Posted February 10, 201312 yr Hi, as far as i understand the process, the installer will be executed via a registry runonce?But how does it works? I know that there is the wintoolkitrunonce binary in system32, where is the config that will tellit what to offer and install? What are the parameter that work with the binary? I maybe want to use it in my own way so i need to know what i can do with it. Greetz X23
February 10, 201312 yr Author Hi, yeah i can find that its under runonce with para /BROWSE but iam sure that isnt all. Greetz X23 Edited February 10, 201312 yr by x23piracy
February 11, 201312 yr On 2/10/2013 at 4:56 PM, x23piracy said: as far as i understand the process, the installer will be executed via a registry runonce?But how does it works?I know that there is the wintoolkitrunonce binary in system32, where is the config that will tellit what to offer and install?What are the parameter that work with the binary? Use the Registry tool and mount this hive. Wim Registry Editor > Wim_Software\\WinToolkit Edited February 11, 201312 yr by dotfusion
February 11, 201312 yr Author Hi, On 2/11/2013 at 2:50 AM, dotfusion said: Use the Registry tool and mount this hive. Wim Registry Editor > Wim_Software\\WinToolkit thank you for the hint but that stuff isn't documented anywhere?@Lego nothing? Greetz X23
February 11, 201312 yr I don't think you will find anymore than what has already been discussed in the forums, The way the WinToolkitRunOnce works is relatively straight forward. When Win Toolkit integrates a silent installer it copies the silently installer to an Apps folder on the root of your installation source media then adds an entry to the registry RunOnce key which is then executed during first desktop load after windows has installed on the target machine. Here is discussion that might help you in your quest. http://www.wincert.net/forum/topic/10697-howto-removing-changing-a-silent-installer-switch-after-integration/unread/ http://technet.microsoft.com/en-us/library/dd346765.aspx Edited February 11, 201312 yr by dotfusion
February 11, 201312 yr Author Hi, On 2/11/2013 at 6:21 PM, dotfusion said: http://www.wincert.net/forum/topic/10697-howto-removing-changing-a-silent-installer-switch-after-integration/unread/ http://technet.microsoft.com/en-us/library/dd346765.aspx well done thank you and of course i may was a bit to lazy Greetz X23
