Hi,
i have an annoying issue with my custom win 7 cd, iam very close to the end that everything is working fine but now i stuck with a installer problem that seems to be kb install related.
This is what i install:
The Problem is that the following products are not installed:
- Shockwave
- Acrobat Reader
- OfficeScan
- VPN
- Office
Framework 4.5
After i mentioned it i directly tried to execute all this installers manually after installer finished and they also didn't worked, the error message i got was related to msi.
Then i thougth about the KB's i install first with the installer and gave the computer a restart. After this restart everything could be installed so my sfx are working well.
Now is the big question, which of these KB's i install makes that Problem to the msi installer service?
How to solve this? Is it possible to start the installer twice? first round all the automatic stuff then reboot and then installer again with all the manual stuff (choose)?
My idea is that lego may can give an option that installer will react like this, on first start it will install everything that is set to automatic install, then it sets another runonce to the registry, reboot, next instance of installer with manual updates, user makes its choice and then manual stuff will be installed, final reboot. finished.
These are the KB that are installed first and iam sure one of it is making that problem:
2603229 http://support.microsoft.com/kb/2603229
2533552 http://support.microsoft.com/kb/2533552
976002 http://windows.microsoft.com/browser-choice
2592687 http://support.microsoft.com/kb/2592687
I dont believe that ie 9 language pack or the microsoft malicious software removal tool and its definitions are causing the problem.
What if its not one of these kb's causing the problem? I dont know what is causing this i only know a restart solves it :(
Greetz X23
Edited by x23piracy
Did you install KB2574819 first?
A I told you in the other thread, this KB MUST be installed before KB2592687! It's not enough, to integrate it in the ISO.
Thiersee
P.S.: I installed yesterday an WinToolkit-ISO with "mixed" configuration (20 prompt install, 55 always installed), 145 updates and many Files/Theme/Background/Tweaks: NO issue!
Hi,
Thiersee
check my Screenshot:
i have KB2574819 installed as Update and KB2592687 as Silent Installs + SFX
I don't have the issue mentioned here: http://www.wincert.net/forum/topic/10950-141-14-installer-wont-work-nothing-happens/page-2#entry95405
This is allready been solved this here must be another issue.
I have checked the KB Articles from the KB's installed with the installer because they cannot integrated and i dont find anything that can give a clou because its nothing related to any msi installation issue or something.
Hi,
I
So i have a bit of fear that i dont find whats causing this :(
Should i try to remove 2592687 from Installer? Maybe this update is so strong that it need a reboot for allowing anymore msi installs? In work we had several problems with Windows 7 and RDP because of protocol update to version 8.0...
Products like activefax and broadgun are installed fine and they don't have msi based installers. Am i stupid or must this stand into relation to my issue? :D
Greetz X23
Edited by x23piracy
Hi,
i removed:
2603229 http://support.micro....com/kb/2603229
2533552 http://support.micro....com/kb/2533552
976002 http://windows.micro.../browser-choice
2592687 http://support.micro....com/kb/2592687
from sfx and all worked fine, so i was right with that one of that 5 causing that problem.
Now it's time to find out which of them.
Lets say its 2592687 how to force it to be last thing installed before final reboot?
I was thinking about a sfx that sets a runonce entry to the registry that executes install in next boot?!
What do you think?
Greetz X23
Edited by x23piracy
Put it at the end on your SFX-list!
Just a question:
why did you put KB2603229 twice for integration?
exactly this update could be the reason for your problem, see MS-Info
 Note for OEMs and system builders
Do not slipstream this
update into preconfigured operating system images. You must run this
update only after the operating system is installed and the Out-of-Box
Experience (OOBE) is finished.
Thiersee
Hi,
Just a question:
Thiersee
yeah i allready found my mistake and removed them both because when i tried to install it system says allready installed,
so it seems i can discard both, for the rest 3 kbs i added 2533552 to automatic again and 976002 and 2592687 went to manual.
Since 976002 is annoying and 2592687 made problems for us i decided to have them manually but good to know that
i may work also if i add them to automatic again.
I later come back and will tell if that what i told above is working.
Greetz X23
Edited by x23piracy
Hi,
Automatic items already get installed before the manual items. Did you find the cause of the error?
not yet but i made the circel tigther, it must be 976002 or 2592687 (i more prefer that the guilty one must be 2592687).
I just removed that two from automatic to manual, then all worked fine.
Lets say its 2592687, if that is true it should be installed as last one, then reboot.
Greetz X23
