Posted February 11, 201312 yr Just found out that WT 1.4.1.14 seems to set a registry entry at [HKEY_USERS\TempHive\Software\Microsoft\Windows\CurrentVersion\RunOnce]"mctadmin"="C:\\Windows\\System32\\mctadmin.exe" (In this sample TempHive is an imported NTUSER.DAT structure) I assume it stems from an option in the Tweaks section of the AIO-Integrator, just which one?I try to write a registry setting for this registry key (accessing the TempHive structure) via RunOnceEx and before the (new?) entry mctadmin appeared that worked fine, now it doesn't any longer. I tried with this lineReg add %K%\010 /f /v 4 /d "reg delete HKU\TempHive\Software\Microsoft\Windows\CurrentVersion\Runonce /f /v mctadmin"to delete it before writing my own value, however this didn't work out. :g:
February 12, 201312 yr http://social.technet.microsoft.com/forums/en-us/w7itproinstall/thread/2D00F9CC-90FD-4E9B-96F9-26C71770F5CC
February 12, 201312 yr That's new to me, I don't even have anything to do with mctadmin in my code :/
February 13, 201312 yr Author So "mctadmin" seems to be "safe to delete", all right. Thank you, sp0iledbrat. Edit: Just decided to keep it, it doesn't seem to interfere with my oem stuff any more. Edited February 14, 201312 yr by foobuzz
