[SOLVED] Howto unattend (edition, destination) - add domain join
Hi,
can someone help with integrating the following to my autounattended.xml:
  Quote
  <?xml version="1.0" encoding="utf-8" ?>
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<settings pass="specialize">
<component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <FavoritesDelete>true</FavoritesDelete>
  </component>
<component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <SystemLocale>de-DE</SystemLocale>
  <UILanguage>de-DE</UILanguage>
  <UserLocale>de-DE</UserLocale>
  <InputLocale>0407:00000407</InputLocale>
  </component>
<component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Identification>
  <JoinWorkgroup>ARBEITSGRUPPE</JoinWorkgroup>
  </Identification>
  </component>
<component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <ComputerName>*</ComputerName>
  <TimeZone>W. Europe Standard Time</TimeZone>
  </component>
  </settings>
<settings pass="windowsPE">
<component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  </component>
<component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ImageInstall>
<OSImage>
<InstallFrom>
<MetaData wcm:action="add">
  <Key>/IMAGE/INDEX</Key>
  <Value>1</Value>
  </MetaData>
  </InstallFrom>
  </OSImage>
  </ImageInstall>
<Display>
  <ColorDepth>32</ColorDepth>
  <HorizontalResolution>1024</HorizontalResolution>
  <VerticalResolution>768</VerticalResolution>
  <RefreshRate>60</RefreshRate>
  </Display>
<UserData>
<ProductKey>
  <Key>HYF8J-CVRMY-CM74G-RPHKF-PW487</Key>
  </ProductKey>
  <AcceptEula>true</AcceptEula>
  <Organization>ABC</Organization>
  <FullName>123</FullName>
  </UserData>
  </component>
  </settings>
<settings pass="oobeSystem">
<FirstLogonCommands>
<SynchronousCommand wcm:action="add">
  <Order>1</Order>
  <CommandLine>%Systemdrive%\Install\WPI.cmd</CommandLine>
  </SynchronousCommand>
  </FirstLogonCommands>
<OOBE>
  <HideEULAPage>true</HideEULAPage>
  <ProtectYourPC>3</ProtectYourPC>
  <NetworkLocation>Work</NetworkLocation>
  </OOBE>
<UserAccounts>
<AdministratorPassword>
  <Value>blablub</Value>
  <PlainText>true</PlainText>
  </AdministratorPassword>
<LocalAccounts>
<LocalAccount wcm:action="add">
<Password>
  </Password>
  <Name>retsch</Name>
  <Group>Administrators</Group>
  </LocalAccount>
  </LocalAccounts>
  </UserAccounts>
<AutoLogon>
  <Password>
  </Password>
  <Enabled>true</Enabled>
  <LogonCount>2</LogonCount>
  <Username>Administrator</Username>
</AutoLogon>
  <ShowWindowsLive>false</ShowWindowsLive>
  </component>
  </settings>
  </unattend>
- I dont like to choose for win 7 pro i should automatically been taken
- Win 7 should automatically be installed on first hdd and should take all available space while deleting partition if existing and if not it should create one over the complete first hdd.
If possible automatic domain join would be great (like with win xp)
Thanks for your help
Greetz X23
Edited by x23piracy
I needed a long time before I got the right autounattend.xml for my purposes: a lot of work "try and pray" is necessary...
I worked with the WAIK and some links.
If you want can I give you those links (a couple of them in german).
  Quote
For this I think you should use an Win7-Pro-ISO without removing the ei.cfg.
  Quote
I think (but I'm not sure), if you give only the parameters "DiskID"=0, "Partition"=1 and no size, only 1 partition on the first HDD and over the complete HDD will be generated.
        <component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <UserData>                <ProductKey>                    <WillShowUI>OnError</WillShowUI>                    <Key>XXXXX-XXXXX-XXXXX-XXXXX-XXXXX</Key>                </ProductKey>                <AcceptEula>true</AcceptEula>            </UserData>            <EnableFirewall>true</EnableFirewall>            <ImageInstall>                <OSImage>                    <WillShowUI>OnError</WillShowUI>                    <InstallToAvailablePartition>false</InstallToAvailablePartition>                    <InstallTo>                        <DiskID>0</DiskID>                        <PartitionID>1</PartitionID>                    </InstallTo>                </OSImage>            </ImageInstall>            <EnableNetwork>true</EnableNetwork>            <DiskConfiguration>                <Disk wcm:action="add">                    <CreatePartitions>                        <CreatePartition wcm:action="add">                            <Order>1</Order>                            <Type>Primary</Type>                        </CreatePartition>                    </CreatePartitions>                    <ModifyPartitions>                        <ModifyPartition wcm:action="add">                            <Active>true</Active>                            <Extend>false</Extend>                            <Format>NTFS</Format>                            <Label>Example</Label>                            <Letter>C</Letter>                            <Order>1</Order>                            <PartitionID>1</PartitionID>                        </ModifyPartition>                    </ModifyPartitions>                    <DiskID>0</DiskID>                    <WillWipeDisk>true</WillWipeDisk>                </Disk>                <WillShowUI>OnError</WillShowUI>            </DiskConfiguration>
  Quote
It should be in the section "specialize" (but I don't have experience with joining domain)
        <component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <Identification>                <JoinWorkgroup>ARBEITSGRUPPE</JoinWorkgroup>                <Credentials>                    <Domain>Test</Domain>                    <Password>Password</Password>                    <Username>X23piracy</Username>                </Credentials>                <JoinDomain>Test</JoinDomain>            </Identification>        </component>
Regards, Thiersee
Hi,
Regards, Thiersee
yes please gimmme that links.
I have win7 pro iso without removed ei.cfg i can only choose win 7 pro but i habe to choose, why choose if there is only one option.
There i no solution with the autounattended.xml to always choose pro?
For domain join and install destination i will test what you gave me ;) thanks for this.
Greetz X23
Thank you for the bunch of links ;),
again for the edition choice, i have a win 7 iso with non removed ei.cfg and i just see professional but i have to choose it.
I dont see any reason to choose if there is no real choice because there is only one entry in the list :)
So any other ideas?
Greetz X23
Edited by x23piracy
Hi,
automatic domain join like thiersee explained is working but i cannot get the always install on first hdd on first partition thingy to work.
Is anyone using some autounattended.xml and gimme a hint?
Greetz X23
  • 4 weeks later...
Hi,
  On 3/10/2013 at 5:01 AM, Gideon said:
Greetz X23, just saw this post. Still interested in a solution?
thank you very much for the offer, but i have a working autounattend.xml :)
- I don't need to choose edition anymore
- I know howto pass partition choosing automatically (but i don't use it) to dangerous
- Inserting the hostname manually is working
- domain join works (actually with problems, after install the state of trust to domain is gone, but machine has joined domain)
- Rest are little tweaks (ie, gadgets etc.)
Is someone has an idea what may happen with my domain join? That worked some days before now all machines join the domain but when i try to logon at the domain it tells me points of trust broken, so i need to temporary leave the domain and join again.
I dont know why this is now happening :(
Greetz X23
Edited by x23piracy
You should probably post a new copy of your current autounattend.xml if you would like any comments or help with it, or even if you just want to share a good working example. :)
Hi,
problem is cleared up:
http://www.wincert.net/forum/topic/11090-domain-join-working-but-after-setup-finished-position-of-trust-bad/#entry97018
Can be seen as solved
Greetz X23
Hi,
  On 3/11/2013 at 2:24 PM, bphlpt said:
Still would be nice to see your current autounattend.xml, if you wouldn't mind and you have a chance. Thanks in advance.
<?xml version="1.0" encoding="utf-8"?><unattend xmlns="urn:schemas-microsoft-com:unattend">    <settings pass="specialize">        <component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <AllowedSites></AllowedSites>            <BlockPopups>yes</BlockPopups>            <PlaySound>false</PlaySound>            <FavoritesDelete>true</FavoritesDelete>            <ShowInformationBar>true</ShowInformationBar>            <DisableFirstRunWizard>true</DisableFirstRunWizard>            <DisableOOBAccelerators>true</DisableOOBAccelerators>            <DisableWelcomePage>true</DisableWelcomePage>            <LockToolbars>true</LockToolbars>            <Home_Page>http://www.google.de</Home_Page>            <LocalIntranetSites></LocalIntranetSites>            <SearchScopes>                <Scope wcm:action="add">                    <ScopeDefault>true</ScopeDefault>                    <ScopeDisplayName>Google</ScopeDisplayName>                    <ScopeKey>SearchProvider1</ScopeKey>                    <ScopeUrl>http://www.google.de/search?q={searchTerms}</ScopeUrl>                    <FaviconURL>http://www.google.de/favicon.ico</FaviconURL>                </Scope>            </SearchScopes>            <FavoritesList>                <FavoriteItem wcm:action="add">                    <FavID>1</FavID>                    <FavTitle>Corporate GmbH</FavTitle>                    <FavURL>http://www.youraddress.de</FavURL>                </FavoriteItem>            </FavoritesList>        </component>        <component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <SystemLocale>de-DE</SystemLocale>            <UILanguage>de-DE</UILanguage>            <UserLocale>de-DE</UserLocale>            <InputLocale>0407:00000407</InputLocale>        </component>	        <component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <Identification>                <JoinWorkgroup>ARBEITSGRUPPE</JoinWorkgroup>                <Credentials>                    <Domain>domain.local</Domain>                    <Password>password</Password>                    <Username>Administrator</Username>                </Credentials>                <JoinDomain>domain.local</JoinDomain>            </Identification>        </component>        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <ComputerName>*</ComputerName> 			<TimeZone>W. Europe Standard Time</TimeZone>        </component>	    </settings>    <settings pass="windowsPE">        <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <UserLocale>de-DE</UserLocale>            <UILanguage>de-DE</UILanguage>            <SystemLocale>de-DE</SystemLocale>            <InputLocale>0407:00000407</InputLocale>        </component>        <component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <ImageInstall>                <OSImage>                    <InstallFrom>                        <MetaData wcm:action="add">                            <Key>/IMAGE/INDEX</Key>                            <Value>3</Value>                        </MetaData>                    </InstallFrom>                </OSImage>            </ImageInstall>            <Display>                <ColorDepth>32</ColorDepth>                <HorizontalResolution>1280</HorizontalResolution>                <VerticalResolution>800</VerticalResolution>                <RefreshRate>60</RefreshRate>            </Display>            <UserData>                <ProductKey>                    <Key>HYF8J-CVRMY-CM74G-RPHKF-PW487</Key>                </ProductKey>                <AcceptEula>true</AcceptEula>                <Organization>Organization</Organization>                <FullName>FullName</FullName>            </UserData>        </component>    </settings>    <settings pass="oobeSystem">        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">            <FirstLogonCommands>                <SynchronousCommand wcm:action="add">                    <Order>1</Order>                    <CommandLine>%Systemdrive%\Install\WPI.cmd</CommandLine>                </SynchronousCommand>            </FirstLogonCommands>            <OOBE>                <HideEULAPage>true</HideEULAPage>                <ProtectYourPC>3</ProtectYourPC>                <NetworkLocation>Work</NetworkLocation>            </OOBE>            <UserAccounts>                <AdministratorPassword>                    <Value>password</Value>                    <PlainText>true</PlainText>                </AdministratorPassword>                <LocalAccounts>                    <LocalAccount wcm:action="add">                        <Password>                            <Value>password</Value>                            <PlainText>true</PlainText>                        </Password>                        <Name>retsch</Name>                        <Group>Administrators</Group>                    </LocalAccount>                </LocalAccounts>            </UserAccounts>            <AutoLogon>                <Password>                    <Value>password</Value>                    <PlainText>true</PlainText>                </Password>                <Enabled>true</Enabled>                <LogonCount>2</LogonCount>                <Username>Administrator</Username>            </AutoLogon>            <ShowWindowsLive>false</ShowWindowsLive>        </component>		<component name="Microsoft-Windows-Sidebar" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">		<Gadget1>%PROGRAMFILES%\windows sidebar\shared gadgets\Leo.gadget,true</Gadget1>		<Gadget2>%PROGRAMFILES%\windows sidebar\gadgets\Clock.Gadget,true</Gadget2>		</component>    </settings></unattend>
Greetz X23
