"Strange" (for me) behavior with ISO and ei.cfg
This is not a problem, I only want to know, why.
I saw this difference on loading an install.wim (allways the same ISO!):
1) If I manually mount the ISO and then copy the content in my working-folder, I don't have the button to remove the ei.cfg (it's OK, I removed it)
2) If I "browse for ISO" and extract the content into the same working-folder (within WinToolkit), I get the button for the ei.cfg.
Do WinToolkit write the ei.cfg in \sources\ again?
TNX, Thiersee
Nope, usually when you click remove it renames it to ei.cfg.bak and restore then renames it back.
I know it.
May be I didn't explain it clearly.
I have an ISO with removed ei.cfg
If I mount this ISO with VirtualCloneDrive and look in the sources-folder, there is wether ei.cfg nor ei.cfg.bak.
If I extract the same ISO within WinToolkit and look in the sources-folder, there is an ei.cfg.
