 Author Share Posted February 6, 2013 (edited) Hi, What is your installation media? DVD, USB, etc... i burned a double layer dvd.Same failure if i boot the iso over pxe. What i have done: Downloaded latest Windows 7 x64 Imageopened the wim removed all except win 7 pro 64opened again, integration: a bunch of drivers - worked i saw some of the integrated ones in the test systemsome tweaks - worked havent proved all but there was some of the changes i sawunattended into boot2.wim - workedadded one gadget - workedadded background pics - workedadded all available security updates - workedadded a bunch of apps like (flash, acrobat reader) without automatic install, i expected then the installer will let me choose what to install. - fail Then after it has finished ~6 hours later i burned the image to dl dvd and tried it. How works wintoolkitrunonce? with which parameter (config, ini) will it be executed?Like that i may can rerun the installer to check what gets wrong instead of building a new iso and install it completely again.One Try one day Greetz X23 Edited February 6, 2013 by x23piracy Quote Link to comment Share on other sites More sharing options...
compstuff Posted February 6, 2013 Share Posted February 6, 2013 I just finished doing a few integrations using 141v15-4 and once I fixed my errors it is working fine but I have not done drivers yet. I am very particular when I do my integrations because I actually have A LOT going on that is custom work so basically I make sure that the base works fine and that I can reproduce solid integrations before I start some of my more complex scripts. What I would suggest is doing this in phases to see where the problem is that way you can eliminate variables easier. Take your clean WIM and just add the updates and then do a VM install and see if that works. Then do other things in separate phases. I have scripts that basically don't change at all so if a particular version doesn't work with them I can try an older version and if they work then I can make a valid report and it will be addressed. Hope that makes sense and helps Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 6, 2013 Author Share Posted February 6, 2013 Hi, yeah iam actually starting from scratch.What i do first is do nothing except adding flash and shockwave installers with non auto mode. Actually its rebuilding and saving the wim i come back if i tried it in a vm. Greetz X23 Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 7, 2013 Author Share Posted February 7, 2013 (edited) Hi, ok my test was negative, same like before the installer is shown but nothing ever happens: I really just opened a fresh copy of the latest ms iso download of win 7 x64selected professional to edit, just added 2 installers (flash, shockwave)made the iso and installed it. I first thougth iam to stupid and i have to click somewhere but i saw screenshotsif how it have to look like FYI: I mounted the image as iso into the vm to install What happend? FYI: Iam actually testing with 1.4.1-15T15 Greetz X23 Edited February 7, 2013 by x23piracy Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 7, 2013 Author Share Posted February 7, 2013 Hi, and again same with the latest T15 Version, installer appears but nothing ever happens.And again i just opened the wim integrated flash, acrobat reader and 7zip with non automatic install. I could make a screenshot but i will look exactly like the one above. Help please. Greetz X23 Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 7, 2013 Share Posted February 7, 2013 FYI: I mounted the image as iso into the vm to installIt's OK! FYI: Iam actually testing with 1.4.1-15T15Where did you get this version from?The actual test is 1.4.1.15_Test 14; only the nstaller is version 1.4.1.15 (withou t15). And again i just opened the wim integrated flash, acrobat reader and 7zip with non automatic install.Did you try with automatic install (always)? I ask only, because I do the same and I have no problem: a couple of driver, addon, and silent-installers (always install). Thiersee Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 7, 2013 Author Share Posted February 7, 2013 (edited) Hi, It's OK! Where did you get this version from?The actual test is 1.4.1.15_Test 14; only the nstaller is version 1.4.1.15 (withou t15). Did you try with automatic install (always)? I ask only, because I do the same and I have no problem: a couple of driver, addon, and silent-installers (always install). Thiersee sorry i ment t14 grabbed it from here: http://www.wincert.net/leli55PK/Testing/Yes i added one of the addons with automatic (7zip) actually iam waiting if the installer will do something after waiting a bunch of minutes.i will now close it, and will check if 7zip was installed. mom ill be back Edit: 7zip wasn't installed, i also didnt saw any installer, i didnt gave silent switches so it just execute the installer but there was nothing. ;( this is the log after installing windows:1.4.1.15 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)CommandLineArg: /BROWSE (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)IDrive: D:\ (Looking for Installation Files...)Enumerating Installation [sOFTWARE\WinKit]... (Enumerating Installation [sOFTWARE\WinKit]...)Enumerating Installation [sOFTWARE\W7T]... (Enumerating Installation [sOFTWARE\W7T]...)Enumerating Installation [sOFTWARE\WinToolkit]... (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00000|7z920_x64 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: |%DVD%:\WinToolkit_Apps\7z920_x64\7z920_x64.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00001|install_flash_player_11_active_x_ie (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\install_flash_player_11_active_x_ie\install_flash_player_11_active_x_ie.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00002|AdbeRdr11001_de_DE (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\AdbeRdr11001_de_DE\AdbeRdr11001_de_DE.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...) If i start wintoolkitrunonce in system32 manually again also nothing happens, no failure no choice just silence.I just see the installer asking me to choose what to install but i cannot choose from anything and the progress bar never changes. this is the log after manually starting wintoolkitrunonce: 1.4.1.15 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)CommandLineArg: /BROWSE (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)IDrive: D:\ (Looking for Installation Files...)Enumerating Installation [sOFTWARE\WinKit]... (Enumerating Installation [sOFTWARE\WinKit]...)Enumerating Installation [sOFTWARE\W7T]... (Enumerating Installation [sOFTWARE\W7T]...)Enumerating Installation [sOFTWARE\WinToolkit]... (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00000|7z920_x64 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: |%DVD%:\WinToolkit_Apps\7z920_x64\7z920_x64.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00001|install_flash_player_11_active_x_ie (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\install_flash_player_11_active_x_ie\install_flash_player_11_active_x_ie.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00002|AdbeRdr11001_de_DE (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\AdbeRdr11001_de_DE\AdbeRdr11001_de_DE.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...)1.4.1.15 (Looking for CommandLineArgs...)CommandLineArg: C:\Windows\System32\WinToolkitRunOnce.exe (Looking for CommandLineArgs...)Found Drive: C:\ (Looking for Installation Files...)Found Drive: D:\ (Looking for Installation Files...)IDrive: D:\ (Looking for Installation Files...)Enumerating Installation [sOFTWARE\WinKit]... (Enumerating Installation [sOFTWARE\WinKit]...)Enumerating Installation [sOFTWARE\W7T]... (Enumerating Installation [sOFTWARE\W7T]...)Enumerating Installation [sOFTWARE\WinToolkit]... (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00000|7z920_x64 (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: |%DVD%:\WinToolkit_Apps\7z920_x64\7z920_x64.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00001|install_flash_player_11_active_x_ie (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\install_flash_player_11_active_x_ie\install_flash_player_11_active_x_ie.msi* (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyFound: 00002|AdbeRdr11001_de_DE (Enumerating Installation [sOFTWARE\WinToolkit]...)KeyValue: %DVD%:\WinToolkit_Apps\AdbeRdr11001_de_DE\AdbeRdr11001_de_DE.exe* (Enumerating Installation [sOFTWARE\WinToolkit]...) Greetz X23 Edited February 7, 2013 by x23piracy Quote Link to comment Share on other sites More sharing options...
compstuff Posted February 7, 2013 Share Posted February 7, 2013 Instead of trying SFX and silent installers could use try a single update from McRips server just to see if even a basic function is working? Make sure to use the basic AIO integrator Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 7, 2013 Author Share Posted February 7, 2013 Hi, yes i can do that but remember it look like wintoolkitrunonce and its config is right prepared on the cd,i can start it but it still does nothing, iam sure it must be a little bug or maybe mistake on my side but which? I come back later to report if what u want works. Greetz X23 Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 7, 2013 Share Posted February 7, 2013 @X23piracy I tried an integration with the same silent-installer (7zip, Flash, AdobeReader) like you and with both modes, prompt-Install and auto: in prompt-install mode I have exactly the same issue, in auto-mode NOT :ranting:! Fresh ISO (X17-59885)Win7 Professional x64 (integration) and working-environmentWinToolkit 1.4.1.15-Test14 (Installer is 1.4.1.15). Thiersee Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 7, 2013 Author Share Posted February 7, 2013 (edited) Hi, @X23piracy I tried an integration with the same silent-installer (7zip, Flash, AdobeReader) like you and with both modes, prompt-Install and auto: in prompt-install mode I have exactly the same issue, in auto-mode NOT :ranting:! Fresh ISO (X17-59885)Win7 Professional x64 (integration) and working-environmentWinToolkit 1.4.1.15-Test14 (Installer is 1.4.1.15). Thiersee i like to thank god that someone confirmed that greatWhat do you do when you set automatic, do you collect all the silent switches from the different installers and add these switches as arguments? I need to choose some updates because i integrate thinks like office 07 and 10 and i want to choose which office to install, so i can live not only with automatic mode. Lego can you fix that maybe? P.S found an old forum thread about irc... the channel is empty seems to be obsolete? Greetz X23 Edited February 7, 2013 by x23piracy Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 7, 2013 Share Posted February 7, 2013 What do you do when you set automatic, do you collect all the silentswitches from the different installers and add these switches asarguments?No, I have a ready silent-installer for every program (in this case I leave the switch-field empty) or I use the original executable with silent-switches in the switch-field. I need to choose some updates because i integrate thinks like office07 and 10 and i want to choose which office to install, so i can livenot only with automatic mode.It would be nice for me too. Thiersee Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 8, 2013 Share Posted February 8, 2013 I will have a look when I finish University. Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 8, 2013 Share Posted February 8, 2013 Here am I again! Yesterday and today I tried a lot of WinToolkit versions because of the issue with the installer and this was the result: older versions:1.4.0.77 (installer version 4.6.3) works fine1.5.0.1_Test39 (installer version 4.8.1) does NOT work newer versions:1.4.1.9 (installer version 4.8.1) does NOT work1.4.1.15 (installer version 1.4.1.15) does NOT work @X23piracy If you want can you try version 1.4.0.77. @legolash2o You are now asked for a solution ! Regards, Thiersee Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 8, 2013 Author Share Posted February 8, 2013 Hi, some other questions.With automatic install i have some programs that won't install but if i try the switcheson a test system everything works well. What is the working directory if the installer executes a binary with parameters? For example for Navision i execute setup.exe /quiet /config Classic.xmlMaybe he cannot find the Classic.xml because the working directory is not: installmedium:\WinToolkit_Apps\Appdir Is there a variable i can use? like setup.exe /quiet /config ${WTKmedium}\WinToolkit_Apps\Appdir\Classic.xml? I have no other idea why the installation should fail, the silent parameter are correct and work manually on a test system. Greetz X23 Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 8, 2013 Share Posted February 8, 2013 For example for Navision i execute setup.exe /quiet /config Classic.xmlMaybe he cannot find the Classic.xml because the working directory is not: installmedium:\WinToolkit_Apps\AppdirYou can build up a silent installer with this program (installation in english too!) you put all the files (setup.exe and your Classic.xml) in a folder and give the silent-switches in the SFX-field (SFX-Schalter). In this way your setup.exe find the classic.xml. Thiersee Quote Link to comment Share on other sites More sharing options...
x23piracy Posted February 8, 2013 Author Share Posted February 8, 2013 Hi, You can build up a silent installer with this program (installation in english too!) Thiersee thank you works well know lets wait for a bugfix from lego. Greetz X23 Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 8, 2013 Share Posted February 8, 2013 So the error only happens on 'prompt install'? Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 8, 2013 Share Posted February 8, 2013 (edited) So the error only happens on 'prompt install'?Yes Sir! Have a look to post #8, #14, #18: I repeated the test three times each version (I installed Win7 in a VirtualBox), always with the same INI, a fresh ISO (x17-59885) and Professional x64. Edited February 8, 2013 by Thiersee Quote Link to comment Share on other sites More sharing options...
Legolash2o Posted February 8, 2013 Share Posted February 8, 2013 problem is, no one has provided a screen shot so i have to use VirtualBox Does it let you select anything before pressing start/install? EDIT: I've managed to replicate the error. Quote Link to comment Share on other sites More sharing options...
Thiersee Posted February 8, 2013 Share Posted February 8, 2013 (edited) problem is, no one has provided a screen shot so i have to use VirtualBox Does it let you select anything before pressing start/install?What for screenshot?X23piracy provided a screen shot in post #8; during my tests I got only on version 1.4.0.77 a list from installer, where I could select a single or all the SFXs.Whitin the other tested versions I got only the the same as in post #8 and no menu to select SFX. Edited February 8, 2013 by Thiersee Quote Link to comment Share on other sites More sharing options...
